therealbugthug Samba Member
Posted: Wed Oct 19, 2016 7:43 pm Post subject: 36hp stalling |
I have a 1955 beetle 36 hp. It is having an issue with the idle. I have cleaned the carb. Set the timing. Has new wires and runs good and idles fine at rest but when driving it will want to stall during deceleration. I will give it a bit of throttle and will idle again. Where to begin? |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Oct 19, 2016 8:18 pm Post subject: Re: 36hp stalling |
Is it only when cold or all the time?
Could be fuel pump/pressure at idle, carb float/valve |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Sat Oct 22, 2016 2:29 pm Post subject: Re: 36hp stalling |
I tried the idle adjustment several ways and the idle mixture screw just does not seem to have any affect on it. Maybe it is plugged somewhere? seem like only the throttle adjustment is allowing it to idle. I think I will do a better cleaning/rebuild and see if that helps. Also how would I test to see if fuel pump was weak?
I also have a question on the point gap. I have it set to spec and then checked dwell which is supposed to be 50 but it is about 30. If I adjust points to get dwell close to 50 the gap is way off. Which one should I keep? |
txoval Samba Member
Posted: Sat Oct 22, 2016 3:06 pm Post subject: Re: 36hp stalling |
Set dwell.
Will have to put (rig) a fuel pressure gauge to line to test it.
My experience (and others disagree or have other experiences), but once a port is clogged in an old carb, it's hard to clean out. I also run (prefer) a 30 pict 1 carb with 6V electric choke
EVfun Samba Member
Posted: Sat Oct 22, 2016 4:14 pm Post subject: Re: 36hp stalling |
Where did you get the 6 volt electric fuel pump? Does it need a pressure regulator? _________________
Wildthings wrote: |
txoval Samba Member
Posted: Sat Oct 22, 2016 8:41 pm Post subject: Re: 36hp stalling |
EVfun:
Summit racing: $30
https://www.summitracing.com/parts/atx-e8011?ibanner=MobileSwitchNo
I installed a regulator and set to 3psi. Unfortunately I do not know the unregulated pressure, but doubt it's much higher. I've been running the pump for 3 years and love it. Cleaner engine compartment and consistent pressure...the price helps too.
Nice Stock rebuilt units are over $250. I used the stock choke pull location to install the switch/cutout as well. Dash looks completely stock... |
