CAlex Samba Member
Joined: March 07, 2015 Posts: 100 Location: Orlando,Fl
Posted: Fri Aug 26, 2016 7:42 am Post subject: Seatbelts |
I have a '65 beetle,it has retractable seatbelts but one of them no longer retract,want to get new ones but i dont think 65 came with retractable 3 point seatbelt,i think that because the retractable part hits the side of my seat,question is,what kind of seatbelt did my 65 originally come with 3 point retractable or just 3 point non retractable..thanks |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Fri Aug 26, 2016 8:21 am Post subject: Re: Seatbelts |
your 65 would have came with no seat belt standard, non retractable lap belts as option.
who knows what aftermarket belts you have in there now... _________________ 67 bug x3
67 ghia
64 bug |
CAlex Samba Member
Posted: Fri Aug 26, 2016 9:34 am Post subject: Re: Seatbelts |
Oh ok,but it does have the threated wholes on the lower part of door frame and middle upper inside between rear side window and door,thats the weird part.you have any recommendation on wich seatbelt to put on? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Fri Aug 26, 2016 9:59 am Post subject: Re: Seatbelts |
There are many threads on this, including options for the outer floor mount. Sounds like you have that mounting point already drilled out, so I'd check using search and find the closest to your hole setup. Note the need for a thick reinforcement washer on either side. Find a good retractable 3-point inertial set. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Aug 29, 2016 7:50 am Post subject: Re: Seatbelts |
Go to eBay and search for "HUMVEE seat belts". Save you wallet some trauma. _________________ 1976 Westy
1966 Beetle |
