bergfan Samba Member
Joined: March 07, 2007 Posts: 150 Location: NewZealand
Posted: Fri Aug 26, 2016 10:35 pm Post subject: Dual Circuit M/C |
I understand there is a spacer needed to fit a dual m/c to a split bus ? has anyone got a pic and specs of whats needed....Cheers |
captcory Samba Member
Posted: Sat Aug 27, 2016 5:04 am Post subject: Re: Dual Circuit M/C |
a '67 master is dual circuit and doesn't need a spacer. _________________ Cory Cotherman |
olliehank47 Samba Member
Posted: Sat Aug 27, 2016 7:17 am Post subject: Re: Dual Circuit M/C |
captcory wrote: |
a '67 master is dual circuit and doesn't need a spacer. |
This^^.
The spacer is used when other than a 67 OEM master is used, usually due to the high cost of the OEM unit. If you are considering a conversion, many kits use a dual MC from a different year (typically 72-79) that requires a spacer to locate the reservoir cap directly under the hole in the floor.
Google, "VW bus dual circuit conversion" and you'll see lots of kits offered that show all the parts needed. |
henk Samba Member
Pacmanfever Samba Member
Posted: Sun Aug 28, 2016 7:29 pm Post subject: Re: Dual Circuit M/C |
I did a write up comparison with pictures of the low cost dual circuit master cylinder from AC Industries here: http://www.thesamba.com/vw/forum/viewtopic.php?p=7635207
It has performed flawlessly on our daily driver. |
Posted: Mon Aug 29, 2016 10:25 pm Post subject: Re: Dual Circuit M/C |
Was this disc brake conversion or stock drums ? |
Posted: Tue Aug 30, 2016 1:40 pm Post subject: Re: Dual Circuit M/C |
bergfan wrote: |
Stock drums on a 67 that already had a failing German dual circuit master cylinder. |
