Zundfolge1432 Samba Member
Posted: Wed Sep 28, 2016 4:02 pm Post subject: 34-4 PICT California |
Anybody have experience or thoughts on this carb? I've seen them a few times but its been awhile. This was a California only carb late 74? . I remember seeing the intake which was also unique using dual heat risers and associated tin, pretty rare stuff now. Thanks in advance.
wcfvw69 Samba Purist
Posted: Wed Sep 28, 2016 5:18 pm Post subject: Re: 34-4 PICT California |
Andy (glutamodo) seems to be the resident Solex guru on this site. As you mentioned, it's a 74' only carb for California. I bet that baby runs LEAN to say the least to meet Cali's smog regulations.
I'm going to be following this thread. It would be interesting to know more about that carb. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Sep 28, 2016 5:24 pm Post subject: Re: 34-4 PICT California |
http://www.thesamba.com/vw/forum/viewtopic.php?p=4397042
I was curious about this carb and found this excellent thread. _________________ Contact me at [email protected]
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Wed Sep 28, 2016 6:03 pm Post subject: Re: 34-4 PICT California |
If you read German, there's a DVG (the company that actually made these for VW) manual that discusses the PICT-4 series a bit, in theSamba archives:
http://www.thesamba.com/vw/archives/manuals/solex_30_34_german.php _________________ Andy T.
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Thu Sep 29, 2016 8:06 am Post subject: Re: 34-4 PICT California |
Hi. I actually like this carb. On the carb's left side was a temp valve that would reduce the accel pump output when warm. We used to put an o-ring from the carb rebuild kit in this valve's groove and this simply blocked the fuel from being diverted back into the float bowl. This allowed the same amount of gas available for the acceleration pump circuit when warm as it did when cold. It helped with the flatspot condition.
Bill |
vamram Samba Member
Posted: Thu Sep 29, 2016 8:55 am Post subject: Re: 34-4 PICT California |
I have one of these rebuilt by volkbitz. I like it and it got great mpg on my Miami road trip last year 35/gal during one 330+ mile stretch - but it idles kinda rough. I switched back to a bocar 34-3 that I've been very happy with for the last year. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Boble Samba Member
Joined: November 13, 2005 Posts: 744 Location: Oslo, Norway
Posted: Thu Sep 29, 2016 3:16 pm Post subject: Re: 34-4 PICT California |
Zundfolge1432 wrote: |
I like this carb, it's rare.Take good care of it - historical piece
The dual heat risers were another improvement that came with the latest carburator version cars. I think it was from 1975(?). Anyways, heats up the intakes faster. Good struff! |
Boble Samba Member
Posted: Thu Sep 29, 2016 3:25 pm Post subject: Re: 34-4 PICT California |
vamram wrote: |
I have one of these rebuilt by volkbitz. I like it and it got great mpg on my Miami road trip last year 35/gal during one 330+ mile stretch - but it idles kinda rough. I switched back to a bocar 34-3 that I've been very happy with for the last year. |
The idle circuit on the 34 PICT-4 is the same as 34 PICT-3. Idling is a challenge on these since it tends to run too lean. If it does not idle perfectly (mine didn't), I can recommend to do some tweeks:
- Plug the little hole on the throttle valve plate
- Increase the Idle Jet to .60
- Main Jet from 127.5 to 130 or higher
Remember to re-adjust the Bypass and Volume Control screws. Should work fine now if the rest of the engine is tuned right. |
Boble Samba Member
Posted: Thu Sep 29, 2016 3:36 pm Post subject: Re: 34-4 PICT California |
rockerarm wrote: |
Bill |
Sure, but then you disable the functions of the temperature compensated accelerator pump, which was an imrovement.
Correctly adjusted the 34-PICT 4 accelerator pump gives 1.9 ml at cold engine, 1.1 ml at warm = more correct fuel mixture.
The simpler 34-PICT 3 gives 0.16 ml at all temperatures, which may be a little too lean when cold, and a little too rich at warm engine.
My experience from playing with these carbs are that flat spot is better dealt with by increasing the Pilot (Idle) Jet to .60. |
airschooled Air-Schooled
Posted: Thu Sep 29, 2016 4:02 pm Post subject: Re: 34-4 PICT California |
I don't understand how some say any 34pict carb can "idle too lean." What is the idle mixture adjusting screw doing in this case? I'd really love to see a demonstration with an O2 meter hooked up to one of those engines in that case.
www.airschooled.com |
vamram Samba Member
Posted: Thu Sep 29, 2016 5:57 pm Post subject: Re: 34-4 PICT California |
Boble wrote: |
vamram wrote: |
Won't gas mileage suffer with those mods? And I'm using a DVDA distributor which requires the hole in the throttle plate. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Sep 29, 2016 6:07 pm Post subject: Re: 34-4 PICT California |
here's a recent thread, maybe he can supply more info
http://www.thesamba.com/vw/forum/viewtopic.php?t=641303&start=0 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 29, 2016 6:26 pm Post subject: Re: 34-4 PICT California |
vamram wrote: |
Boble wrote: |
vamram wrote: |
Won't gas mileage suffer with those mods? And I'm using a DVDA distributor which requires the hole in the throttle plate. |
I would think so, sounds like a band aid to cover loose throttle shaft bushings and improperly cleaned idle passages. I can make mine puff black smoke if I feel the need with stock jets and the hole in the plate. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Sep 29, 2016 6:30 pm Post subject: Re: 34-4 PICT California |
asiab3 wrote: |
Robbie |
Not to mention you can bump up the pilot jet for more fuel during idle. _________________ Contact me at [email protected]
Posted: Thu Sep 29, 2016 8:16 pm Post subject: Re: 34-4 PICT California |
wcfvw69 wrote: |
asiab3 wrote: |
Robbie |
Not to mention you can bump up the pilot jet for more fuel during idle. |
I showed up to a car recently where the owner was convinced that they had an oil pressure issue, (wanted to buy a pump,) electrical issue, (wanted to buy an alternator,) and a hesitation issue, (wanted to buy a carb.)
The mixture screw was fully seated and it was running so lean that the warm idle would bog down to about 350-400 rpm and light up both the idiot lights.
Sometimes all it takes is a little talk with the car. Ask it what it needs. Don't just blindly follow instructions without asking "why" you're doing what you're doing and "why" you're getting the results you are.
