Stefanino Samba Member
Posted: Fri Aug 26, 2016 7:36 am Post subject: Keys |
I recently acquired a 73 thing. It has no keys. Any suggestions on how to get keys made? Thanks |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Fri Aug 26, 2016 9:25 am Post subject: Re: Keys |
If you don't want to pull the ignition, remove one or both of the locking door handles and the decklid lock and look for the code inside. If it matches the ignition you can have a key made very easily for everything.
I have used Gabe's Key in the past and was very happy with his work. Here is a link to his feedback page with his contact info: http://www.thesamba.com/vw/forum/viewtopic.php?t=54110&highlight=keys |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Fri Aug 26, 2016 12:26 pm Post subject: Re: Keys |
Guess I'm missing something here. If you want to confirm that the codes on the front door locks and the rear deck lid match the ignition, exactly how can you do this without disassembling the steering column and pulling the ignition switch to see the code on it? |
Posted: Fri Aug 26, 2016 4:14 pm Post subject: Re: Keys |
wbailey2112 wrote: |
The only way to make sure they match is to pull the ignition. If the doors both match along with the deck lid lock, I'm guessing you have a good shot that the ignition is the same also. Worst case, you spent $20 for a new key for your doors that doesn't match the ignition. |
