Gnasha Samba Member
Joined: July 12, 2016 Posts: 106 Location: Leicester England
Posted: Fri Aug 26, 2016 2:39 pm Post subject: Sway or not to sway |
It appears my Ghia used to have a sway bar judging by the one remaining rubber bush left attached.
I'm told I have a selecta-drop front end, I'm not sure if it is a narrowed or not.
Does this mean I don't need a sway bar OR should I replace it?
Thanks for replies. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Aug 26, 2016 2:45 pm Post subject: Re: Sway or not to sway |
Front sway bars were standard on ghia's but I am not sure what happens if the beam is narrowed. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Aug 26, 2016 3:53 pm Post subject: Re: Sway or not to sway |
At a minimum, I would install the stock 3/8" front sway bar or go with a larger 3/4" aftermarket front sway bar. It will help crosswind stability.
BTW, I doubt your front end is narrowed. By the time people started narrowing front ends, there were far better options for lowering than the Select A Drop. _________________ 1966 Karmann-Ghia convertible |
c21darrel Samba Member
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Gnasha Samba Member
Posted: Fri Aug 26, 2016 11:00 pm Post subject: Re: Sway or not to sway |
Thank you all for your feed back, very much appreciated. I'm going to purchase a new sway bar thanks to your advice. |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sat Aug 27, 2016 3:02 am Post subject: Re: Sway or not to sway |
Narrowed beams = narrowed sway bar and tie rods to match _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Sat Aug 27, 2016 7:10 am Post subject: Re: Sway or not to sway |
Unless you're a purist, I would go with the thicker sway bar, as it would help handling. Also, depending on the year of car/type of transaxle, I would add a camber compensator and quality tires as well. I bought some Vredesteins a couple of years ago and they hold well when I push my lowlight through the mountain curves where I live.
Here's my link comparing Vredesteins to Nankangs:
http://www.thesamba.com/vw/forum/viewtopic.php?t=595842&highlight=vredesteins
One thing I've heard about compensators is that they cause leakage from the transaxle side plates where the middle bracket mounts. To prevent this (I've never had leaks), before I mount the compensator into place I fit the bracket into place and see how tight the mounting ears are to the transaxle body. If there's any daylight between the ears and the side plates, the nuts might not be able to pull the side plate(s) firmly into place because one or more of the ears might be fighting the nuts. So, I bend the ears so that they fit firmly into place before mounting and tightening the nuts, preventing transaxle leaks.
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
