easilydistracted Samba Member
Joined: January 08, 2016 Posts: 43 Location: Yorkshire, UK
Posted: Tue Oct 04, 2016 5:30 am Post subject: painting engine bits |
Hi, I'm wanting to paint my aircooler, more importantly, the twin carbs, manifolds, alternator etc... will i have to use any special kind of paint so it will last?
I guess I'll have to well clean them, then give them a once over with etch primer, then something that will take the heat?
I'd quite like to get this sort of effect:
can anyone advise the best way? _________________ It's about the going, not the showing. |
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Tue Oct 04, 2016 6:54 am Post subject: Re: painting engine bits |
yeah that looks nice, I like the subtle approach with the the satin finish..
you want a high temp engine enamel, clean, decrease, repeat... I like using dawn for a third wash rinse with scotchbrite.. _________________ BUS WANTED: 13 window BUS any year considered.. |
beetlenut Samba Member
Posted: Tue Oct 04, 2016 7:37 am Post subject: Re: painting engine bits |
Have your engine tins powder coated. They will look more professional and last much longer than just paint. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Tue Oct 04, 2016 8:30 am Post subject: Re: painting engine bits |
I was more worried about the alternator, manifold and carbs... would they powdercoat too? _________________ It's about the going, not the showing. |
Posted: Tue Oct 04, 2016 11:21 am Post subject: Re: painting engine bits |
easilydistracted wrote: |
I was more worried about the alternator, manifold and carbs... would they powdercoat too? |
They would just have to be heated to melt the powder coat. No more than what they usually see while running. Aluminum and probably magnesium, need a special primer for the powdercoat to adhere to properly. The only issue might be preparing the surface's of the carb and alternator for the powdercoat. That's usually done in a glass peening machine, like sand blasting but finer. You'd have to ensure no media gets into those, or take them apart and just powdercoat the bodies of them. _________________ scrapyards are for quitters
Wetstuff wrote: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Tue Oct 04, 2016 2:12 pm Post subject: Re: painting engine bits |
Powder paint is the way to go. Carbs and alternator will need to have the internals stripped. _________________ Glenn
Member #1009
#BlueSquare |
Joseph DR Samba Member
Posted: Sat Oct 15, 2016 1:51 am Post subject: Re: painting engine bits |
I'm having my manifolds ceramic coated. There is a satin black in for it as well:
http://www.cerakotehightemp.com/finishes/ _________________ 1964 Beetle |
