CAlex Samba Member
Joined: March 07, 2015 Posts: 100 Location: Orlando,Fl
Posted: Tue Aug 30, 2016 7:52 am Post subject: Wiper motor |
My wiper motor doesnt work on my '65 bug so i found a rebuilt one that im ready to hookup,but i was looking online on how to do the wiring and saw that someone put a resister between the motor and fusebox.is this a must or isit just a safety to prevent motor from burning out.my big is converted to 12v.thanks |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Aug 30, 2016 8:12 am Post subject: Re: Wiper motor |
Is the new motor 12 or 6 volt? 65 was originally 6 volt so that is why the resistor was installed _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
CAlex Samba Member
Posted: Tue Aug 30, 2016 9:16 am Post subject: Re: Wiper motor |
The new one is 12v, |
bluebus86 Banned
CAlex Samba Member
Posted: Tue Aug 30, 2016 9:33 am Post subject: Re: Wiper motor |
Thanks for the good onfo,also wich fuse should i hookup the power to,all the wiper wiring was disconnected when i got the car.tryed on the radio fuse spot but for some reason it doest go into the park position when i turn off wipers.does it make a difference? |
Posted: Tue Aug 30, 2016 9:51 am Post subject: Re: Wiper motor |
do the wiper blades just stop wherever you shut them off or do they stop in the same position each time? look at the wiring diagrams here where the wire should go but that has nothing to do with your problem _________________ Rick
tasb wrote: |
sb001 wrote: |
CAlex Samba Member
Posted: Fri Sep 02, 2016 12:55 pm Post subject: Re: Wiper motor |
I took a second look at the wiper diagram,saw that i had 2 wires in the wrong spots,switched them up and bingo.Now when i turn off the wiper button the wipers go back to its sitting possition.thanks bluebus86 & 60ragtop for the help. |
