Kizbo Samba Member
Posted: Tue Aug 23, 2016 7:19 am Post subject: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Forgive me if this has already been discussed before, I'm sure it's likely been brought up...as my search revealed other posts that have touched the tip of the topic anyways, but really hasn't been talked about in detail from what I can tell or currently find. I'm sure I'm not the first person to encounter this issue...I know that even though I run a set of carbs that are a little less common (dual Solex 34 pdsit), there are guys out there that run dual weber 34s and kadrons that are similar in some respects. Anyways, I thought I could at least bring up my experiences in an effort to further "perfect" my ride and lend some help to future searchers on the topic.
Before the story, here are my engine specs;
Engine - 1641
Cam - engle 110
Carburation - dual Solex 34 pdsit carbs (28 vent(s), 145 mains, 130 air, & 50 idles) - Carbs balanced and manifold is connected by tube
Heads - Stock dual port, stock valves (no porting that I'm aware of)
Ignition/Distributor - 009 static timed at 8 deg & flame thrower coil
Fuel - Stock fuel pump
Yesterday marked the 2nd journey out and about riding in my sand rail since putting it back together. My 1st journey, although enjoyable and for the most part successful, revealed some tuning issues and some sputtering on rougher terrain. Let me just interject here and say that where I ride is for the most part gravel, dirt and sand roads...and when the season is right, a Mississippi river sand bar. With that said, most of the terrain that I ride isn't as horrible as say a rocky mountain trail, but it has its share of potholes. One road in particular is unavoidable and is horrible! (and is where the majority of said sputter is mostly taking place)....it's nothing but reclaimed asphalt (huge chunks I might add) used to make a gravel road - Bump city!
After the 1st outing, I thought I might need to check the fuel pressure as I had read that Solex carbs don't like much above 2 psi. As I figured, the fuel pressure was up past 4 psi on the stock pump. So I installed a fuel pressure regulator and gauge and then regulated it down to 2 psi (as far as I could get it). This seemed to make a big difference on its own to the quality of the ride. It definitely felt as though it remedied any potential loading up that was previously going on.
So, when out on the 2nd outing this weekend, everything was running well (maybe except for the slightest hesitation at lower rpm - which is probably due to the cam). However, when I get to the road-from-hell, it wants to sputter like crazy unless I take it at a snails pace. I would like to hopefully remedy this or at least make it a little bit better if anyone had any ideas to share.
So here's my question(s);
1) Is this sputter more than likely a flooding condition (fuel slosh in the bowl), or is it possibly a form of cavitation?
2) Is there anything that has/can be done to help this (i.e. bowl vent extensions, lowering float)?
I know that traditionally a centermount is the way to go for offroad, but I'm hoping that I could at least clean-up this phenomenon a bit if possible. I have a couple other stockish engines I'll put a center mount on in the future, but for now I'd like to make it work...plus, I'd like to work towards licensing this baby for the road this winter, and I know that the current set-up will seemingly work for that nicely.
Any thoughts or suggestions are always great!...If not for my benefit anyways, it could help the guy doing the search on it tomorrow. Thanks. |
I Ride Sand Samba Member
Posted: Tue Aug 23, 2016 7:55 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Kizbo wrote: |
dustymojave Samba Member
Posted: Tue Aug 23, 2016 6:16 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Yup! Bowl vent extensions.
Center pivot" for offroad is purely a Holley 4 bbl carb deal. Has NO bearing on other carbs used on VWs, (and a Holley 4bbl is extremely rare on a VW). _________________ Richard
SoCalBajas Member
Kizbo Samba Member
Posted: Tue Aug 23, 2016 6:48 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
[quote="dustymojave"]Yup! Bowl vent extensions.
Ok, awesome! Sounds like a potential fix exist. So now let me ask...is this just as simple as attaching a fuel line for some length or is there a better way or art to making it work? Thanks |
Posted: Tue Aug 23, 2016 7:54 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Been a little while since I looked down the throat of those carbs. Refresh our memories with a pic or 2. _________________ Richard
SoCalBajas Member
Kizbo Samba Member
Posted: Wed Aug 24, 2016 7:32 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Ok so here's a quick look down into the carbs. I was in a hurry and forgot to get the dimension of the brass vent, but nevertheless here's a view of it. This is the dirtiest these carbs / buggy has been to this point - we've had a very unusually wet & muddy summer around here and just haven't had time to washer and clean her up.
I will say this too.... that little brass circle/plug with the hole in it just above the outlet pipe (vent jet maybe? - unsure of the terminology), I have noticed that it stays a little moist with fuel. Not sure if that maters or if it's significant by any means.
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Wed Aug 24, 2016 8:07 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Is there enough of the vent sticking out to even get a fuel line on there? If so, I bet one of those small spring clamps for lawn tractor fuel line might do the trick holding it in place... |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Wed Aug 24, 2016 9:13 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
PDSIT carbs with 4in of 1/4in fuel line. I replaced the brass pieces. Pulled them out, drilled out the 6mm hole in the top casting to .250in, pressed in a new 1/4in brass tube with a flared end, and slipped the fuel hose over the flaired end.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Kizbo Samba Member
Posted: Thu Aug 25, 2016 7:50 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
This is some good info, and thanks for the pics. Yeah, those darn vent tubes really don't have much extension into the carb barrel at all do they...looks like a modification is due. I compared the length of the vent tubes from these carbs with a 34 pict, and unless my perception is somewhat jaded (with respect to the top of float bowl to top of vent) it would appear that the 34 pict extends much further. I'm surprised that fuel would slosh that much to come out of the vent tube....but I guess much like when running with a coke in hand, it doesn't take much for it to spill all over you either.
I'll be sure to post any pics of modifications to the vents.
34 PICT
Now the 34 PDSIT
Posted: Fri Aug 26, 2016 3:33 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
The replacement brass tube needs to be a tight interference fit in the carb top.
It must not be a slip-in fit. If it is, it will slip out and fall down the throat, probably jamming the throttle wide open and then sucking it into a cylinder and doing damage there. It's amazing how much damage small brass pieces can do to aluminum pistons and heads in a moment. _________________ Richard
SoCalBajas Member
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Aug 26, 2016 7:26 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
I dont know those carbs, but doesnt a 145 main seem pretty damn big? I know on Kads, would run a 132 or 135 on that engine. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sat Aug 27, 2016 1:39 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Richard brings up a good point. You do need to make sure it is a tight fit. After pressing mine in, I also peened over the tube in the float bowl just for an extra measure of safety. Just took a flat chisel and gave the inside edge of the tube a couple good pops. To get the new tube back off you would probably have to drill it out. Stucker than stuck.
Worth doing though. The extra length and flared end helps keep the fuel hose nice and secure. _________________ 1800 Type 4 Berrien 295
Kizbo Samba Member
Posted: Sat Aug 27, 2016 9:01 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
andk5591 wrote: |
I dont know those carbs, but doesnt a 145 main seem pretty damn big? I know on Kads, would run a 132 or 135 on that engine. |
I originally purchased this engine with this set of carbs on them, prior to my rebuild. They were fairly new carbs, so I chose to keep them. When I did my research into these little guys I found that they came with 22 venturis and 130 mains....this was essentially a 1200-1300 set-up and unfortunately how they come in a carb kit. I'll honestly admit that jetting is probably one of my least knowledgeable areas of this hobby, so I sought help in this area. When dealing with this carb, a very reputable vendor sells and recommends going from that 22 vent to a 28, and moving the mains up to 145 in order to get this from a 1200 carb to 1600+.
When testing out the buggy at the rpm range that the mains kick in (2500-3000rpm+), it'll fly and with smooth operation...and while this probably isn't the best way of gauging jetting, I noted that the exhaust isn't too sooty afterward as well. So at least for the moment, I'm inclined to think that they're ok. I may eventually throw the something smaller in for experimentation purposes. I do plan on running the occasional stock class sand drag, so maybe a little rich would be a plus for the higher rpm range. |
Dark Earth Samba Member
Posted: Sat Aug 27, 2016 9:16 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Kizbo wrote: |
When testing out the buggy at the rpm range that the mains kick in (2500-3000rpm+), it'll fly and with smooth operation...and while this probably isn't the best way of gauging jetting, I noted that the exhaust isn't too sooty afterward as well. |
Another telltale sign is the porcelain on the spark plugs. Really black means too rich, really white means too lean, a slight tan color on the porcelain means you're right where you want to be. _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Sun Aug 28, 2016 10:05 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Factory in '72 had 137.5s on 26mm vents, so 145 on a 28mm vent is probably very close. _________________ 1800 Type 4 Berrien 295
Kizbo Samba Member
Posted: Mon Aug 29, 2016 6:33 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Vanapplebomb wrote: |
Worth doing though. The extra length and flared end helps keep the fuel hose nice and secure. |
Yeah, I'd say that's probably the way to go....thanks for the tips. I had also been thinking about ordering a "phenolic" spacer between the carb and manifold, considering that fuel puddles up in the bottom of the butterfly on shut-down...making it difficult to start up a few minutes later (have to floor it). So with that said, I went ahead and ordered the whole carb rebuild kit in order to get them. I'll just go in and replace gaskets and everything while I'm in there drilling and peening the new vent tube.
Richard, Thank you too for the tips as well. |
Posted: Mon Aug 29, 2016 7:25 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Phenolic spacers insulate the carb so they don't get too hot. Not sure what that has to do with your fuel pulling issue though. _________________ 1800 Type 4 Berrien 295
Posted: Mon Aug 29, 2016 3:15 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
Fuel puddling on the butterfly is what the idle shut-off solenoid on the 34 PICT-3 carb (golden canister at lower left of pic) is for. This puddling wastes fuel, can result in a fire, and can cause dieseling on shutdown.
I don't know if one could be adapted to the carbs you have though. _________________ Richard
SoCalBajas Member
Posted: Mon Aug 29, 2016 3:58 pm Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
...except that is for the air/fuel bypass below the throttle plate...but you are right about it cutting fuel to prevent run on. Still not sure what is up with fuel poolling on the throttle plate...
The only PDSIT carb to use the air bypass solenoid was the drivers side carb on dual carbed busses...and some dual carbed Opels. It cut air/fuel to the central idle circuit.
The type 3 PDSIT carbs and bus PDSIT carbs all had a pilot jet cut off on each carb to cut fuel supply to the progression drilling a in the throttle body...I still doubt this is your issue though. It shouldn't be pooling on top the throttle plate even though some drilling a are above. Vacuum on the lowest drilling should keep anything from comming out the upper drillings...You could replace the pilot jet with one of the pilot cut off solenoids to cut fuel at shut down and see if that is the issue. Most were 55s, but there were some 52.5s as well. They are probably close enough for this application. I don't think you will notice much of a difference at idle.
How much fuel is pooling? _________________ 1800 Type 4 Berrien 295
Kizbo Samba Member
Posted: Tue Aug 30, 2016 11:19 am Post subject: Re: Dual 1bbl Carbs Occaisional Sputter On Rough Roads - Fuel Slosh? |
You may be absolutely right in thinking that the puddling is not directly related to the carb's heat. My original thought was that it "might" be related due to a couple of internet searches that described the Weber 34s having a similar problem that was resolved with a phenolic spacer....that and some information that claimed that the PDSIT carbs came from the factory (mostly) with a spacer to reduce a boiling effect out of the vent, which I guess wouldn't be an issue when I do the venting upgrade providing that it's actually happening in the first place.
As far as how much it's puddling... it's really not too much, although I do notice a little bit more in the drivers side carb as opposed to the passanger side. It's hard to describe the volume of fuel without a picture, but maybe it's somewhere around level with the top of the throttle plate shaft. I only noticed this when I had the air cleaners off to sync the carbs....during shut-down, when the engine was hot (as well as 95 deg outdoors), I noticed a number of drips out of what the Germans call the "austrittsarm" (not labled below) that dumps the fuel from the main jet into the venturi. I call it the "outlet arm" as I'm unsure of the terminology.
What I thought "might" be happening was; since this outlet arm is at a lower level than the vent tube (as shown below), maybe the heat was causing any residual fuel in the arm/tube to boil and expand and as a result drip out of there before it could puke out of the vent tube? This however may not be the case at all and I (admittedly) probably lack a little understanding on some of the finer points of this carburetor. Thanks for the continued info.
