67ctbug Samba Member
Posted: Sat Oct 15, 2016 6:33 pm Post subject: Re: Floor Pans |
I've actually seen that thread, even posted in it . You say those are Brazilian pans, but they look like the WW pans. If they are the WW pans, I hope mine don't do that, because it will be the exact same set up. I'm going to a swap meet tomorrow, who wants to bet there are going to be NOS VWoA pans there for $100 each side. (No one, yea I didn't think so either) alright I'll order the pans soon. I have to get this done befor the snow. I don't have a garage. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Sun Oct 23, 2016 2:25 pm Post subject: Re: Floor Pans |
The Zito pans are fine. I have installed several sets of them. Most recently on my Super.
They fit fine. The WW pans are very nice too. Not sure they're nice enough to justify the price difference. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Sun Oct 23, 2016 2:48 pm Post subject: Re: Floor Pans |
I've actually decided to use what I've got here's my current progress.
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sun Oct 23, 2016 5:38 pm Post subject: Re: Floor Pans |
Something definitely wrong with your welding technique there ....way too much spatter ...not too sure of the cause, those with more experience could likely tell you. You should be grinding those welds down with an angle grinder grinding wheel, or flap disk to make sure you have enough adhesion ...and just clean it up. You need a weld every inch or so ....top and bottom. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sun Oct 23, 2016 5:56 pm Post subject: Re: Floor Pans |
Digger89L wrote: |
Something definitely wrong with your welding technique there ....way too much spatter ...not too sure of the cause, those with more experience could likely tell you. You should be grinding those welds down with an angle grinder grinding wheel, or flap disk to make sure you have enough adhesion ...and just clean it up. You need a weld every inch or so ....top and bottom. |
I know I have to grind them, don't worry, I had to leave though so I just primed it so it won't rust. My welder isn't good right now, it's burning holes everywhere. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Oct 23, 2016 8:15 pm Post subject: Re: Floor Pans |
Right ....sorry. Didn't mean to be 'looking over your shoulder' ....lol _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon Oct 24, 2016 6:05 am Post subject: Re: Floor Pans |
Here are a couple of suggestions to make the job easier for you:
Install the crossbraces onto the tunnel first. They will require some tweaking to get a good fit and it is harder to do with the floor pans attached. Tack them in place and hammer and bend until they fit well, then ...
Fit the floor pans. I have never done a floor pan install that didn't require some trimming. Fit the floor pans, adjust, trim, tweak until they fit flat without having to stand on them. Drill larger holes in your pans so you can weld to the heavier metal under the pans.
Now here is the part you may not like. Put the body onto the tacked on parts to make sure everything lines up correctly. Only after it all fits well do you start the final welding. And, you need to skip around a lot when welding. If you do all your welding in one area you will heat that area too much and cause things to warp and buckle and move around.
Check out this thread, second page, for how you want things to look. http://www.thesamba.com/vw/forum/viewtopic.php?t=544918 _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
beetlenut Samba Member
Posted: Mon Oct 24, 2016 7:47 am Post subject: Re: Floor Pans |
Q-Dog wrote: |
Check out this thread, second page, for how you want things to look. http://www.thesamba.com/vw/forum/viewtopic.php?t=544918 |
I would put the body on BEFORE tacking the pans. Bolt the pans loosely into the captive rocker panel nuts, and make sure you have good contact with the pans and the lip you're welding to (weight pressing down). Looks like you need to weld hotter. More melting, less spatter. Bigger holes in the pan will help with starting the weld pool on the lip metal below, which is thicker and will hold the heat. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Mon Oct 24, 2016 8:09 am Post subject: Re: Floor Pans |
I didn't use the Zito cross members. They were thin and I didn't like them. I drilled the spot welds out on the Zito pans and left the German members on the tunnel. Then rewelded the Zito pans to the German cross members. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Oct 24, 2016 8:16 am Post subject: Re: Floor Pans |
beetlenut wrote: |
Q-Dog wrote: |
I would put the body on BEFORE tacking the pans. Bolt the pans loosely into the captive rocker panel nuts, and make sure you have good contact with the pans and the lip you're welding to (weight pressing down). Looks like you need to weld hotter. More melting, less spatter. Bigger holes in the pan will help with starting the weld pool on the lip metal below, which is thicker and will hold the heat. |
Great suggestions and saved me from having to type it. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Oct 24, 2016 12:47 pm Post subject: Re: Floor Pans |
I tried welding them desperate from the cross member in the back, but it didn't work, but I think it would have if I had cut more metal off. The pans are alll trimmed, so firms that isn't an issue. I'll put the body on for the heater channels. The cross members in using are WW, mine were toast. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 24, 2016 3:15 pm Post subject: Re: Floor Pans |
That's what I did. Left that part of the German pan in. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Oct 24, 2016 4:11 pm Post subject: Re: Floor Pans |
Mine was worse than yours i think i have a picture.
they were both rusted terribly so i just replaced them. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 24, 2016 4:40 pm Post subject: Re: Floor Pans |
Turn the heat up on your welder. Way up. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Oct 24, 2016 5:42 pm Post subject: Re: Floor Pans |
swhitcomb wrote: |
Turn the heat up on your welder. Way up. |
I can't all I can do is wire speed.
Bought it for $35 on sale _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 24, 2016 5:53 pm Post subject: Re: Floor Pans |
Unfortunately, you get what you pay for. I'm assuming you already have it on MAX? Might try turning the wire feed down and holding the wire on the part to be welded longer? Not many options to choose from though. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Mon Oct 24, 2016 6:19 pm Post subject: Re: Floor Pans |
You bought the wrong welder then. Search for a good used mig welder. Get the biggest shielding gas tank you can afford. You'll thank me. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Oct 24, 2016 6:45 pm Post subject: Re: Floor Pans |
beetlenut wrote: |
Unfortunately, you get what you pay for. I'm assuming you already have it on MAX? Might try turning the wire feed down and holding the wire on the part to be welded longer? Not many options to choose from though. |
I think I have it on low because that's what it suggests. Might be on high. The get what you pay for part; I read in someone's signature once " the only cheap part of a VW is the driver", I guess that true for me. I saw a good deal and bought it. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 24, 2016 6:46 pm Post subject: Re: Floor Pans |
Also ....those weld-to surfaces are way too rusty to welding to. You have to polish them up with a flap disk or sandpaper or SOMETHING to get good contact. I'm taking this thread off my watch list .....too frustrating to follow.
Good luck with your project. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Mon Oct 24, 2016 7:08 pm Post subject: Re: Floor Pans |
What weld to surfaces? Those pictures aren't current. All of the surfaces I'm welding get hit with a 40 grit sanding disk on the grinder until they shine. I'm not trying to make this confusing, it's just this thread has literally exploded today in terms of responses for this topic. I keep getting suggestions, that I can't answer because I don't know at the moment. I'll take more pictures tomorrow. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
