ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Sep 23, 2016 8:25 pm Post subject: Hard Start Relay wiring - how did you do it? |
Back when I converted my 64 to 12 volt, I also installed a hard start relay to take the load off of the ignition switch.
I'm looking for how others installed their hard start relays where the wiring/relay is inside the car vs. mounted near the starter (exposed).
So, you have a hard start relay installed - where is the relay? How'd you run the wires? Pictures would be great! |
HenrikL Samba Member
Posted: Sat Sep 24, 2016 11:14 am Post subject: Re: Hard Start Relay wiring - how did you do it? |
Here is mine on the firewall. Not visible with the air cleaner in place.
Posted: Sat Sep 24, 2016 12:01 pm Post subject: Re: Hard Start Relay wiring - how did you do it? |
Thanks for posting - I would not have thought to mount it here but it seems like a good place - out of sight and not dangling over transmission. |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Sat Sep 24, 2016 1:07 pm Post subject: Re: Hard Start Relay wiring - how did you do it? |
Mine is under the back seat next to the battery. I will post pictures later _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
dkvmatt Samba Member
Joined: September 20, 2016 Posts: 32 Location: Western Australia
Posted: Sat Sep 24, 2016 3:07 pm Post subject: Re: Hard Start Relay wiring - how did you do it? |
Any one have a wiring diagram for this or can explain what wires go where? |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Sat Sep 24, 2016 3:47 pm Post subject: Re: Hard Start Relay wiring - how did you do it? |
Kept mine under the back seat, out of the elements. Wasn't finished wiring when I had taken the pic.. Ignition wire still needed ran.
_________________ Justin |
Posted: Sun Sep 25, 2016 12:11 pm Post subject: Re: Hard Start Relay wiring - how did you do it? |
ataraxia wrote: |
Yes, the firewall is a reasonably dry and clean place too. Maybe a bit hot. No need to modify any of the original wires and the only hole that must be drilled is the one to attach the relay itself. |
