Dmfresh1 Samba Member
Joined: March 08, 2012 Posts: 14 Location: Loudoun County, VA
Posted: Tue Aug 23, 2016 7:43 am Post subject: '67 bug driver side brake light/turn signal reversed |
so, just messed with this for a while, all the wires are correct to the tail light assemblies, but, when i hit brake, the turn signal light is brake light. The running lights, turn signal, flashers are all correct, but the brake light lights where turn signal bulb is. Where do i even BEGIN to troubleshoot this? thanks in advance for any advice.
-DM |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Aug 23, 2016 8:05 am Post subject: Re: '67 bug driver side brake light/turn signal reversed |
Dmfresh1 wrote: |
-DM |
Nope. Something is either misconnected there or at the T3 connector in the engine compartment.
_________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
grandpa pete Samba Member
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Tue Aug 23, 2016 9:34 am Post subject: Re: '67 bug driver side brake light/turn signal reversed |
One way to troubleshoot when all else fails is to remove all bulbs in those circuits, then add them back one by one, and see which wire/bulb causes the problem when added. At least it narrows your search. |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Tue Aug 23, 2016 9:53 am Post subject: Re: '67 bug driver side brake light/turn signal reversed |
grandpa pete wrote: |
I remember a thread a while back where the elements IN the new bulb were crossed... |
Which has absolutely nothing to do with this situation, since the rear signals on a 67 use single filament bulbs.
Make sure that the wires have not been reversed at the T3 connector as mentioned above. |
Posted: Tue Aug 23, 2016 12:21 pm Post subject: Re: '67 bug driver side brake light/turn signal reversed |
thank you for all the replies, going to see about that T3 connector. It definitely seems like something is flipped.
-DM |
Posted: Tue Aug 23, 2016 2:14 pm Post subject: Re: '67 bug driver side brake light/turn signal reversed |
so, just went to connectors, and now the only thing that lights differnetly is the drivers side brake light. Top bulb illuminats when should be bottom. |
KTPhil Samba Member
Posted: Tue Aug 23, 2016 4:51 pm Post subject: Re: '67 bug driver side brake light/turn signal reversed |
Keep at the wiring, they are swapped still. |
