davidpot53 Samba Member
Posted: Sun Aug 21, 2016 4:49 am Post subject: Beetle frame head replacement |
Hi Everyone
I have found a lot of good information on this forum and i am sure someone will be able to help me, having issue to align my new frame head, it's out by at least 10 mm while positioned in the same jig as the old one came out.
Brand IGP
i think i might end up cutting the good tunnel side of the old one and make the new one fit or find a second hand head which is pretty hard.
What are your though folks ?
Thanks |
BuggyFaron Samba Member
Joined: September 01, 2005 Posts: 441 Location: Canyon Lake, Texas
Posted: Sun Dec 04, 2016 9:23 am Post subject: Re: Beetle frame head replacement |
I'm having the very same problem, what did you end up doing? |
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Goshen Samba Member
Posted: Tue Apr 11, 2017 6:21 pm Post subject: Re: Beetle frame head replacement |
Chronological sequence ... No captions.
Measured the distance from the Shift lever cutout to the edge of the Frame head and I got 32.5"
I made all the markings and used the Sawzall to cut the bad rusty frame head off:
I secured the sides with two visegrips one for each side and made my first weld on top to secure it.
Marking the yellow tape as to where the plug welds will go.
Went to town on fusing the replacement frame head and the original tunnel.
Now to secure the Napoleon Hat
All done
Now to fill the underside where most of the rot was ..
_________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
