dkvmatt Samba Member
Joined: September 20, 2016 Posts: 32 Location: Western Australia
Posted: Thu Sep 29, 2016 2:24 am Post subject: Auxiliary Gauges |
Just wondering what Gauges other then the standard tacho and speedo people are running and where they are placed? _________________ 1970 Volkswagen Notchback- Bunky |
Notch Samba Member
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Thu Sep 29, 2016 7:23 am Post subject: Re: Auxiliary Gauges |
I swapped my stock speedo out for Porsche 911. Then used a 911 fuel & oil level combo gauge to replace the stock fuel gauge and hooked the oil level up to a temp sender since they miraculously work on the same oHm scale. The stock clock is replaced by a VWO aftermarket 7K tack that was re-faced and re-bezeled with a Porsche bezel to match the others.
I then made a custom fiberglass mini-consol below the radio for 4 gauges. I'm currently running a WB AFR gauge, an oil pressure, CHT and a volt meter. I'd like to swap the volt meter (un-necessary IMHO, but I had it laying around) out for a boost gauge in the future.
It's all buried in my build thread about 1/3-1/2 way through it. _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Sep 29, 2016 7:48 am Post subject: Re: Auxiliary Gauges |
Wasn't there a thread for this? I seem to recall it had a lot of good ideas. _________________ 71 Elm Green FI A/T Squareback |
