Vw1600dellortoGR Samba Member
Posted: Fri Oct 21, 2016 4:26 pm Post subject: 1776 power estimate |
Hello,
I have an engine Combo in mind and I would like some input on the power output so that I can decide what else I need what clutch mostly ,
1776
German CW crank
Stock rebuilt rods
New case
044 panchitos
Mahle p&c
C25 cam |
modok Samba Member
Posted: Fri Oct 21, 2016 4:31 pm Post subject: Re: 1776 power estimate |
85-95 hp |
Posted: Fri Oct 21, 2016 4:32 pm Post subject: Re: 1776 power estimate |
Do you think it is a.good combo ? What would it need for more ; |
modok Samba Member
Posted: Fri Oct 21, 2016 4:37 pm Post subject: Re: 1776 power estimate |
The cam is very mild, so it doesn't really NEED heads that big.
a 1776 with those heads could run 7000rpm, but that's not necessarily a great idea to turn high RPMS for most uses, so IMO, what would do the most good is.....
more stroke! |
mark tucker Samba Member
Posted: Fri Oct 21, 2016 4:40 pm Post subject: Re: 1776 power estimate |
modok wrote: |
more stroke! |
yup change stroke.and get some good rods too. no reason to leave good power at the store when your spending this kind of cash looking for more power. |
gt1953 Samba Member
Posted: Fri Oct 21, 2016 4:42 pm Post subject: Re: 1776 power estimate |
What is the carb gonna be?
My 1776cc, C-25 cam, 40X35.5 valved heads, 1.4 ratio rockers, dual kadron carbs. Dyno sheet says 78 hp to the ground. Plenty of giddy up for me in a 68 type 1. Oh that is at 6500 feet above the sea, lower it would be more for sure. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Fri Oct 21, 2016 4:47 pm Post subject: Re: 1776 power estimate |
Use stock heads, single springs, 48cc chamber. Ditch the bigger heads. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Fri Oct 21, 2016 5:01 pm Post subject: Re: 1776 power estimate |
The expected output is 0hp since it has no carb(s) or exhaust. What vehicle is it going in? _________________ 1965 Beetle sedan
Click to view image |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri Oct 21, 2016 6:06 pm Post subject: Re: 1776 power estimate |
Just for your information, when asking about horsepower/torque expectations, all you need to include is piston size, head details, ccs, camshaft/rockers, induction, and exhaust. When the combination becomes really wild, other small parts can be a factor like lifters, pushrods, valve make, piston make, compression, intake and exhaust specs. |
74 Thing Samba Member
Posted: Fri Oct 21, 2016 6:10 pm Post subject: Re: 1776 power estimate |
Those heads are too big for that camshaft. Change one or the other.
What exhaust and carbs will be big factors in whether you should go with smaller heads or a larger camshaft. |
Posted: Sat Oct 22, 2016 2:49 am Post subject: Re: 1776 power estimate |
I have found two nos dellorto 36 drla with 32mm Venturi's
As for the exhaust I have not concluded to something yet . What would it need to make 100-110 HP; |
Posted: Sat Oct 22, 2016 3:05 am Post subject: Re: 1776 power estimate |
Vw1600dellortoGR wrote: |
Go with some Steve Tims super stock heads and Web 163 camshaft. This is assuming it's going in a beetle or ghia. _________________ 1965 Beetle sedan
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sat Oct 22, 2016 4:15 am Post subject: Re: 1776 power estimate |
This is one of my small and quick 1600 type 1 set ups:
AB case line bored to 0,50mm. Surface cut 0,35 mm.
69 mm std crankshaft, 0,25 mm
200 mm flywheel, ligthened 1 kg.
38 mm HD flywheel bolt.
200 mm. std pressure plate. All dynamically balanced.
200 mm. Super disc.
Unitech rods, balanced +/- 0,5 gr.
26 mm Shadek oil pump, full flow.
Scat pump cover.
Cam: Web 163 special grind. 108 lc. Advanced 2 gr. ,472”/,425” valve lift.
CB 30 mm light weight lifters.
Std 85,5 mm Mahle cylinderset. Pistons balanced +/- 0,5 gr. 1,2 mm. Deck height.
Manton Cromemoly pushrods.
Old VW 043 cylinderheads, 35,5/32 mm. Valves, 9 mm. Shaft on exh. Ported to my stage II specs. Scat sgl HD valve springs shimmed 1,5 mm. 9.5-1 CR.
HD Rockershafts. 1,1 – 1 ratio.
Accuvance 009 copy w. Electronic module. Advance curve altered. 3 Ohm Pertronix coil.
Dual 40 mm Dellorto, 32 mm venturies, on Riechert manifolds.
Al´s header, 1 3/8” merged with Turbo Thomas 2” stainless Phat boy. .
Reduce CR to accept medium grade US fuel (9-1) and use a 1½" header instead. An A1 sidewinder would be a good choice. So would a CSP super comp if you are more into stock appearance. Use your 36 Dells, and you will be very close to if not spot on 110 hp.
T |
gt1953 Samba Member
Posted: Sat Oct 22, 2016 7:18 am Post subject: Re: 1776 power estimate |
Keep in mind my measurement was on a dyno. I would bet that at the flywheel it would be greater. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sat Oct 22, 2016 10:14 am Post subject: Re: 1776 power estimate |
Sorry for the thread hijack.
78 hp on the wheels, at 6500 feet is around 105 hp on the flywheel at sea level (!) How much did you do to the Kads ? |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Tue Oct 25, 2016 5:59 pm Post subject: Re: 1776 power estimate |
Did you order all your parts yet? You can have a larger 1835TW without sacrificing anything. Just order the heads with 94mm opening(Same cost) and keep your 92 opening on your case(no cost change). Then you have thicker cylinders then the 90.5's, and bigger 1835cc.
Go with a larger cam, even a 110 would be better then that C25. Just choose something better!
I wouldn't ditch the heads. That would be my FIRST choice for a 1835. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Oct 25, 2016 9:11 pm Post subject: Re: 1776 power estimate |
Properly ported stock valve (35x32mm) heads will produce 120 hp so using larger valve heads in your combo will only accomplish a slightly soggy bottom end (and maybe slightly reduced mileage). A 1776 or 1835 would have to rev to 6500 rpm to make use of 40x35 heads. Go with heads that are a better fit for what you're building if you want the best power throughout the rpm range. Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
MURZI Samba Member
Posted: Wed Oct 26, 2016 4:34 am Post subject: Re: 1776 power estimate |
Revmaster 049 heads. Flycut to 48cc, a fk41 or FK42 cam and some CB 1.3 rockers. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
porkchop-rob Samba Member
Posted: Wed Oct 26, 2016 5:28 am Post subject: Re: 1776 power estimate |
Alstrup wrote: |
T |
Is there anything available in the US that would be similar for heads? I would love to have you build me a set, but if I remember correctly, you said the freight and currency exchange would make them quite expensive.
SteveTims maybe? or some of the aftermarket small valve "as cast" heads? _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
