SIX FOUR Samba Member
Posted: Tue Sep 27, 2016 8:02 pm Post subject: Newbie question |
Hey guys, new to VW's learning as I go. I have a 1600 dp in my 63 and my neighbor took it for a spin. He said he thinks it's running on 3 cylinders, sitting at idle he took the spark plug wire off the distributor to cylinder #3, and the car kept idling fine. My question is, now what? |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Tue Sep 27, 2016 9:07 pm Post subject: Re: Newbie question |
Thanks for your reply, it has points and condenser. Should I replace all the spark plugs or check and replace #3? |
wcfvw69 Samba Purist
Posted: Tue Sep 27, 2016 9:11 pm Post subject: Re: Newbie question |
Before throwing parts that it may or may not need, I'd do a quick compression test on number 3 cylinder. Have you pulled the valve cover off and make sure a push rod hasn't fallen off and the rockers are moving correctly? _________________ Contact me at [email protected]
The Samba member since 2004.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Sep 27, 2016 9:41 pm Post subject: Re: Newbie question |
Do the usual tune-up steps (valve adjustment, point gap, timing, gap spark plugs, check SP wire/connector resistance). Often this flushes out something that is amiss, but costs you nothing. |
