pushkick Samba Member
Posted: Mon Sep 05, 2016 8:54 pm Post subject: fuel line replacement |
has anyone replaced the existing fuel lines from pump to engine with ss lines?
what about the return line? seems that with the new fuels this could be the only way to make the lines more reliable. any comments on pros and cons ? _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
sciroccojim Samba Member
Posted: Mon Sep 05, 2016 9:57 pm Post subject: Re: fuel line replacement |
I don't really think reliability is a concern as much as longevity. New rubber hose is relatively inexpensive and should be good for 15-20 years. Stainless hoses will have rubber internals and while the stainless sheath will help prevent damage to the outside, the hose will still degrade. And damage to the hoses doesn't seem to be an issue. _________________ 1987 Westy Camper |
Posted: Mon Sep 05, 2016 10:05 pm Post subject: Re: fuel line replacement |
i was thinking of using ss tubing instead of ss hose. this should solve many issues. forgot to specify what i was thinking of using. _________________ i see said the blind man to his deaf dog
Posted: Mon Sep 05, 2016 10:28 pm Post subject: Re: fuel line replacement |
I don't see why not, although you'll need at least two pieces of flexible hose (feed and return) as the motor rocking around in its mounts will eventually break metal lines.
And you should really put a flare or barb on each pressurized line end that joins up with flexible hose, in order to prevent the hose from popping off. _________________ 1987 Westy Camper |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Tue Sep 06, 2016 7:43 am Post subject: Re: fuel line replacement |
In theory, its a great idea.
In actuality, there are so many hurdles that it simply isn't worth the trouble.
How will the metal line fasten to the fuel pressure regulator?
How will the metal line fasten to the fuel rails?
Will you eliminate the rubber hose to each injector?
How will the connections to the fuel tank be made? The fuel pump? The fuel filer?
What about vibration and metal fatigue? Where will you brace the metal pipes? How often will they be braced?
I see metal pipes with a LOT of short hose connections at each end which effectively doubles the number of fuel clamps and possible leakage points.
My experience is that the hoses leak at the clamps, screw on or squeeze on.
Nice idea folks, move along...... Nothing to see here......
Ghia
Vanagon
Beetle
bluebus86 Banned
Posted: Tue Sep 06, 2016 8:14 am Post subject: Re: fuel line replacement |
use of lined hose made to resist todays government mandated gasoline is the solution.
so use 30R9 or equivelent lined hose. the liner is a fluoropolymer, a teflon like substance. this liner resists the new mandated fuels. the older 30R7 hose is not lined
also consider the trouble you may have integrating an all hard tubeing fuel line into the injectors, and regulator, and note they may be issues with vibrations that could lead to cracks or wear in the hard lines.
the real solution is the lined rubber hoses. as it is easy effective and inexpensive to do.
also do not forget the install fuel pressure rated hose on the regulator vacuum port and clamp both ends. if the regulator diaphram fails, high pressure fuel is shot into the vacuum hose, if that hose fails, fuel will be sprayed about. if the hose is good and not able to come off, the spilled fuel will be contained by the hose and it will be shot into the intake manifold, were it will harmlessly cause your motor to stall out, no fire risk!!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Tue Sep 06, 2016 8:32 am Post subject: Re: fuel line replacement |
Van-Cafe / GoWesty sell replacement kits for the plastic feed and return lines for $25 or so. That said they don't usually wear out, even after 30 years. _________________ 1986 Weekender "Birch" |
Posted: Thu Sep 08, 2016 2:00 pm Post subject: Re: fuel line replacement |
great points but the reason i was wanting to change to something like ss is because of the mouse issue of them and squirrels chewing on the lines. i dont think they would bother the metal. maybe i need some different hose protector material that may stop their chewing. lucky i havent had fire yet. last time #3 cylinder hose was chewed next to the fuel rail. squirted out over the tail pipe. i ran out of gas before i knew what happened. it could have been sabotage given the area i am staying. they tend to do that kind of thing around here just to make a point. if it had been #2 cylinder line would have been over the catalytic converter or header. and lucky they chewed on the direction toward the rear and not towards the front. second time in 5 years that i had a problem. seems like that vw should have run the lines somewhere if they leaked they would not cause a fire potential. maybe some ss shielding with a nylon inner sleeve. although the metal ss lines would far exceed any carb restrictions and future restrictions and probably never go bad at least from oxidation in a lifetime. metal coated with rubber sleeve for vibration issues and puncture holes sealing. _________________ i see said the blind man to his deaf dog
bluebus86 Banned
Posted: Thu Sep 08, 2016 2:06 pm Post subject: Re: fuel line replacement |
pushkick wrote: |
great points but the reason i was wanting to change to something like ss is because of the mouse issue of them and squirrels chewing on the lines. i dont think they would bother the metal. maybe i need some different hose protector material that may stop their chewing. lucky i havent had fire yet. last time #3 cylinder hose was chewed next to the fuel rail. squirted out over the tail pipe. i ran out of gas before i knew what happened. it could have been sabotage given the area i am staying. they tend to do that kind of thing around here just to make a point. if it had been #2 cylinder line would have been over the catalytic converter or header. and lucky they chewed on the direction toward the rear and not towards the front. second time in 5 years that i had a problem. seems like that vw should have run the lines somewhere if they leaked they would not cause a fire potential. maybe some ss shielding with a nylon inner sleeve. |
some metal,outer sleeving might help prevent mouse and squirel bites on the existing hoses. look online, you should be able to buy a rool of the stuff, metal braided sleeving is what to get.
good luck
ps or coat with a tobasco mixture, guarrenteed no returns for a second taste!!!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Sep 08, 2016 2:25 pm Post subject: Re: fuel line replacement |
technically if i was going to design such a fuel system i would have put pressure sensor control system in to maybe stop some issues when a leak happens. seems like there should be something like a gas safety shutoff like the system or system fuel pressure fault. maybe a safety pressure valve for high and low pressure band that would shut off pump and dump lines safely. also run the lines so there is minimal chance of puncture or long term failure problems causing problems with fire. _________________ i see said the blind man to his deaf dog
Sodo Samba Member
Joined: July 06, 2007 Posts: 9613 Location: Western WA
Posted: Thu Sep 08, 2016 3:24 pm Post subject: Re: fuel line replacement |
Fuel is not corrosive (enough) to metal, to warrant SS fuel lines. No other vehicles on the road require SS fuel lines, and there are a lot of other vehicles.
A good solution is to just do what the other vehicles do. Change the hoses to a more reliable hose, which is what all the other vehicles HAVE from the factory. And what everyone's doing to Vanagons now (hopefully). No additional benefit gained by SS lines. _________________
....KTMs, GasGas, SPOT mtb |
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
Posted: Thu Sep 08, 2016 4:01 pm Post subject: Re: fuel line replacement |
pushkick wrote: |
technically if i was going to design such a fuel system i would have put pressure sensor control system in to maybe stop some issues when a leak happens. seems like there should be something like a gas safety shutoff like the system or system fuel pressure fault. maybe a safety pressure valve for high and low pressure band that would shut off pump and dump lines safely. also run the lines so there is minimal chance of puncture or long term failure problems causing problems with fire. |
http://www.swagelok.com/en/product/Valves/Excess-Flow
Excess flow valve. _________________ 1986 Transporter Single Cab Syncro |
Posted: Thu Sep 08, 2016 5:26 pm Post subject: Re: fuel line replacement |
hey that excess flow valve is a good solution if it would work on fuel and at the pressures and flow rates of the fuel line. the reason for ss is the salt enviroment during winter months here in ohio also any coastal areas like florida have issue with corrosion of steel. not much price difference with steel vs ss tubing. i think i remember another thread where someone used steel tubing. i will have to search. but for now i think i will try the new hose and some of the hose shield with a ss hose shield over the existing hose and shield should keep those rubber and plastic eating critters away. i cant understand why they chew the lines. i am always finding empty nut shells on the engine block. i can understand the nut shells on the engine block because it is warm but why the fuel lines. it is not only tree rats but ground squirrel or chipmunks. _________________ i see said the blind man to his deaf dog
bluebus86 Banned
Posted: Thu Sep 08, 2016 5:43 pm Post subject: Re: fuel line replacement |
djkeev wrote: |
Did anyone read OP's response?
He is considering these metal lines because of mice and tree rat (squirrel) damage.
They eat his fuel lines.
Dave |
i did and replied that he should consider rubber hose with metal raid sleeving placed over it to deter animal damage, also consider tobasco sauce as a deterant. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Sep 08, 2016 6:02 pm Post subject: Re: fuel line replacement |
bluebus86 wrote: |
djkeev wrote: |
Dave |
i did and replied that he should consider rubber hose with metal raid sleeving placed over it to deter animal damage, also consider tobasco sauce as a deterant. |
Or stop using French fry oil for fuel!! _________________ 1986 Transporter Single Cab Syncro |
Posted: Mon Sep 12, 2016 8:49 pm Post subject: Re: fuel line replacement |
well after research of cost of fuel line (rubber) and protective abrasive hose sheath. in my case ss and silica (from mcmaster carr) it would be cheaper to use ss 5/16" tubing from fuel pump to pressure regulator. the issue with fittings on the end of the tube would resolve the leaking issues or roll a bead on the end of tube would be cheaper than fittings. although i think i will use gates 5/16" fuel injection j30r9 hose , i have tried this and it seems to hold at the pressures of the fuel system and is carb rated. i think i will use the protective hose sheath from mcmaster carr they have several silica and multiple ss . the one thing i have noticed is that the critters only chew on the hose that has cloth covering which was the old hose from previous fuel line change. while inspecting the fuel lines i noticed that they chewed the 12mm hose from tank to filter. it also had cloth covering. ss hose is way to expensive to even consider for this application. i have stopped using french fry oil to lubricate the hoses! _________________ i see said the blind man to his deaf dog
Merian Samba Member
Posted: Mon Sep 12, 2016 9:10 pm Post subject: Re: fuel line replacement |
solid tubes be pickin' up bad vibrations
it'll give them excitations
they pickin' up bad vibrations (Oom bop, bop, bad vibrations)
it's giving them excitations(Oom bop, bop, excitations)
Bad bad bad vibrations (Oom bop, bop)
It's giving them excitations(Oom bop, bop, excitations)
Bad bad bad vibrations vibrations (Oom bop, bop)
It's giving them excitations (Oom bop, bop, excitations)
Close your eyes
the flames are closer now
Softly smile, I know it must be designed
to avoid those bad vibrations
I smarter than an engineer
I really got no fear
Van Van burn vibrations! _________________ .... |
Posted: Tue Sep 13, 2016 4:15 pm Post subject: Re: fuel line replacement |
i replaced the fuel line with gates 30r14t2 fuel injection line(napa sells it) with a ss hose protector (mcmaster carr). the old line from pmp to pressure reg. was plastic 1/4" ID and 5/16" OD and they used the fuel injection hose and clamps to couple to pressure reg. and pmp. plastic line was used from pressure reg to tank return inlet with fuel inject hose for coupling. i didnt replace the return plastic line seems ok. the thing about the plastic line the ends didnt even have a bead on the end and they didnt leak i replaced due to the old fuel injection coupling . so i think next time i will replace the return line with ss tubing and the feed line to pressure reg. with ss tubing with couplings on each end. that way all i have to do is replace couplings the ss tubing should last forever. _________________ i see said the blind man to his deaf dog
kamzcab86 Samba Moderator
Posted: Tue Sep 13, 2016 5:16 pm Post subject: Re: fuel line replacement |
Sodo wrote: |
No other vehicles on the road require SS fuel lines, and there are a lot of other vehicles. |
Perhaps you meant new vehicles? Because any vehicle running K-Jetronic will have SS fuel lines and there are a lot of old K-Jetronic cars still running around (from VW to Ferrari):
While there are rubber connections, the majority of a CIS car's fuel lines are metal (thankfully).
With the Vanagons' lack of screw-on fuel fittings, SS lines would be a bit difficult. The SS fuel line sleeves are probably a good compromise. _________________ ~Kamz
2016 Golf GTI S
