Beetle body to floorpan washers
pig-pen
pig-pen is offline
PostPosted: Fri Aug 19, 2016 2:18 pm    Post subject: Beetle body to floorpan washers Reply with quote
quick question, is there a reason for the shape of the stock floorpan washers?
if I wanted to could I use a flat washer instead? or even an L profile rather than a U profile.
cheers
1954 L227 Type 113
1964 L31 Type 265
pig-pen
pig-pen is offline
PostPosted: Sat Aug 20, 2016 12:18 am    Post subject: Re: Beetle body to floorpan washers Reply with quote
or... does anyone have a source for these...
http://www.thesamba.com/vw/forum/viewtopic.php?t=557437
1954 L227 Type 113
1964 L31 Type 265
andk5591
andk5591 is offline
PostPosted: Sat Aug 20, 2016 5:52 pm    Post subject: Re: Beetle body to floorpan washers Reply with quote
I guess you could use flat washers. Would need to be something heavy and you will end up cutting flats into them anyway because things dont quite line up. Way more work than what a set costs CIP1 sells a set of 10 for $13. Seriously, if a flat washer was fine, VW would have used them.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
pig-pen
pig-pen is offline
PostPosted: Sat Aug 20, 2016 11:18 pm    Post subject: Re: Beetle body to floorpan washers Reply with quote
absolutely. of course they would... but I want to run a fuel line tucked up in the channel, so if I had an L section I can use pipe clips on the opposite side...
1954 L227 Type 113
1964 L31 Type 265
andk5591
andk5591 is offline
PostPosted: Sun Aug 21, 2016 6:29 am    Post subject: Re: Beetle body to floorpan washers Reply with quote
That makes sense - small lengths of angle bracket would be handy for that
