jaime.barriga Samba Member
Posted: Tue Aug 23, 2016 9:35 pm Post subject: Too much difference between Carbs |
Hello,
I have a 1600SP that was recently rebuilt with new dual Weber ICT 34, I set the carbs with 2 1/2 mixture and 1 1/2 for speed. Using a sync tool the Left carburator is 4.5 kg/h and the right carburetor is 2.5 kg/h, there is a lot of difference ,what could be the problem ? Could be something with the engine or only with the carbs ?
Altitude where i live : 8392 feet
Timing : 7° BTDC
Jets :
• Air Correction Jet: 2.1
• Emulsion Tube: F6
• Main Jet: 1.20
• Pump Jet: .50
• Idle Jet: .50 |
jason Samba Member
Posted: Wed Aug 24, 2016 8:26 am Post subject: Re: Too much difference between Carbs |
Adjust one side to match the other with the linkage disconnected. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Aug 24, 2016 8:41 am Post subject: Re: Too much difference between Carbs |
If you're not getting results easily with the carbs, test the engine's compression numbers. If it's a new engine , have you readjusted the valves after cam break-in? |
Agent47 Samba Member
Joined: April 22, 2016 Posts: 271 Location: Scott AFB
Posted: Wed Aug 24, 2016 12:43 pm Post subject: Re: Too much difference between Carbs |
Is the balance tube and linkage connected?
They need to be removed for initial setup up. You will need to plug the balance tube port until after the initial setup or you will have a massive vacuum leak. _________________
TDCTDI wrote: |
... The VW beetle is the cockroach of the automotive world, no matter how many are killed, there always seems to be 100s more lurking in all the cracks & crevices. |
Posted: Wed Aug 24, 2016 8:44 pm Post subject: Re: Too much difference between Carbs |
If i do that then the speed screw in the R carb is like 2 1/2 versus L carb 1 1/2 and i have "dieseling" problems
Not yet.
Quote: |
Is the balance tube and linkage connected? |
I did the set up with :
-Balance tune : connected
-Linkage : disconnected
Interesting i did not see in any guide that the balance tube should be disconnected for the set up.
Thanks for your answers. |
Posted: Thu Aug 25, 2016 3:38 am Post subject: Re: Too much difference between Carbs |
Ok, do your cam break in at 2500 rpm, then let it cool off (preferably overnight), then do the valve adjustment, cold, then try adjusting carbs/linkage/timing for idle.
And if there's any doubt, take a compression test, just the simple one, not the leak-down test (yet). It's best to know, not to waste time chasing false leads. |
Posted: Thu Aug 25, 2016 8:25 pm Post subject: Re: Too much difference between Carbs |
Ok, thanks. is it necessary to disconnect the Balance tube to set up the carbs ? |
Posted: Thu Aug 25, 2016 8:33 pm Post subject: Re: Too much difference between Carbs |
clamp the balance tube closed for syncing, but leave it open for setting idle mixture(s). _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Fri Aug 26, 2016 8:08 pm Post subject: Re: Too much difference between Carbs |
Ok, thanks John. |
