jdub63 Samba Member
Posted: Mon Aug 29, 2016 7:33 am Post subject: Okrasa intakes vs Fan Shroud Fastener |
I'm still in the mock-up stage of my WW Okrasa build, but I've ran into a problem with the fan shroud bolts.
The inboard intake nuts has to be secured before the fan shroud is installed. Once the intakes are installed, I can't get the fan shroud bolts started into the cylinder tin. There's not enough space between the intake and the shroud.
Has anyone had/solved this problem?
thanks,
jdub
Homeresque Samba Member
Joined: November 11, 2013 Posts: 90 Location: Hippy-Dippy Fruitcake Land
Posted: Mon Aug 29, 2016 11:12 am Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
Instead of the usual sheet metal screws, I switched to the 10mm fan shroud bolts so you can get a wrench in there. Worked fine. _________________ "Do you see what happens Larry?!?!" |
jdub63 Samba Member
Posted: Mon Aug 29, 2016 2:05 pm Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
I should have put a ruler next to the intake for the picture, I think it's 2- 4mm clearance, so I can't get a bolt started, regardless of the head type.
Maybe I should just open the slot in the cylinder tins and have the bolt installed with a washer to slide over the tin, then tighten... |
mr_bill Samba Member
Joined: February 19, 2006 Posts: 1008 Location: City of Orange, CA
Posted: Mon Aug 29, 2016 4:18 pm Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
turn the bolt hole in the cyl. tin into a SLOT & shroud, with bolt will drop right in _________________ see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Mon Aug 29, 2016 4:40 pm Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
Two thoughts:
Follow Mr. Bill's suggestion or don't worry about it. With the generator strap tightened down, the shroud isn't moving.
A small hex head would work as well |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Mon Sep 05, 2016 7:46 am Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
Same challenge I had with mine! I lifted the fan shroud and the cylinder tin a bit so I could reach it. Make sure you don't have the other screws fastened, start with these! |
jdub63 Samba Member
Posted: Thu Sep 08, 2016 11:24 am Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
JeeWee wrote: |
That sounds like a good simple solution... Thanks.
jdub |
scvw Samba Member
Joined: September 02, 2006 Posts: 3544 Location: South Carolina
Posted: Thu Sep 08, 2016 3:25 pm Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
I opted for hex head bolts. The treads are pretty short but it all goes together well.
_________________ 58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
SOUTHERN INTEGRITY AIRCOOLERS
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775 |
56samba Samba Member
Posted: Wed Sep 14, 2016 12:44 am Post subject: Re: Okrasa intakes vs Fan Shroud Fastener |
scvw wrote: |
Agreed! I choosed the same method and after some attempts it worked.
Just make sure the threat of the bolt and the nut is working well |
