mikaelh Samba Member
Posted: Wed Oct 19, 2016 3:11 pm Post subject: max hp stock forged counterweighted crank? |
Hi
i got an original german made crankshaft wich is forged and welded counterweight on and wonder how much it it can handle?
69 mm stroke its made by bug pack 23 years ago. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Wed Oct 19, 2016 3:45 pm Post subject: Re: max hp stock forged counterweighted crank? |
I have used a stock non counterweighted crank in a 250 hp turbocharged engine with no problems. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Wed Oct 19, 2016 5:03 pm Post subject: Re: max hp stock forged counterweighted crank? |
2-4 hundred? Doesen't really matter, as long as it's more than all the other parts
At some level of HP and rpm the flywheel will come of, does that count? |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3460 Location: Paradise, Ca
Posted: Wed Oct 19, 2016 5:46 pm Post subject: Re: max hp stock forged counterweighted crank? |
mikaelh wrote: |
Hi
From Sweden? Ahhhhh Home of JPM Motorsports, they just had their Dyno day not to long ago.
Dust of that crank and run it! If your worried that our internet X-Ray Magnaflux vision is not trustworthy, you can always have JPM or some machine shop check it. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Thu Oct 20, 2016 12:00 am Post subject: Re: max hp stock forged counterweighted crank? |
seems i be on safe side=) i plan to rebuild a low hp street engine for my 1303s.
i will use my as21 case build a 1915 cc and use this crank and rebuilt original connecting rods and cb 44 heads.
winter and darkness come here now so now its more time to spend in my workshop. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Oct 20, 2016 3:32 am Post subject: Re: max hp stock forged counterweighted crank? |
Winter & Darkness We must be "Neighbors"? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Fri Oct 21, 2016 2:08 am Post subject: Re: max hp stock forged counterweighted crank? |
madmike wrote: |
Winter & Darkness We must be "Neighbors"? |
LOL.. It wont be long now, Mike! _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Fri Oct 21, 2016 9:42 am Post subject: Re: max hp stock forged counterweighted crank? |
Hej mikaelh (Hello mikaelh)
Another swede here.
I think you are safe with the welded counterweights on the forged crank.
Make sure to get the crank + flywheel + pulley balanced at a local engine shop.
I did that with my 2007 I finished late this summer, and there is almost no vibrations.
I also weighted the pistons and conrods to differ 0,7gr lightest/heaviest.
Going from a tired abused 1600 to a fresh 2007 is quite the experience..... |
mark tucker Samba Member
Posted: Fri Oct 21, 2016 9:50 am Post subject: Re: max hp stock forged counterweighted crank? |
IMHO if you want to know then you want hp. so sell it and get a 82-86 stroke crank that will make the power.unless your going to force feed it then it will also make power. but then I would still go with a new crank. but thets me... Im kinda stupid that way.. |
