GuruX Samba Member
Joined: August 09, 2016 Posts: 27 Location: Göteborg, Sweden
Posted: Fri Aug 19, 2016 7:13 am Post subject: Late bay: thickness of hub and drum/disc |
This is for a 74 Late Bay Camper.
I recently got hold of a set of Mercedes Vito(?) rims with some decent rubbers. Bolta pattern, ET and hub size seems to be all good. But as always, how long does the wheel studs need to be?
The original front wheel studs seems to be 60 mm long in their full length. The rear seems to be 34 mm. These are good for the steel rims. But these are alloys. The rim is about 20 mm thick at the bolt holes.
My Bus is far away from where I am right now, so I could really need some help with measurements. I need to know how thick the hubs and the drums and discs are. That way, I can calculate if I can use the front original studs (rear is a no go), or if I need to buy new studs for all four wheels. I'll also know the length needed when buying new studs.
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Tue Sep 06, 2016 8:46 pm Post subject: Re: Late bay: thickness of hub and drum/disc |
Hi and WELCOME.
I believe this has been covered in the Bay section. I recall someone using long 12mm studs that replaced the VW 14mm hardware.
Bill |
GuruX Samba Member
Posted: Wed Sep 07, 2016 1:41 am Post subject: Re: Late bay: thickness of hub and drum/disc |
Thanks rockerarm!
I found some 70 mm long studs for a decent price, so I ended up ordering them. I'll take the hacksaw if they are way too long. I bought them from a Swedish site, but I guess they can be found around the world. They are from Studdard and the article no is NLA-331-671-01
http://dalhems.com/sv/p/e2aa933d28864ddb9331a57d010c8421/hjulbult-M14x15-70mm-lang _________________ #ecobus
My project on Youtube.
And on Facebook
And Instagram |
elpres Samba Member
Posted: Mon Sep 26, 2016 10:09 am Post subject: Re: Late bay: thickness of hub and drum/disc |
How did you get the studs in? Any pointers? |
GuruX Samba Member
Posted: Mon Sep 26, 2016 11:11 am Post subject: Re: Late bay: thickness of hub and drum/disc |
Turns out the studs wasn't as cheap as I thought. The price was for one stud, even though the page said the price was for ten. They wanted to send me nine more for no charge, but I declined, thought it was too generous. I'm happy enough with a refund.
But I started transferring the studs from the front hub to the back hub. First heated the front hub, then cooled the stud with ice water. The stud popped out with a hammer.
I put the loose stud in the freezer, heated the rear hub and then was really quick to the get the stud out of the freezer into the hub. I used quite a lot of washers and the wheel nut to pull the stud into the hub. _________________ #ecobus
And on Facebook
And Instagram |
elpres Samba Member
Posted: Mon Sep 26, 2016 11:46 am Post subject: Re: Late bay: thickness of hub and drum/disc |
Aktually i have the same Mercedes rims as you. Thinking they would look good on my 75 DOKA. So just to be sure what your doing. You are Mowing the front studs to the rear drums, because they are longer. And Then you need to find some long 14mm/70mm studs that dont cost 135 skr each. |
GuruX Samba Member
Posted: Mon Sep 26, 2016 1:12 pm Post subject: Re: Late bay: thickness of hub and drum/disc |
Yes elpres. That's right. Longer studs from the front moved to the back and I'm most likely getting 65mm studs for the front. The new ones I have found are 38 skr each, so that's 380 skr for the front. I guess I'll get an extra as spare also.
http://www.classicvw.se/pinnbult-bromstrumma-t2-71...ts_id/3763 _________________ #ecobus
And on Facebook
And Instagram |
