jmranger Samba Member
Posted: Tue Sep 13, 2016 4:04 pm Post subject: Glue suggestion? |
Hello,
What glue would you suggest to reattach the vinyl/leatherette on the bottom of the passenger's side B-pillar (original fire extinguisher location)?
It's quite impossible now to do a good surface preparation on both the metal and the vinyl, and whatever I've tried (Lepage contact, 3M Super 77) turns to goo in hours or days, probably due to some kind of chemical reaction with prior glue.
What's next? Silicone?
Thanks,
JMR |
bluebus86 Banned
Posted: Tue Sep 13, 2016 4:58 pm Post subject: Re: Glue suggestion? |
exactly what I am dealing with. appliction of new adhesives have failed. what to remove the old adhesive with, without harming the material?
I have had no luck with any of the contact type adhesives, and I have tried several brands. it will hold tight for a short time, then peels back magically after a while, days or weeks later.
I think acetone might remove the glue, but it probably aint going to do the vinyl any good. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Tue Sep 13, 2016 5:44 pm Post subject: Re: Glue suggestion? |
the 3M professional adhesive in a spray can is the best. Spray both sides, let the carrier fladh off for about 30 seconds, then stick it to the surface and tape it there for amcouple of days. |
bluebus86 Banned
Posted: Tue Sep 13, 2016 6:44 pm Post subject: Re: Glue suggestion? |
tschroeder0 wrote: |
tried that, did not work, problem seems to be the old glue that cant be removed from the vinyl easily. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Tue Sep 13, 2016 6:54 pm Post subject: Re: Glue suggestion? |
Somebody mentioned in another post on another subject that Xylene was a good solvent for the adhesive VW used on the interior coverings. Though he mentioned that it worked best if the adhesive wasn't allowed to be exposed to to UV for too long as it seemed to have a hardening effect on it. Can be had at Lowe's. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
Terry Kay Banned
Posted: Tue Sep 13, 2016 6:56 pm Post subject: Re: Glue suggestion? |
Time to watch some television.
Catch the new (pretty ) Loc-Tite ad.
They got some stuff that will glue anything together that displaces moisture, and is bullet proof.
You'd never get that vinyl away from the metal again--ever--
Plus it's ballistic drying time.
El Permanento.
Home Depot has it. _________________ T.K.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Tue Sep 13, 2016 9:21 pm Post subject: Re: Glue suggestion? |
I'm interested in a solution as well. I've tried several things that all failed with reasonable prep - not perfect as I couldn't fully remove it. Including the 3M professional adhesive, etc. Automotive interior heat is rough on things. I will look into the TV stuff. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Wed Sep 14, 2016 4:13 am Post subject: Re: Glue suggestion? |
IdahoDoug wrote: |
I'm interested in a solution as well. I've tried several things that all failed with reasonable prep - not perfect as I couldn't fully remove it. Including the 3M professional adhesive, etc. Automotive interior heat is rough on things. I will look into the TV stuff. |
That's surprising 'cause the 3m stuff works really well. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Sep 14, 2016 8:04 am Post subject: Re: Glue suggestion? |
Doug: could you share a bit more on what you tried so far?
Despite the numerous adhesives on the market, I feel that they all boil down to very few different basic chemicals. We have to find one that doesn't react with the residues of the original glue, since we won't be able to get it all out of the fibers backing of the vinyl.
That's why I'm thinking silicone. From what I read on various manufacturer's website, it sticks to metal and is stable at high temperature. But having sprained an ankle yesterday, I truly deserve to be called an armchair mechanic for now.
http://www.loctiteproducts.com/p/cntct_silicone/ov...ealant.htm
http://www.gorillatough.com/gorilla-sealant
https://www.permatex.com/products/adhesives-sealan...e-sealant/ (site currently not responding, but google cache version is here). |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Wed Sep 28, 2016 1:26 pm Post subject: Re: Glue suggestion? |
Update...
I ended up asking 3M technical support, and quickly got an amazingly detailed reply:
Quote: |
Based on your description below it sounds like the issue is with the vinyl and not with the sheet metal.
There are plasticizer additives in vinyl that make it difficult to bond to over the long term, especially if exposed to direct sunlight. The glue turning to mush is a classic symptom of plasticizer migration. You need an adhesive that is plasticizer resistant.
The product that we suggest you trial would be our Rubber and Vinyl 80 Spray adhesive. This is formulated to tolerate the additives in vinyl. On the sheet metal side, I am assuming that it is painted. Please note that the surface should be clean and dry and any waxes should be cleaned off.
Please find more information on the product below. If you have any more questions, please let us know.
http://solutions.3m.com/wps/portal/3M/en_US/Adhesi...amp;rt=rud |
From there, the following links were enlightening for me:
https://en.wikipedia.org/wiki/Plasticizer
http://multimedia.3m.com/mws/media/682505O/3mtm-sprayable-adhesives.pdf
That glue seems almost impossible to find in Canada if you don't want to buy a case, but a local mom & pop tool shop just ordered one for me at a reasonable price from SCN. For US folks, it is listed on Amazon and Home Depot.
I didn't find glues from other manufacturers that are specified as plasticizer resistant. If you find some, please list them.
I should receive it next week. To be continued... |
Stephenmarklay Samba Member
Posted: Wed Sep 28, 2016 8:01 pm Post subject: Re: Glue suggestion? |
I’m feeling lucky that my 85 did not have material there. Just metal. _________________ 1985 Westfalia. Project 2017. |
Vanagator Samba Member
Joined: January 14, 2009 Posts: 230 Location: Cool lush mountains in Mexico
Posted: Thu Sep 29, 2016 5:38 pm Post subject: Re: Glue suggestion? |
Future glue is what you need....I found some at Big Lots. |
Westified Samba Member
Posted: Thu Sep 29, 2016 6:03 pm Post subject: Re: Glue suggestion? |
I used loctite vinyl, fabric and plastic adhesive with success for that spot. I did put a board that there with a clamp for several hours. It's still stuck after one year. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Terry Kay Banned
Posted: Thu Sep 29, 2016 9:16 pm Post subject: Re: Glue suggestion? |
Power Grab--
_________________ T.K. |
Posted: Thu Sep 29, 2016 11:56 pm Post subject: Re: Glue suggestion? |
JM,
Apologies for not checking in up there. I used a high end automotive contact cement, the 3M stuff and something else I can't recall. I once found a Vanagon in the u pull with a damaged headliner my color and cut out a big chunk. So, I had a tear or two here and there and glued carefully cut patches before I hosed the whole headliner down with an excellent vinyl dye. It looks really awesome - except where a couple patches let loose. Grrr. So if yours works, I will get those pieces cut from my big swatch for the corner of two windows where the issue happened and respray! Back to show-grade! Cough... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
