magdelyn Samba Member
Joined: March 24, 2008 Posts: 80 Location: San Francisco
Posted: Mon Aug 22, 2016 10:19 pm Post subject: What are these two holes on the heads? |
_________________ http://fauxwhore.com
1973 vw super beetle
1988 Jetta
2001 Jetta
1959 beetle, ragtop sunroof
1973 bus westfalia (presently owned)
1967 squareback custom (just bought 04/11/2015) |
ac78 Samba Member
Joined: March 18, 2008 Posts: 330 Location: Nashville
Posted: Mon Aug 22, 2016 10:30 pm Post subject: Re: What are these two holes on the heads? |
Left one is temp II sensor for fuel injection. The right is a tin screw but the tin has been cut around it. _________________ 78 Westy 2.0l hydr. FI
VW Campmobile
For people who believe a family's
car should be it's castle ! |
Posted: Tue Aug 23, 2016 4:21 am Post subject: Re: What are these two holes on the heads? |
ac78 wrote: |
Left one is temp II sensor for fuel injection. The right is a tin screw but the tin has been cut around it. |
Thanx bunches. Since I am using a carburetor, I assume that I have to put in a sensor, or otherwise plug it up?
Do you happen to know what size and thread pattern the hole is? Are those 1mm threads?
Looks like it's M10 x 1mm. _________________ http://fauxwhore.com
1988 Jetta
2001 Jetta
Posted: Tue Aug 23, 2016 4:47 am Post subject: Re: What are these two holes on the heads? |
You don't need to plug them but you do want to put fasteners in them to hold the tin tight against the head. The left one is a 10x1mm thread which you may find in a drawer at your local hardware. An old TSII sensor will work as well.
A standard M6 bolt with work for the right hole with a fender washer large enough to span the cutout in the tin. You may need to saw or grind off a bit of one edge of your washer to get clearance.
You need to find something to plug that big unused hole in your tin as well as it will waste a ton of cooling air if left open. |
Bleyseng Samba Member
Posted: Tue Aug 23, 2016 7:25 am Post subject: Re: What are these two holes on the heads? |
That big old hole is from a early oem temp sensor 2 location and you can buy the rubber piece that fits it. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 23, 2016 8:08 am Post subject: Re: What are these two holes on the heads? |
I wonder if an electrical knockout plug would fit there?, those rubber plugs die an early death from the heat, steel would last forever. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 23, 2016 12:07 pm Post subject: Re: What are these two holes on the heads? |
If I were to buy that sensor, like the one near the number three cylinder, could I convert it to use as a temperature gauge? _________________ http://fauxwhore.com
1988 Jetta
2001 Jetta
Posted: Tue Aug 23, 2016 2:04 pm Post subject: Re: What are these two holes on the heads? |
Not really, yes it would show a rough idea of the temperature of that part of the head, but it wouldn't react fast and may never show what's happening at the combustion chamber where the action happens. It was just to tell the computer when the engine was warmed up, it won't provide a second by second account of when potential damage may happen.
1/8" NPT pipe fittings (like plugs for example) are really close to M10X1.0 and will thread in as well. Or use the male end of an old brake line, they are the correct thread and have a stepped up area you could put a washer under. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 23, 2016 2:17 pm Post subject: Re: What are these two holes on the heads? |
Thanks again, everybody for the awesome insights. _________________ http://fauxwhore.com
1988 Jetta
2001 Jetta
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5409 Location: Holland, MI
Posted: Fri Aug 26, 2016 12:39 am Post subject: Re: What are these two holes on the heads? |
busdaddy wrote: |
I wonder if an electrical knockout plug would fit there?, those rubber plugs die an early death from the heat, steel would last forever. |
It works well. That's what I used to fill unused holes in my tin. Just got cheap off the shelf black nylon knockout covers from my local hardware store. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Hoody Samba Member
Posted: Fri Aug 26, 2016 1:00 am Post subject: Re: What are these two holes on the heads? |
Edit
Hoody Samba Member
Posted: Fri Aug 26, 2016 1:06 am Post subject: Re: What are these two holes on the heads? |
Or you could buy a correct stainless plug from Belmetric and not eff up the threads in your head. For very short money. Search drain plugs on their site. The Spanish heads have the temp sensor 2 hole drilled out on both sides. So you just need to plug the one side. Use copper anti seize on the plugged side. The head gets way to hot for rubber and the tin needs to be tight. The one you want uses a hex wench. It's the same thread pitch as the tempS2 with a wide head. If you can't locate it on their site. I can send you the link. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Aug 26, 2016 6:48 pm Post subject: Re: What are these two holes on the heads? |
At the very least plug them or else you'll have popping on high decel situations. Won't be detrimental but annoying. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
SGKent Samba Member
Posted: Fri Aug 26, 2016 6:52 pm Post subject: Re: What are these two holes on the heads? |
udidwht wrote: |
At the very least plug them or else you'll have popping on high decel situations. Won't be detrimental but annoying. |
the TsII hole is open on the back. It isn't internal. Just use anything that is 10mm x 1.0 or even stick some RTV in it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Aug 26, 2016 7:23 pm Post subject: Re: What are these two holes on the heads? |
SGKent wrote: |
udidwht wrote: |
the TsII hole is open on the back. It isn't internal. Just use anything that is 10mm x 1.0 or even stick some RTV in it. |
Have put several of the AMC heads on these engines and leaving them open (while not detrimental) will introduce under certain conditions 'popping under high decel'. Once plugged the popping ceases. The 10mmx1.0 bolts or RTV will work. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
SGKent Samba Member
Posted: Fri Aug 26, 2016 7:58 pm Post subject: Re: What are these two holes on the heads? |
udidwht wrote: |
SGKent wrote: |
udidwht wrote: |
Have put several of the AMC heads on these engines and leaving them open (while not detrimental) will introduce under certain conditions 'popping under high decel'. Once plugged the popping ceases. The 10mmx1.0 bolts or RTV will work. |
Maybe someone can correct me but I think that would be true if they were air injection holes which they are not. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Aug 26, 2016 10:41 pm Post subject: Re: What are these two holes on the heads? |
SGKent wrote: |
udidwht wrote: |
SGKent wrote: |
udidwht wrote: |
Maybe someone can correct me but I think that would be true if they were air injection holes which they are not. |
If they were air injection holes you would get the loud firing of an unmuffled exhaust plus lots of stink and heat in your engine compartment. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Aug 27, 2016 12:19 am Post subject: Re: What are these two holes on the heads? |
There are many that do not want to concede their mistakes when it comes to holes in their head"s _________________ V.W.owner since 1967 |
