stubb1986 Samba Member
Joined: August 15, 2016 Posts: 32 Location: Wichita, KS
Posted: Sat Aug 20, 2016 9:16 pm Post subject: Cant get rear brake drum off 68 |
Trying to get the right rear drum off my bug to replace the shoes. Left side came off easy but the right side wont budge. It spins freely so the shoes arnt stuck. Cant find a puller that will work to pull it off. Been shooting penetrating fluid in the splines and tapping with a hammer. Also tried heating it up with a torch and pulling it. Im out of ideas. |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Sat Aug 20, 2016 9:27 pm Post subject: Re: Cant get rear brake drum off 68 |
If you pull on the drum while rotating it slightly does it bind up and stop spinning? |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Sun Aug 21, 2016 12:28 am Post subject: Re: Cant get rear brake drum off 68 |
You need to release the brake shoe barrels by turning the spindles through the adjuster port w/screwdriver. forget which way to turn but you will figure it out. |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun Aug 21, 2016 2:26 am Post subject: Re: Cant get rear brake drum off 68 |
I have one of these pullers and it worked very effectively for me. You may also need to get some extra long bolts to get it to fit if the lug nuts are too short.
https://youtu.be/PQQvFK4B6pY
Here are some other tricks:
https://youtu.be/y6jpNC6emOQ _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Sun Aug 21, 2016 3:59 am Post subject: Re: Cant get rear brake drum off 68 |
andrewvwclassic wrote: |
Definitely try this - if the brake drum has enough wear, you will have a ridge on the edge of the drum that snags the brake pads when you try to remove it. |
Posted: Sun Aug 21, 2016 6:47 am Post subject: Re: Cant get rear brake drum off 68 |
loosened the barrels all the way so there is a gap between the pad and drum. Still wont budge. Banged on it with a baby sledge still nothing |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Aug 21, 2016 6:52 am Post subject: Re: Cant get rear brake drum off 68 |
is the car movable with the tires on it? If so just put the tires on along with the castle nut loose and drive it back and forth to see if that will loosen it up. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sun Aug 21, 2016 6:59 am Post subject: Re: Cant get rear brake drum off 68 |
60ragtop wrote: |
is the car movable with the tires on it? If so just put the tires on along with the castle nut loose and drive it back and forth to see if that will loosen it up. |
Only brake i have at the moment is the E brake. car had no fluid in the system when i picked it up and im working to get all the brakes replaced then bleed the system. |
Posted: Sun Aug 21, 2016 7:59 am Post subject: Re: Cant get rear brake drum off 68 |
went out and tried popping the clutch in forwards and reverse after heating up the drum around the shaft and putting penetrating oil on again and were at the same spot. Tried shaking the car and wheel as well.. |
johnR Samba Member
Joined: August 25, 2009 Posts: 668 Location: Virginia
Posted: Sun Aug 21, 2016 8:12 am Post subject: Re: Cant get rear brake drum off 68 |
I had the same issue with one rear drum. I tried everything up to a 6-foot steel pipe extension on a 3/4" breaker bar and it wouldn't budge. After reading a few threads here I bought the infamous torque tool which loosened the bolt quickly and easily! Seriously! I was amazed how easily it loosened that nut! And the tool helps put the correct amount of torque on the nut when reinstalling too. |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun Aug 21, 2016 9:37 am Post subject: Re: Cant get rear brake drum off 68 |
Beat on the face of the drum where the studs are or on the tops? |
Posted: Sun Aug 21, 2016 9:58 am Post subject: Re: Cant get rear brake drum off 68 |
stubb1986 wrote: |
beat as hard as you can on the face...youre basically trying to shock loose the rust..even if you break the drum dont worry,you can break it enough to get behind it with a puller |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 21, 2016 10:01 am Post subject: Re: Cant get rear brake drum off 68 |
Phone your local rental tool shop and see if they have a drum puller.... _________________ In Stereo, Where Available! |
EVfun Samba Member
Posted: Sun Aug 21, 2016 10:02 am Post subject: Re: Cant get rear brake drum off 68 |
Try not beating on the axle. A '68 with a 4 speed is still a swingaxle car and while a replacement axle is pretty cheap, it's a lot of work to change it. _________________
Wildthings wrote: |
hotsam Samba Member
Joined: December 02, 2015 Posts: 366 Location: Ashburn, VA
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sun Aug 21, 2016 12:14 pm Post subject: Re: Cant get rear brake drum off 68 |
I use a chain
bolt the chain to the drum with with lugs
leave about 2-3 feet in between attachments
take a big HEAVY pipe or other handy heavyweight object
wrap or attach the chain around heavy object
now position object with slack chains near drum and pull away wildly
the shock when the chain tightens, and the heavy object being hurled away provides a massive shock slide hammer effect
a few good flailing efforts and it comes off or the car off the stands
increase inertial offerings as required
so much for bent trailing arms and rear wheel alignments, huh!
you are so busy saying you will get new brakes you assume the suggestion to back off the adjusters was nothing
many a time a ridge is made on the inner edge of the drum and it hangs up on the shoes until they are moved inward to a diameter lesser than the ridge
this brake adjustment stuff is so important
it needs to be done over and over again throughout the brake shoe replacement process and afterwards as regular maintenance. |
Posted: Mon Aug 22, 2016 7:34 am Post subject: Re: Cant get rear brake drum off 68 |
Tried everything suggested and more still can't get the damn thing off.
Going to try leaving it with the jack attached with pressure against the axle and keep spraying with kroil and see if it comes loose. |
johnR Samba Member
Posted: Mon Aug 22, 2016 8:04 am Post subject: Re: Cant get rear brake drum off 68 |
It would be interesting to see if the torque tool works after all those attempts. |
awreed Samba Member
Posted: Mon Aug 22, 2016 8:44 am Post subject: Re: Cant get rear brake drum off 68 |
johnR wrote: |
The torque multiplier tool is fantastic, but axle nut removal wasn't the problem.
What johnnypan said is what you gotta do. Enough perseverance and violence will eventually get it loose. Hopefully. Good luck. |
