andybla Samba Member
Posted: Sun Oct 23, 2016 2:21 pm Post subject: off centered step studs |
Hello,
Anyone know if they exist? Off centered step studs?
I have a 8mm stud oil pump and want to put it in my 6mm case
And because the circle pattern for 8mm is bigger for 6mm pumps/cases the pump is not centered
In my mind it would look something like this
mukluk Samba Member
Posted: Sun Oct 23, 2016 2:51 pm Post subject: Re: off centered step studs |
You can use the 8mm pump with 6mm studs, no funky offset studs required. If the thickness of the pump body and cover plate are an issue, you can use longer 6mm studs or bolts. _________________ 1960 Ragtop w/Semaphores "Inga" |
mark tucker Samba Member
Posted: Sun Oct 23, 2016 9:13 pm Post subject: Re: off centered step studs |
kinda looks like it fits to me |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Oct 24, 2016 10:31 am Post subject: Re: off centered step studs |
To me it demonstrates the engineering VW was thinking all along. When they switched the stud size- they didn't enlarge them on center- but rather in a radial 'pattern.' Makes perfect evolutionary sense- run it. _________________
EverettB wrote: |
FU#5 |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Mon Oct 24, 2016 6:21 pm Post subject: Re: off centered step studs |
Make sure the inlet and outlet holes in the pump and case line up. Probably want to use the 6mm cover to prevent leaks. |
Posted: Tue Oct 25, 2016 3:22 am Post subject: Re: off centered step studs |
Hmm, i'd still rather want those off centered step studs, so that will be custom works also because for better aligning from the oil passage oils.
I am nog going to use the 6mm cover because i am doing some testing with adding a oil filter without drilling the case.
eye candy for type III people
CB performance maxi 3 pump with lots of sand paper TLC fits with only half a mm of space between
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Oct 25, 2016 6:50 am Post subject: Re: off centered step studs |
Isn't that gonna rattle like crazy? |
mr. lang Samba Member
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Oct 26, 2016 5:13 am Post subject: Re: off centered step studs |
wondered when this chart would show up _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Feb 06, 2017 6:03 am Post subject: Re: off centered step studs |
In the end i used m6 bolts with some type of spacer to fill the gap.
engine is getting almost ready
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Wed Feb 08, 2017 5:02 pm Post subject: Re: off centered step studs |
andybla wrote: |
So, did the fittings on the oil pump cover clear the shroud? Looked pretty tight to me. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Feb 05, 2018 11:38 am Post subject: Re: off centered step studs |
Bobnotch wrote: |
andybla wrote: |
So, did the fittings on the oil pump cover clear the shroud? Looked pretty tight to me. |
Had to sand a couple of millimeter from the fitting and fan shroud but got a clearance of a couple millimeter right now |
