Schnage Samba Member
Posted: Tue Aug 30, 2016 9:58 am Post subject: Bosch VJU4BR 8 vs. Ignitor |
Hello, now i have the Ignitor 2843N6, but it wont fit. When i build it in, the vaccum system cant work, because the ignitor ground plate blocked it. Has someone a ignitor in this bosch distri. it is a 6 Volt system...
Markus |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Aug 31, 2016 1:10 pm Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Hello Marcus, you're going to have to explain yourself a bit more clearly. I am a distributor rebuilder and have lots of cores of the above distributor but I do not understand what you mean by ignitor or vacuum gate. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Wed Aug 31, 2016 2:00 pm Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Shure, i have bought a Ignitor system part number 2843N6 who should replace the points. But it doesent fit to the distributor, when installed, the set blocks the adjustment of timing by vacuum...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Wed Aug 31, 2016 3:39 pm Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Sounds like when the Pertronix is mounted it locks the upper plate to the lower so the vacuum advance won't more the points.
I think "technically" there is no Pertronix that fits the VJU4BR8. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Aug 31, 2016 8:49 pm Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Thanks for clarifying and yes, my understanding is that Glenn is right. _________________ Roads Scholar &
Posted: Wed Aug 31, 2016 9:25 pm Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Hi Glenn, that is what i think too, it wont fit out of the box. The upper plate cant turn free, because the pertronix cut out for the small thing that holds upper and lower plate togehter ist too small.....i will send pictures maybe than it gets clear what i mean.....
Markus |
Posted: Sat Sep 03, 2016 10:50 am Post subject: Re: Bosch VJU4BR 8 vs. Ignitor |
Now it works, with some handwork, and thinking abaut ist, you can fit this ignitor to the VJU4BR 8 distributor. |
