InitialWesty Samba Member
Joined: August 18, 2014 Posts: 45 Location: United States
Posted: Thu Oct 13, 2016 3:27 pm Post subject: Vincent's Makeover Restoration/Re-Paint |
My van was gathering a few heavy rust spots so its time to repaint. Since I planned to pull the interior for sound deadening it seemed like as good as time as ever to also swap the color. I'll keep the color announcement a surprise for future posts.
My van is in pretty sound shape with limited dents and clean interior especially for 250k. While everything is out I'll be adding some new features including hot water shower, remove swivel seat, etc.
Where I need help is around selecting new headliner and vinyl materials. Looking to do something unique but I am certainly more of a mechanic than a interior designer.
Tips and comments welcome, I'll be keeping this updated with new photos.
As he sits before the strip
Bumper rust
Bubbles at the hookups
Empty face
No need for this hole
Fronts out
End of Day One
jimf909 Samba Member
Posted: Thu Oct 13, 2016 5:20 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Ooh, this is going to be fun!
Headliner? I'm selecting a headliner material for my high-top. One material near the top of my list is Veltex. It's a display fabric made by Velcro and it's designed to receive Velcro hook material. I've attached a 2' strip of Velcro hook and ripped it off many times and the material doesn't show any wear. Seattle Fabrics has used it as a display material and moved signs on it for years and it still looks reasonably good.
I don't have any experience of it in use as an actual headliner but I thought I'd mention it.
Scroll down to Velcro laminates...
http://www.velcro.com/business/products/converted-and-fabricated-products _________________ - Jim
Abscate wrote: |
Posted: Thu Oct 13, 2016 5:25 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
This is a crafty idea mate! |
Posted: Fri Oct 14, 2016 10:13 am Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Day 2: Cabinets are out
Almost an empty shell. Looks like this thing is going to the junkyard more than a paint job
Cut out the panel with a dremel under passenger seat for storage
Removed driver side swivel base, opening up more room for my aux battery accessories.
Posted: Sun Oct 16, 2016 12:41 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Got the Van dropped off at AJ Auto body in Emeryville, CA.
Day 2 the antenna hole is filled and front is sanded.
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Sun Oct 16, 2016 12:50 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Anxious to see how this turns out for you! I am in Oakland and will be needing some body/paint work done this winter and have been needing to start looking for a shop. Are you planning to still use your radio? If so, what are you doing for an antennae? _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
bluebus86 Banned
Posted: Sun Oct 16, 2016 1:14 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
the problem with paint used in Oakland and other nearby areas is that the laws have banned the good paints. Now you get water color paints with a clear coat, expect the clear coat to peel off shortly. Id drive the van to a place that uses the good stuff. probably better in the long run environmentally to have the good paint as it will last longer, negating the need for a future repaint.
good luck
PS I had to drive to Santa Cruz County to purchase good paint for a door repaint, they could not sell the good stuff in San Mateo, Santa Clara nor Alameda counties , Didn't even bother to check with San Francisco county. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
tangojeff Samba Member
Posted: Sun Oct 16, 2016 7:47 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
I wish good luck w this shop. I thought I had them interested in repairing some seam rust by the wheel well and repainting a sliding door to replace a bashed one.
"We'll get back to you by email w/ an estimate", I was promised After three unreturned phone calls, I gave up on them. Too bad as they had two We$tys that looked like they were getting thorough re-paint jobs |
Posted: Mon Oct 17, 2016 12:33 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Sides are almost done. Filled the exhaust hole for the old fridge. After long debate kept the hookup doors. Almost removed to reduce moisture from getting in but the ability to hookup in the future seemed likely. |
Posted: Mon Oct 17, 2016 12:35 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
tangojeff wrote: |
Yeah, I have to stay on top of them with multiple followups to get my quotes, but they have been very accommodating and know there stuff about Westys. I would recommend this shop so far. |
Posted: Mon Oct 17, 2016 12:39 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Sunday I recieved 1/8th ABS plastic from TAPS plastics to redo all door cards/panels. Flattened the old fiberboard cards and traced it out. Will be cutting with jigsaw and wrapping in new vinyl. Spent the night watching videos to do high/low vinyl designs and will be giving it a shot once the fabric is selected.
wynnep Samba Member
Joined: May 16, 2006 Posts: 174 Location: Winston Salem, NC
Posted: Mon Oct 17, 2016 1:07 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Van looks good for repaint. One stupid remark be careful when you cut your door panels. Make the line disappear. If you leave the line or part of the line the panel will be to big. I have done this when using a piece of metal as a template resulting in the cut piece being larger than the template. Hope you thought of this and I am just wasting words. |
Posted: Mon Oct 17, 2016 1:39 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
wynnep wrote: |
Yup, Thanks! The goal is to remove any material that is silver marker. I don't have to be too accurate on my cuts as long as I am inside the lines as I will be wrapping the panel. So minor imperfections wont be noticeable like if I was going unwrapped ABS. |
bluebus86 Banned
Posted: Mon Oct 17, 2016 4:49 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
InitialWesty wrote: |
wynnep wrote: |
imperfections in the panel can show thru the upolstery, make all edges as nice and straight , (or smooth in the case of curves) as possible. chamfer all the edges well so upolstery does not get cut by the edges that it is folded over.
pay attention to the material thickness also, best to make it as close to factory as possible in thickness for a good look _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Oct 18, 2016 12:01 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Exhaust Vent filled. Hookup areas repaired.
The van only had one spot rusted through, working on cutting it out now
Next is to remove all the seem sealer and replace |
Posted: Tue Oct 18, 2016 12:03 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
If anyone has a small cabinet door grey, please let me know.
I was able to find a brown one, which I can refinish with grey handle and laminate but I have been unable to find the surrounding seals. Anyone know?
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Tue Oct 18, 2016 6:21 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
My van was gathering a few heavy rust spots so its...
Remove the winshield. I bet you'll be shock of what you'll found under that rubber.
my2cents
nice work _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Tue Oct 18, 2016 7:44 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
I was wondering how long the "windshield is being left in?" issue was yet to be mentioned, too. I didn't see any specific rust in the pix, but if you are going to the extent you are, and not removing the windshield, there must be some reason you have not yet mentioned. Could be the first place you will see a blemish or bubble after you spend all that effort this time around. If it were me, that would be heartbreak.
pathao wrote: |
my2cents
nice work |
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Oct 18, 2016 8:41 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
Windshield has been left in to minimize dust inside the cabin. It will be pulled out soon. I also expect to find some rust underneath the seal. |
Posted: Tue Oct 18, 2016 9:47 pm Post subject: Re: Vincent's Makeover Restoration/Re-Paint |
You're after the holy grail. The best bet so far is to paint the door mounding.
Grey lateches are available for sale, as are hinges...sometimes. I've bought smaller doors off e-bay for silly prices to get parts. Grey fridge doors are as rare as hens teeth. There are threads here where people have had some success ordering from Europe but there's been disappointment in the color. Bulk orders have been placed, etc. I'm ready to pay $10/foot for grey door mounding (I have two doors that need it).
Threads:
Page three of this thread has some info plus paint advice:
http://www.thesamba.com/vw/forum/viewtopic.php?t=301170&postdays=0&postorder=asc&start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=626362
http://www.thesamba.com/vw/forum/viewtopic.php?t=528786
Something tells me if there was an easy way to sell this molding for profit that GW would be doing it. _________________ - Jim
Abscate wrote: |
