Alex Maldonado Samba Member
Posted: Tue Aug 23, 2016 3:48 pm Post subject: Turbo 1776 turbo build questions |
Hello! So I've got a tired old 1776 in my '69 bug I'm planning on rebuilding soon. I'm planning on turbo charging it and don't know exactly what parts I'll need to get the most longevity out of it. Also, I've got a relatively new set of webber 44 carbs that are too big for the engine as it is, but I'm wondering if they will perform better in turbo charged form given the more thirsty nature of turbo'd engines. Any and all input would be good. Thanks! |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Tue Aug 23, 2016 4:48 pm Post subject: Re: Turbo 1776 turbo build questions |
You might try posting this question in the performance/engines section. Those guys might have a few things to say.
Otherwise I'd contact someone at CB Performance. They have very knowledgeable mechanics who can direct you toward the correct parts for your build. |
hotsam Samba Member
Joined: December 02, 2015 Posts: 366 Location: Ashburn, VA
Posted: Tue Aug 23, 2016 4:49 pm Post subject: Re: Turbo 1776 turbo build questions |
Doing this with carbs would be tough, I'm guessing fuel injection + Megasquirt would be the way to go. _________________ 1968 Beetle |
Posted: Tue Aug 23, 2016 6:10 pm Post subject: Re: Turbo 1776 turbo build questions |
hotsam wrote: |
Doing this with carbs would be tough, I'm guessing fuel injection + Megasquirt would be the way to go. |
I've been really considering that, but I'm also trying to stay relatively inexpensive. I know the old saying about not being able to have cheap, fast, and reliable, but I want to see how close I can get. I'm not looking for crazy power, but i'm looking for some decent get up and go. I'm also hoping for a build that I could plausibly use for a daily driver. |
awreed Samba Member
Posted: Tue Aug 23, 2016 8:35 pm Post subject: Re: Turbo 1776 turbo build questions |
Alex Maldonado wrote: |
hotsam wrote: |
I've never touched turbos or even gone the FI route, but why couldn't you make a reliable 1776cc turbo engine? Conventional VW wisdom dictates that 1776 is arguably the best power to reliability size for a DD, and turbo charging can nearly double HP, so what the hell, right? Why not have your cake and eat it too? |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Tue Aug 23, 2016 10:57 pm Post subject: Re: Turbo 1776 turbo build questions |
I have a 1776cc Turbo in a 66 Bug...plenty of HP for me as a daily driver.
90,5 Pistons
041 heads
110 Cam
Weber DCOE 40 (Progressive jetting)
Rajay B25 Turbo
Stainless Exhaust
009 dist with elect ignition
12 lb flywheel
30mm oil pump
stock Early oil cooler connected to External Oil Filter (PH8A)
Bottom end was balanced when NEW but is now 20 some yrs old while I did replace the heads and rings recently......life goes on. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Wed Aug 24, 2016 6:37 am Post subject: Re: Turbo 1776 turbo build questions |
hotsam wrote: |
^This^
I just got my 1776T on the road a month ago. Super fun. I went the megasquirt, crank trigger, fuel injection route. Not having to change jets and being able to time your car with a mouse and keyboard is worth every penny the system cost. Sell the carbs if they are in good shape, and look into the megasquirt realm. The amount of knowledge you gain from doing the whole thing is awesome. You won't be sorry.
_________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Wed Aug 24, 2016 3:17 pm Post subject: Re: Turbo 1776 turbo build questions |
kangaboy wrote: |
hotsam wrote: |
^This^
What throttle body did you use? Looking to do the same setup for my 68 Sedan.
-Nick- |
