Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Fri Sep 23, 2016 2:34 pm Post subject: Retrovans 1952 Beetle find in South Africa |
Hi Guys,
Just wanted to share my find with you, as finding a Split Beetle in South Africa is becoming near impossible these days.
So here is the story so far....
As promised, I will post what I have right now,
As you can see, there is not much to see, but boy what a good looking project this is.
The rotten pan and body VIN numbers are correct and matching, and clearly a June 1952 build.
(guess who has rose coloured glasses on)
so here goes..........
With the incorrect tank, I have already placed an order for the right 1952 (pre Oct) tank
Also have placed order for 49-52 pan half's
and even as I have already got "a" pillars, have placed order for new ones as well.
Set of German rubbers
Round horn grills
Popes nose lenses
Dim/bright floor switch
door light switches, but no dome light fond yet.
So yes, its coming together, one day at a time.
Well not much news, but the parts are starting to come in.
Have got a few "replacement " Parts, but they still look good.......
Waiting for the "Hens Teeth" to come, as I managed to get some off The Samba, Will however wait till they here before announcing them.
The body will be collected just after George Show, then there should be more Photo"s for you Main Line addicts.
Till then
Herman
_________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc
Posted: Fri Sep 23, 2016 2:38 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
As time passes....
As most would know, my time is not my own at this time, with Consultant Work, Moving house and office, building new house, renovating new office, and trying to do projects one runs out of these few hours in a day.
This means, that to prevent the 1952 Beetle project from grinding to a halt, I have farmed-out the Body work, or should I say, the metal cut, bend, fit and re-weld to someone with more time and better equipped for the job.
No, the final prep and flatting will still be mine, and the body ready for paint will be done by me.
Then Paint and assembly..... again ME....
So here are some teasers to wet your pallet.......
Here we have an Hole'y 1952 Beetle pan with more hole and less pan.
As this is the correct pan for the car, we will have to fix it, and get it back to life....
and that has been done.....
"A" pillars are gone "west"as well, so they where cut and fitted.......
As some of you may remember, this will be a "Used" car, not a Trailer Queen, so the engine will be "Upped" a bit, and to load it in and out with ease, the back Valance has been made removable.
With all shouting at the same time...".Beetle engine is easy to take in and out.".. let me explain..
The split window had a much higher fitting engine, the box is held tight up to the body, so to get an 1600tp engine with twin carbs in is near impossible. Yes..Yes.. if you take off near all the satellite parts, it just slips in....but fully complete, its a drag.
OK so we will carry on with this reconstruction, and as I have more, I will post it.
Ok , so the work is going on.
The metal is being replaced where possible, and the other areas are being welded up, with new steel.
The Pope Now has a nose again, bit worse for wear, but a nose all the same.
The pan has just got to be cleaned up and smoothed out, to ready it for the epoxy coat coating.
The bumps are being leaded out, to reduce the use of filler, something the old 52 Beetles had little of.
The body is coming together nicely, so soon we will be having it back in PE for the paint prep work.
Thanks for looking.
Herman
Posted: Fri Sep 23, 2016 2:39 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Well the body work is coming on nicely now, and she is near ready to come home.
Will just be light bolt on of all the parts, so that It is easily striped here at home, to start flatting and readying the body for paint.
Will be removing the body off the pan, and building the car up from there.
OK, Here is "before and after"
Looks a bit different to when she was found.
Well, this is a start of a new beginning for her, and a joy to have a 1952 in a 1952, and one is as good as new.......
Now all I need is a good body shop for myself.
Thanks for looking.
Herman
Posted: Fri Sep 23, 2016 2:41 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Look what followed me home........
Yes the 1952 Split Beetle has returned from the metal workers up in Jhb.
OK, so here is the story so far..... :puterwork:
The Beetle was found in Pretoria on a farm, the Beetle was brought back to Buggers work shop, and the donor car was also dropped off at Buggers workshop.
Pierre then had his metal guys loose on the project, and in very little time, replaced all the rust, with good solid metal, not only from the donor car, but from time correct panels brought in from all over the world.
The work was well done and on budget, and best of all, on time. Thanks Pierre, super work, and thanks for the detail built into this project.
Now the body will be removed, and the pan completed and final painted, before the new pan seals are fitted, as well as the original bolts supplied by Impi, Thanks Armand.
Hope to have more pic's during the build as from now, lets see.
Sorry about the "Shadow Man", but he does seem to be having fun, and also likes the beetle, judging from the thumbs up.
Thanks for looking,
Herman
Posted: Fri Sep 23, 2016 2:44 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
OK so for you VW aircooled perverts.....
Here are some pic's of my new workshop and parts room.
Please excuse the mess, but we work here...
Been trying to find a panel beater to do my pan straightening......
but alas, non are willing to do it on short notice.
So the self sufficient in me decided that I too can do this.
With angle iron brackets, and 10 mm wall plug screws and drill, I bolted the two brackets to the floor, under the two axles.
With the pan on tripods, I strapped the 3 high points to the floor, and jacked up the low point.
Over jacking a bit at a time, I had the pan straight to the mm, and now I can complete the work without having to lick someones a$$ to do the pan.
Will post pic's tomorrow, as I did not have the Camera with me at the workshop.
Well till next time..
Herman
Posted: Fri Sep 23, 2016 2:46 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Well here you go, very crud, but effective.......
So here are the photo's of the handbrake system,
Here to I have a photo of the peddle stops for the split / oval system that is hard to come by, as no info is found on the web, or books.
These stops can now be adjusted forwards or back to set the required position of each peddle.
Just now still waiting for my new Gear Rod coupler, then I can close up the hole in the tunnel, and fit the body back on.
Herman
Posted: Fri Sep 23, 2016 2:50 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
If only life would not interfere, I could have it done by now........
So the body finally went back on, and the bolts where refitted and the wheels went back on.
Got the incorrect mudguards off, and fitted the re-worked 52 mudguards back on.
She is now ready to go to Paint.
Thanks for looking,
Herman[/quote]
Posted: Fri Sep 23, 2016 2:51 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
So the cats out the bag, the Split Beetle is wearing her new coat, and I think she looks a Million Dollars.
The Old Fugly did her thing, as Grand Madam, and A-Framed the split home safe and sound.
Here is a small taster of what she looks like,
Here we just collected here from the Painters, and as always the Boys at Paramount Body Works did an excellent job,
Richard, take a bow, as per the Fastback, that you also did, the Split will be a testimony of your excellent work.
So the trip went off well, and we got home just before dark, so a few pic's before putting her to bed........
Now the fun will begin, as a small boy in a candy store, sleep will elude me tonight.
Till next time, thanks for looking.
Herman
Posted: Fri Sep 23, 2016 2:52 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
We here she is today as you see her...
So as I am still waiting for the Wiring harness, which could still take weeks, I am getting the small things done.
Started with the Sound proofing, and YES the 1952 did not originally come out with sound proofing. but as said a number of times, this is not a trailer queen, but a daily driver.
So here we go, the Back seat area got 1st treatment.....
Here you see it all done,....
Now you do not .....
The engine fire wall also got the same treatment ...
So now we will do the back wheel humps and the doors.....
But in the mean time I had to hang them 1st, and get the hardware into the doors as well....
Well till next time
Herman
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Fri Sep 23, 2016 3:54 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
You're doing a fine job! My gosh, cutting out the center tunnel like you did- that's real precision work to patch in a good section. I fully understand your intent to save the chassis# stamping from the original pan.
Quote: |
The split window had a much higher fitting engine, the box is held tight up to the body, so to get an 1600tp engine with twin carbs in is near impossible. Yes..Yes.. if you take off near all the satellite parts, it just slips in....but fully complete, its a drag. |
You've probably noticed that it's not the engine that sits higher, but that the original H apron extends further up. This reduces the available space to pull a larger engine rearwards. You probably also know that if you have fresh-air style heater boxes on your 1600, the tops of the HB will not clear the underside edge of the firewall. Back in the late '80's I had a '56 sunroof Beetle with a 1300 and factory HB. Took me a while to figure out that the HB had to come off to enable the engine to slide rearwards. Still was a very tight fit. On my late '52 Zwitter in the early 90's, I was lucky that it had a later, 40-hp style apron. By that point it was easy to install the HB with the engine in place; key was to use a sideways-curved 13mm box-end wrench sold for carburetors, to get the upper exhaust nut on the RHS (near the starter) fitted. Chase the threads of your front exhaust studs with a M8x1.25 die before installing the engine, and apply anti-seize compound to them so that the nuts come off easily next time.
I see you located a '67 rear axle to have better highway ratios with your 1600 engine- good choice, if it has the 4.12:1 ratio like those '67 sold in the USA which had the 1500 engine.
Looking forward to more updates. |
aa390392 Samba Member
Posted: Fri Sep 23, 2016 6:09 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Love the tenacity you guys that purchase these car and totally get them road worthy and documenting the work being done, keep sharing its like a page burner novel.
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sat Sep 24, 2016 10:33 am Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Rome wrote: |
Thanks, Yes and I have also fitted a longer 4th gear, to give me an extra 6% on top gear.
she should run 120 kph at 4000rpm.
She will be sporting twin 34 ICT's Webers as well, so no slouch here.
With regard to engine fit, as you said, why battle if you can just take off the apron on engine change.
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1973 FT Hahn SP - Project 1776cc |
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Mon Sep 26, 2016 8:13 am Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Great resto/make it your's Retrovan! Also great colour! |
Basketcase Samba Member
Posted: Mon Sep 26, 2016 12:43 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
fantastic job bringing it back. _________________ '72 Karmann Ghia Coupe (the Boss's) |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sat Oct 01, 2016 1:50 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Thanks Guys,
Yes, thats right, makes a very affordable sound proofing without causing condensation build up under the normal carpet type sound proofing.
You can now fit the "under-veld" type on top of this, and it will not promote rust.
Well as you can see, I have added sound proofing to the back side panels as well as both doors, so the door now has a nice quality sound when closing.
Also made up some seat rails, as the pan sections for the replacement true 1952 did not have them on.
Thanks again Jaco, for letting me copy your old rails, Think I managed to get a very near perfect rail together.
Here are the parts before assembly......
And here is the driver side in place, fixed to the pan.....
Not very clear, but better photo's when I do the passengers seat.
Still waiting for the Harness from John Henry, so we will carry on with the small things till it gets here.
Still getting the window sashes as well, so you can see that this is a slow process to get all parts needed for such a project when you start with only a shell.
thanks for looking
Zvonimir1985 Samba Member
Joined: August 19, 2015 Posts: 135 Location: Zagreb, Croatia
Posted: Tue Oct 11, 2016 1:20 am Post subject: Re: Retrovans 1952 Beetle find in South Africa |
I was enjoying reading... _________________ Proud to be Croat! |
Posted: Tue Oct 11, 2016 10:47 am Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Thanks guys, will be going full blast after getting harness from John Henry.
Till then
Posted: Tue Oct 11, 2016 12:00 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
Great job....
question why does it soooo long to get the harness?
Seems like shipping has not kept up with new millennium?
Bureaucracy? Laws? Taxes?
Thanks
55 ragtop
56 delux sedan
56 Kabriolet |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Tue Oct 11, 2016 3:30 pm Post subject: Re: Retrovans 1952 Beetle find in South Africa |
We run a couple of web-sites selling goods around the world, and from our experiences, I can tell you that South Africa is notoriusly slow when it comes to processing things through their postal system. If our customers get their goods within 2 months, then that is good going. By comparison, from the UK, it generally only takes 5 days to reach even the outback in Austrailia.
Staff in South Africa have a long running dispute with the Post Office, and have been on strike at least once in the past year. Plus customers tell us that the system is basically bankrupt: http://www.bekkerinvestments.co.za/saa-suspends-delivery-of-south-african-post-office-mail/
Does that throw light on the delay subject? |
