Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Oct 19, 2016 8:02 pm Post subject: Possible Stupid Newbie Question |
On a 1969 911T with worn suspension, is it possible to upgrade to the 1974-82 (or so) front Koni struts so that Koni Sport inserts can be used as well as larger brakes? I'd like to do it without having to change wheels.
Also- it appears that there's a break in ball joint part numbers around '72/3 or so. I'm assuming the later strut housings will work OK with the earlier ball joints... is this correct?
Any advice from someone who has done this would be appreciated. Thanks! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bleyseng Samba Member
Posted: Sat Oct 22, 2016 5:57 am Post subject: Re: Possible Stupid Newbie Question |
Yes, you should be able to. You might have to change the balljoint to the later style too. If the front suspension is worn install the Elephant replacement bearings on the A arms and toss the rubber crap. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
