bugtub Samba Member
Posted: Thu Aug 18, 2016 2:58 am Post subject: Widening front beam |
I want to widen my front beam. Can I still use the torsion leaves or do I have to go for through rods to hold the arms in place? I have heard that you can cut the leaves and use 4 adjusters but I can’t see how this will hold the arms securely in place |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Thu Aug 18, 2016 3:21 am Post subject: Re: Widening front beam |
I show how I widened mine 4" by just adding the adjusters.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...p;start=40 _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bugtub Samba Member
Posted: Thu Aug 18, 2016 12:52 pm Post subject: Re: Widening front beam |
Thanks TDCTDI
That does seem to be the accepted way to go. I was just concerned how secure the arms are, as the adjusters have to have some play to work there appears nothing to stop them pulling sideways |
retterath Samba Member
Joined: July 19, 2004 Posts: 661 Location: SW Washington state
Posted: Thu Aug 18, 2016 3:02 pm Post subject: Re: Widening front beam |
There are grub screws that hold the springs in place. |
bugtub Samba Member
Posted: Fri Aug 19, 2016 3:12 am Post subject: Re: Widening front beam |
Yes its I know its grub screwed. Normally its held by the centre and the other side none of which can't move. With the adjusters I’ve seen there is nothing to stop the centre of them sliding up the tube or am I missing something.?
Posted: Fri Aug 19, 2016 3:37 am Post subject: Re: Widening front beam |
There is the little grub screw that holds the spring pack in the clamp which is rotated down 90* on a balljoint beam), then the clamp is held in place by the stud that goes through the slot in the adjuster, which is then secured by the aluminum block & nut. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
