Caddyman3 Samba Member
Joined: November 17, 2010 Posts: 5 Location: Bend Oregon
Posted: Fri Aug 26, 2016 9:35 am Post subject: Rear brake conversion question. |
Has anyone out there upgraded there rear drum brakes on a MK1 to disc brakes without installing rear brake proportioning valves and lived to tell about it?. How necessary are the proportioning valves for safe road driving?
Also how necessary is it to upgrade the master cylinder to a larger bore and/or change the booster.
I'm upgrading a 1983 Caddy with rear disc parts from a MK2; 1989 Jetta Carat; Girling calipers |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Fri Aug 26, 2016 6:57 pm Post subject: Re: rear brake conversion question. |
IMO, the large drums on the rear of your caddy are better than discs, & you don't have an issue of figuring out how to make a parking brake cable. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Aug 26, 2016 8:33 pm Post subject: Re: rear brake conversion question. |
Discs are useless unless you are doing some serious track work. I had mkII drums which are the same as caddy drums (200mm) that I put on my Rabbit and towed the Scirroco race car, our mkIII Golf and my 4X8 utility trailer with. Franky, it needed bigger front brakes, as they do most of the stopping, with a load or not. And the fact that a caddy has little weight at the rear makes them even more unnecessary. But, Im sure this is just for looks.... |
crsmp5 Samba Member
Posted: Sat Aug 27, 2016 4:04 pm Post subject: Re: Rear brake conversion question. |
rear lock up, rotors turn blue.... in 94 when i did mine... added 16v rocco ones, problem solved... this was in a mk1 jetta, spring loaded prop valve stock...
i also feel it to be unbalanced with out 10.1" fronts.. got my brackets from a audi 4000 quattro as lots of them vs rocco in 94... same bracket
its only car i have ever done the swap on... and i was doing stupid youth stuff in it.. rest of my stiff i run the big rear drums... _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
