Blondylab Samba Member
Joined: September 28, 2016 Posts: 2 Location: Newfoundland, Canada
Posted: Wed Sep 28, 2016 11:17 am Post subject: Fuel problem 1979 bug fuel injection |
Hi, I have a 1979 VW Bug Convertable with Fuel Injection ( my wife's dream car and she is not happy at the moment ). I have a problem that I can't seem to figure out. The car starts and will idle all day with no problem. However, when driving the car after a few minutes it will lose power and shut off, just like it runs out of gas. The car then will not start, just like it's out of gas, but if I wait a few minutes it will start again, but it will do the same thing again within a short period of time. I've replaced the fuel filter, tried another fuel pump, replaced the gas tank, checked the double relay, and checked the fuel pressure at the cold start value ( 37 PSI )
Anybody got any suggestions as to what my problem might be ?
One thing I noticed from reading other posts here is that my fuel pump runs as soon as I turn the key, before the the starter is engaged.
Any help would be greatly appreciated. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Sep 28, 2016 11:28 am Post subject: Re: Fuel problem 1979 bug fuel injection |
That could be a fuel tank venting problem. Drive the car with the fuel cap removed and see what happens. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Sep 28, 2016 12:02 pm Post subject: Re: Fuel problem 1979 bug fuel injection |
Blondylab wrote: |
One thing I noticed from reading other posts here is that my fuel pump runs as soon as I turn the key, before the the starter is engaged.. |
That's not good, you have double relay or AFM issues, or some PO has been messing with the wiring back there.
As for the quitting bring a small squirt bottle of gas along and put a teaspoon full into the S boot through one of the hose fittings next time it dies (put hose back after squirting), if it tries to run you have fuel issues, if it's still dead start looking at the ignition system or ignition switch. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
trisuli Samba Member
Posted: Thu Sep 29, 2016 5:30 am Post subject: Re: Fuel problem 1979 bug fuel injection |
Sounds like fuel supply problem where there is just enough flow to idle. Could be a clogged fuel filter or as in my brother's case a cruded up fuel supply line. |
mergedown Samba Member
Joined: March 13, 2016 Posts: 299 Location: Columbus, OH
Posted: Thu Sep 29, 2016 7:34 am Post subject: Re: Fuel problem 1979 bug fuel injection |
trisuli wrote: |
Sounds right as I had a similar issue when I first purchased my bug. Idled fine, but would fluctuate from running fine while driving, to sputtering, to no power at all.
I had a combo of a kinked hose at the fuel pump as well as a filter filled with rust from the gas tank. As soon as I replaced the filter it ran great, but didn't take long to clog again due to the amount of rust in the tank. I flushed my tank and replaced the filter and it's been great since. _________________ 1978 Convertible Fuel Injected - Blue (originally white...wait...maybe red?) |
garyt Samba Member
Posted: Fri Sep 30, 2016 12:11 pm Post subject: Re: Fuel problem 1979 bug fuel injection |
I reckon vacuum leak so check air hoses and the s boot for holes,
Check flap in air intake is not stuck open a bit
look for any loose wires and bad earths |
Posted: Mon Oct 17, 2016 3:45 pm Post subject: Re: Fuel problem 1979 bug fuel injection |
Sorry for the delay in posting about my problem, but I've spent the last 3 weeks checking every componet of fuel & electrical system & dealing with some really strange stuff. I won't get into all the details here, but suffice it to say that when the engine started with the fuel pump unpluged and 2 spark plugs removed, I was quite surprised. Anyway, the problem I was having was due to the wire from the # 2 temp sensor not being fully pluged into the connection in the wiring harness. As a result, the Control Unit was not receiving the correct engine temp signal and was just dumping fuel into the engine.
Car is running fine now, but I would like to thank all those who replied to my post and if you ever run into problems with your fuel injection, make sure to check the temp sensor cause it can cause some major problems.
Thanks to all |
