scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Oct 19, 2016 10:19 am Post subject: H30/31 carb on 1641cc hard to adjust |
1641cc dual port engine, rebuilt by me last year about 8k miles ago.
aftermarket stock heater boxes
header and bugpack muffler, about 1-3/8"?
H30/31 carb, 'rebuilt' with carb kit same time as engine build
Bosch/VW 205T vac-only distributor, rebuilt but not spec'd on a machine
The problem is I can't seem to lean the idle mixture out enough, and the idle speed (volume) doesn't have much of a range either. Sorry, I don't have a mixture meter so I don't know what it's actually doing, but as I tighten the mixture screw I hear the idle increase slightly and then the screw bottoms out. I am expecting RPM to increase as I lean the mixture, find where it leans to a miss, and then back the screw off to just rich of peak.. but I can't lean it that much.
Can anyone help me figure it out?
I put on a new aftermarket stock type bus muffler this spring and actually was able to get a little better adjustability, but now that I put my header/muffler back on, I'm having the same problem again with idle speed and mixture. If I remember correctly it's a 55 and a 60 idle jets.
It seems to run well at speed, I think I have a 120 main.
_________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Slow 1200 Samba Member
Posted: Thu Oct 20, 2016 4:35 am Post subject: Re: H30/31 carb on 1641cc hard to adjust |
how open is the throttle plate at idle? |
Posted: Thu Oct 20, 2016 7:40 am Post subject: Re: H30/31 carb on 1641cc hard to adjust |
The fast idle screw is set to spec but I haven't measured the gap at the plate. _________________ Robert in Memphis
Posted: Mon Oct 24, 2016 7:53 pm Post subject: Re: H30/31 carb on 1641cc hard to adjust |
Found it, my fuel level was set too high and the needle was intermittently sticking open or closed. Amazing what a difference a few mm of fuel makes! _________________ Robert in Memphis
Zundfolge1432 Samba Member
Posted: Tue Nov 01, 2016 4:30 pm Post subject: Re: H30/31 carb on 1641cc hard to adjust |
That yellow sticker on the coil is installed upside down, won't help how engine runs but. |
Posted: Tue Nov 01, 2016 5:05 pm Post subject: Re: H30/31 carb on 1641cc hard to adjust |
Lol, you're far from the first person to tell me! _________________ Robert in Memphis
