croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1107 Location: Western Washington State
Posted: Wed Aug 24, 2016 8:35 pm Post subject: New Spring Plates, New Bushings |
I recently purchased a pair of Empi adjustable spring plates from a known vender. I also purchased new bushings for the whole set up. I CANNOT get the spring plates on the new bushings, and the new bushings in the housings to bolt on the torsion bar covers and lift the spring plates onto the mountings to save my life! Suggestions? _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
modok Samba Member
Posted: Wed Aug 24, 2016 9:13 pm Post subject: Re: New Spring Plates, New Bushings |
use silicone grease to get the bushings to slide on the spring plate. Can be found in the plumbing isle, or, possibly in your bedroom? |
Posted: Wed Aug 24, 2016 9:55 pm Post subject: Re: New Spring Plates, New Bushings |
modok wrote: |
I tried some silicone lube (NOT from bedroom). Did not really help. The only way I can see to get this to go on is to buy a couple of long bolts to pull the cover onto the outer bushing to get it at least so that the splines get into contact with the spring plate so that I can raise the plate up to its mount... _________________ Please check my '67 sedan project progress!
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Wed Aug 24, 2016 10:04 pm Post subject: Re: New Spring Plates, New Bushings |
I did exactly that. I have the grey empi adjustable, and ended up using some slightly longer bolts, and little at a time tightening them down.
In the picture below is most likely what you have, I just painted mine black. I used the red polyurethane and greased them with the green waterproof grease.
_________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed Aug 24, 2016 10:43 pm Post subject: Re: New Spring Plates, New Bushings |
jpaull wrote: |
X2
I had to do the same and used spacers inside the torsion covers so they didn't crush. When I was finished I used a Dremel to cut the bolts from the back. I also used a lot of baby powder on the inner & outer bushings. _________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
Posted: Wed Aug 24, 2016 10:52 pm Post subject: Re: New Spring Plates, New Bushings |
56Cabrio wrote: |
jpaull wrote: |
X2
I had to do the same and used spacers inside the torsion covers so they didn't crush. When I was finished I used a Dremel to cut the bolts from the back. I also used a lot of baby powder on the inner & outer bushings. |
Wow. That all seems a bit extreme. I'm hoping I can just use the longer bolts, and grease on the bushing, to get it all "drawn in" so that I can use the appropriate tool, which I have, to raise the torsion bar to its mount. Then, remove the long bolts, remove the cover, and reinstall the cover with the stock bolts... _________________ Please check my '67 sedan project progress!
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Wed Aug 24, 2016 11:20 pm Post subject: Re: New Spring Plates, New Bushings |
Yes, a pair of longer bolts to get it started is all you should need, then replace them with standard bolts when done. VW recommended talcum (baby) powder to avoid squeaks (same for door rubber). |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Aug 25, 2016 4:47 am Post subject: Re: New Spring Plates, New Bushings |
Adjustable spring plates usually have larger inner diameter bushings that need to be used with them. Usually a 2 inch, and a 1 7/8 to accommodate the extra diameter of the adjustable portion. Did you get the adjustable spring plate specific bushings? If so, I've never seen them in rubber, so they are most likely urethane. Powder is used on stock rubber bushings, but urethane ones need urethane specific lubricant. If you don't have any, Summit Racing has it from Energy Suspension. Depending on what preload you are trying to achieve, most of the time the spring plate cap can be loosely bolted up before you preload the torsion bar. I've known many with urethane bushings to bolt the spring plate up without the torsion bar, and check for binding. Sometimes the edges of urethane bushings need to be trimmed/ground to fit in the irregularities of the cast torsion housing, or aftermarket caps to allow smooth movement of the spring plate. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Aug 25, 2016 11:28 am Post subject: Re: New Spring Plates, New Bushings |
britegreenVWSB wrote: |
56Cabrio wrote: |
jpaull wrote: |
X2
Wow. That all seems a bit extreme. I'm hoping I can just use the longer bolts, and grease on the bushing, to get it all "drawn in" so that I can use the appropriate tool, which I have, to raise the torsion bar to its mount. Then, remove the long bolts, remove the cover, and reinstall the cover with the stock bolts... |
Read this
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=20 _________________ F#CK CANCER
Make a donation
1963 Hard Top
mark tucker Samba Member
Posted: Fri Aug 26, 2016 8:44 am Post subject: Re: New Spring Plates, New Bushings |
you do know there are different size &disine bushings for diferent vehicles.... I get the small id ones and machine them to fit the way I want them to....I dont like the stickey greese/goo that comes with the bugpoop stuff. |
Posted: Fri Aug 26, 2016 11:45 am Post subject: Re: New Spring Plates, New Bushings |
Mark, I just got the OEM rubber ones for my vehicle. The ID of the inner bushing is a TIGHT fit on the spring plate. Once I get the bushing squeezed in the torsion housing it constantly wants to squish back out. I can BARELY get the spines of the spring plate to match up to the torsion bar splines. As soon as I take my hands off of it, after pushing it pretty hard, tapping it with a hand sledge, and grab the cover, place the cover over the outer bushing, it squeezes off the splines.
Also, I greased the bushings, not powdered them. I've read of both ways. Is greasing them "bad"? I tried the powder method, but there was NO WAY I was going to get the plate on the bushing without a more slippery surface. Used silicone spray, too, because that stuff is really slippery. _________________ Please check my '67 sedan project progress!
Posted: Fri Aug 26, 2016 4:04 pm Post subject: Re: New Spring Plates, New Bushings |
Also, I greased the bushings, not powdered them. I've read of both ways. Is greasing them "bad"? I tried the powder method, but there was NO WAY I was going to get the plate on the bushing without a more slippery surface. Used silicone spray, too, because that stuff is really slippery. |
OEM rubber bushings are most likely the cause of your problems. Stock spring plates are 1 7/8 diameter on the inside portion locating it in the bushing, and use a rubber bushing that has a 1 7/8 inner diameter. Empi's adjustable spring plates are 2 inch on the inside, and use a 2 inch bushing. Putting a stock rubber 1 7/8 bushing over a 2 inch spring plate section, the extra 1/8 inch has to go somewhere.
Greasing a stock rubber bushing with standard wheel bearing type grease will have it squeak once the grease has been worn off/squeezed out. Get the correct 2 inch urethane bushing, and use the correct sticky translucent lube that doesn't squeeze out. |
modok Samba Member
Posted: Fri Aug 26, 2016 6:21 pm Post subject: Re: New Spring Plates, New Bushings |
If the new spring plate is larger diameter, use a sanding drum (1.25 or 1.5 drum, in drill press) to make ID of the the rubber bushing an equal amount larger.
Urethane.....no thanks, but, some people think it's ok, which is fine. Some people like adjustable spring plates. Not me, I can adjust it right the first time Just kidding. You want to DROP it so ti looks cool for the car shows eh? |
Posted: Thu Sep 01, 2016 11:24 pm Post subject: Re: New Spring Plates, New Bushings |
modok wrote: |
Actually Modok, my car has a severe driver's side lean. All I'd really like to do is to drop the passenger side down to match the driver's side and I'll be coool. I'm thinking that maybe going to adjustable spring plates was,,, overkill. Although, as you said, getting a car "in the weeds" would endear the younger crowd. I, frankly, hate the look of a VW so slammed it looks like a pimp dominated <bleeeeeeep>. I do recognize the benefit of getting one's car slammed at such a car show event. I might even take a couple of trophies? And other things? Maybe?
RE. urethane bushings - The only two things I've heard is, "they're bad", and "there's nothing wrong with them". Would love to hear some objective, experiential ideas about them. _________________ Please check my '67 sedan project progress!
modok Samba Member
Posted: Thu Sep 01, 2016 11:45 pm Post subject: Re: New Spring Plates, New Bushings |
I just took the caps off my 60 and the rubber bushing just falls off.
Dam. Only been in there 2 years. good news, I did find the source of the clunk sound.
we should trade bushings
In my experience the urethane bushings don't stay snug any better than rubber, and they also squeak and transmit more noise. I've seen them have 1/8 of play from just sitting, car just sitting in a garage for a few years. That's really sad.
My old daily driver the rubber bushings lasted near a decade, but, it was a IRS rear, and quality varies ect ect. Yeah, quality varies.
The way it's supposed to work is the rubber stays stuck to the surfaces and just flexes for all small movements as the car goes down the road. You hit a big bump and it does slide, and makes a funny sound too but you usually don't notice because of all the other sounds the car makes.
Urethane doesn't have enough flex to do that. It's not a "bearing"
Good for some thing tho, things that flex but don't slide. Actually liking my urethane front bump stops. They are 15 years old, and blue. I think they used to be available in different colors
Setting the torsion bars gets easier with practice. I like the idea of the adjustable ones but then again simple is good. I'm looking tonight for where the play is causing this clunking, and at this time I'd rather not add any additional potential sources of play, but I would like these bushings to be tighter! |
Posted: Fri Sep 02, 2016 4:14 am Post subject: Re: New Spring Plates, New Bushings |
It took 22 years, and around 80k miles to finally show some play in one of my swaybar clamp bushings from Energy Suspension on my Super. The control arm bushings from that original set, installed in 91, are still in use. I have a set of their torsion grommets, but never got the chance to put them in yet. With Adjustable spring plates, you're kind of limited to Bugpack's Prothane, Empi, and Sway-A-Way for 2 inch urethane bushings. Energy Suspension was one of the pioneers in urethane, but they only make the stock replacement sizes. Rubber components have changed a lot within the last 15-20 years. Ever had a boot on a new tie rod/ball joint split on a few year old joint, regardless if it was Chinese, or German? Unless you're getting NOS rubber grommets from the 70's, what's to say your new Brazilian OEM VW, or their Chinese replacements aren't going to crumble in 5-10 years? |
jsturtlebuggy Samba Member
Posted: Fri Sep 02, 2016 7:42 am Post subject: Re: New Spring Plates, New Bushings |
I use the SACO/German Auto yellow spring plate grommets on both the SwayAway and Chinese copies adjustable spring plates.
Since the SACO yellow grommets biggest size is a 1-7/8in they have to be open up to 2in size. What I do is put them in the freezer for awhile, then chuck them up in the lathe and machine them out to size.
Freezing them makes them easier to machine.
Also I use Super Lube synthetic grease on them. There is very little noise from them.
I am also using the SACO/German Auto yellow IRS pivot bushings with the Super Lube. On one car, I do develop noise from the pivot bushings over a period of time, this is from suspension having 14in of wheel travel. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Sep 12, 2016 7:01 pm Post subject: Re: New Spring Plates, New Bushings |
UPDATE:
After some consideration I am seriously considering just using the stock spring plates with new rubber bushings, and just setting them at the height I want, which should be easy. Installing these Empi $100 Chinese adjustable spring plates has proven to be more trouble than it's worth. My car has (had) a bad driver's side lean. I have not touched the driver's side yet, so I'm thinking of just doing the one spline one way, one spline the other thing on the driver's side to lower it just a bit, measuring the angle with protractor, and setting the passenger side to the same measurement.
On that subject, is there a protractor that any of you would recommend for this job? I found a digital one on Harbor Freight's website for $35 that looks like it will do the trick. _________________ Please check my '67 sedan project progress!
