Stephenmarklay Samba Member
Posted: Mon Aug 29, 2016 4:15 am Post subject: Tools: Screwdriver set |
My screwdriver drawer is full of mismatched, bent and ugly screwdrivers.
I would like a nice new set and wondered what is a good choice. Need to have tough shafts, comfortable and have a good tip that won’t bend, and importantly have good tolerances (true to size.) _________________ 1985 Westfalia. Project 2017. |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Mon Aug 29, 2016 5:59 am Post subject: Re: Tools: Screwdriver set |
I bought a Stanley diamond tip set at Lowes for less than $20.00 that I am happy with. I have some specialty drivers like a 22 inch #2 phillips snap-on that was purchased o long ago it has been replaced once and I forget what obscene amount I paid for it, but it is a goto tool. I also have a harbour fright 4 in 1 that I grab often for stuff around the house. It is kept in the upstairs toolbox. If the fastener presents any problem I take the time to go get the diamond tip. |
Terry Kay Banned
Posted: Mon Aug 29, 2016 7:00 am Post subject: Re: Tools: Screwdriver set |
I like snap-on screwdrivers.
They are infinitely guaranteed if you bust an end, and they have a hex on the shaft at the bottom of the handle, so if you need to get a stuck screw loose you can lean on it and use a box wrench on it to assist.
A racheting box wrench works great here. _________________ T.K. |
Posted: Mon Aug 29, 2016 7:04 am Post subject: Re: Tools: Screwdriver set |
Terry Kay wrote: |
they have a hex on the shaft at the bottom of the handle, so if you need to get a stuck screw loose you can lean on it and use a box wrench on it to assist. |
I thought you just got the acetelene torch out for stuck fasteners TK. Put some heat to it until it glows kind of stuff. |
ZanaEvyPapa Samba Member
Joined: July 31, 2010 Posts: 255 Location: Gainesville, FL
Paulbeard Samba Member
Posted: Mon Aug 29, 2016 7:23 am Post subject: Re: Tools: Screwdriver set |
I have a couple of square shaft ones as well in my collection of misfit toys tools and they are useful for the same reason: you can clamp a vise grip on them when needed. I think they're Craftsman. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Terry Kay Banned
Posted: Mon Aug 29, 2016 7:29 am Post subject: Re: Tools: Screwdriver set |
<<I thought you just got the acetelene torch out for stuck fasteners TK. Put some heat to it until it glows kind of stuff.
You are correct--but in certain instances that a torch can't be used.
If the ratcheting box wrench on the screwdriver, and a lot of leaning won't do it--I break out the impact driver--that will get the fastener out in an instant. _________________ T.K. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
physast Samba Member
Posted: Mon Aug 29, 2016 7:51 am Post subject: Re: Tools: Screwdriver set |
I have had luck (so far) with these craftsman screwdrivers. I have only owned them for a month, but no complaints so far.
http://www.sears.com/craftsman-extreme-grip-14-pie...ockType=G4 _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Aug 29, 2016 8:09 am Post subject: Re: Tools: Screwdriver set |
I'm still using my Craftsman set purchased almost 50 years ago. Of course each screwdriver has been replaced a few times through the years.
Pry bars, paint stirrers, chisels, even welded on to a battery post -- they are versatile tools.
They always let me swap for a new one - but if the tool has clearly been abused then I have my wife handle the exchange. They don't bother to quiz her on how she managed to melt the shaft or bend the tip into a pretzel. |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Mon Aug 29, 2016 8:15 am Post subject: Re: Tools: Screwdriver set |
I got these Milwaukee ones maybe 6 months ago. I'm pretty impressed so far. They say that they're "demolition grade" so I've taken that to mean that I can beat on them with a hammer or pipe wrench😈
https://www.milwaukeetool.ca/hand-tools/screwdrivers/48-22-2002
I've been changing a lot of my other hand tools over to Milwaukee as well. I picked up some insulated screwdrivers, vice grips, chanel locks, side cutters etc. I do hvac installations so I'm hard on my tools. No brand loyalty though. I do have a sweet dewalt adjustable wrench. _________________ 1978 CEII Get-away hightop |
Vanagon Nut Samba Member
Posted: Mon Aug 29, 2016 11:09 am Post subject: Re: Tools: Screwdriver set |
Re impact driver
I use my handheld impact driver all the time. Don't know if it technically qualifies as a screwdriver but it's a really useful tool to have.
Mine is a Lyle. Don't know how it would hold up under daily pro use but so far, no issues. It came with bits, drive head is 3/8" so it will accept sockets.
Neil _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Mon Aug 29, 2016 11:23 am Post subject: Re: Tools: Screwdriver set |
Stanley FatMax diamond tip set.
http://www.stanleytools.com/products/fatmax-tools/.../fmht62052
I use Lowes as they graciously give me a 10% veteran's discount. With the discount the Stanley set was $18.00.
I also will use Lowes for Irwin pliers (Vicegrip brand) just bought a set of slip joints with a box frame and push button adjustment which is similar to the Knipex Cobras at half the cost. Nice pliers. Prefer them to the old channel locks I had which are now delegated to the travel tool box. I also use Lowes for Dewalt bits and blades.
Harbour freight professional series are suprisingly good for their 8" diaganols and needle nose pliers, linesman and safety pliers. The locking pliers are decent for the price. Avoid the non professional series, they are junk. The slip joint pliers are cheaply made and designed.
Sears Craftsman Brand are made to their specs by whomever sears contracts with. At one time they were decent, although nothing special, manufactured by Cooper Industries and then by Danaher Corporation. The lifetime guarantee is paid for up front and they expect most will lose the tool or neglect to return it for warranty.
Problem with Snap-on returns is finding the snap-on truck to return them. If you purchased from one vendor somewhere else and do not have a relationship with the guy they do not like to do the return. |
Posted: Mon Aug 29, 2016 7:41 pm Post subject: Re: Tools: Screwdriver set |
Thanks for these ideas! I do like the thought of having a shaft can put a wrench on. _________________ 1985 Westfalia. Project 2017. |
tates1882 Samba Member
Joined: August 07, 2012 Posts: 275 Location: Southwest Idaho
Posted: Mon Aug 29, 2016 8:25 pm Post subject: Re: Tools: Screwdriver set |
Well as an electrician I've driven literally thousands of screws and fasteners, the pictque from above is descent but the tips rust and wear quickly then they are a pita to get in and out of the handle. The best brand I've found for comfort and longevity is wera, I use the screw sticks, ratchets and precision screw stick set all the time. The handle fits my hand nicely, I wear a large glove to give you an idea of my hand size. _________________ 88 Vanaru, ej22, naht |
ejimmi Samba Member
Posted: Mon Aug 29, 2016 8:36 pm Post subject: Re: Tools: Screwdriver set |
I have multiple sets of craftsman snap-on, and wiah. I always seem to grab for the wiah first, they just feel right.
amazon has an amazing deal on a 5 pack for $34
https://www.amazon.com/Wiha-30295-Screwdriver-Slot...NRDX119YCB
KC tools carries the bigger sets.
Edit: I do also have a big #4 philips Wera driver and agree they make top quality stuff too! |
Merian Samba Member
Posted: Mon Aug 29, 2016 9:37 pm Post subject: Re: Tools: Screwdriver set |
the critical thing is to get flat screwdrivers with cross-ground blades - Hazet was the best as of a few years ago - better than Snap-Off
I have several Snap-Offs, and a couple of Crapsman that are used as beaters, and then returned periodically. The Snappies last a long time but I had to get the guy to put new shafts on a couple years ago.
I have some tiny ones by Wiha - very nice; no experience with larger ones _________________ ....
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Aug 29, 2016 9:41 pm Post subject: Re: Tools: Screwdriver set |
This is the only full size one I have
The only one aside from a set of Wiha precision Torx and jewelers screwdrivers.
That and a large hammer will fix anything! _________________ This free advice is worth exactly what you paid for it.
Zundfolge1432 Samba Member
Posted: Tue Aug 30, 2016 6:26 am Post subject: Re: Tools: Screwdriver set |
Geez I'm shocked nobody is ready to hand over their money to their Chinese buddies at harbor freight. LOL. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Aug 30, 2016 7:42 am Post subject: Re: Tools: Screwdriver set |
Terry Kay wrote: |
A racheting box wrench works great here. |
It depends on which end you break, the plastic handle are not warranted. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
