jimdubs Samba Member
Joined: August 31, 2016 Posts: 152 Location: Buffalo, NY
Posted: Sun Oct 23, 2016 5:15 pm Post subject: Cut out headlight bucket? |
I picked up a pair of 1966 front fenders that someone cut the headlight housing (bucket?) out of. The lip is still on the outside of the fender.
Are replacement pieces available? Can I simply install a headlight assembly and not drive through puddles??
Just curious about what options are available. |
grandpa pete Samba Member
Posted: Sun Oct 23, 2016 5:25 pm Post subject: Re: Cut out headlight bucket? |
The buckets were probably cut for an extremely lowered bug ; which means they were probably driven that way for a long time in and out of puddles ; spray some paint/sealer on all the wires . _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3847 Location: San Jose, CA
Posted: Sun Oct 23, 2016 10:25 pm Post subject: Re: Cut out headlight bucket? |
Two more options:
1: Shop The Samba, CL, or swap meets, for some otherwise beat up fenders, then cut the buckets off and weld them to those sweet German fenders you bought;
2: At a crazy $200 bucks each, buy some new fenders (crappy Italian, I believe) and cut those buckets off.
For sure, if your '66 fenders are clean, they're worth saving (needless to say), whether you return them to original is your choice. I think you could tack weld them in 10 or 12 places, then just seal the joints with body sealer/caulk. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Posted: Mon Oct 24, 2016 4:46 pm Post subject: Re: Cut out headlight bucket? |
Busstom wrote: |
Thanks for the replies. I had thought of this and will keep an eye out. I also figured I could fab up some sort of crude bucket/deflector and weld it over the back of the lights.
Possibly a molded fiberglass "tub" would suffice, assuming I can get it to stick to the steel.
Mostly I was concerned about water and protection for the wires. I'm somewhat surprised that reproduction pieces aren't readily available. |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Tue Oct 25, 2016 9:48 am Post subject: Re: Cut out headlight bucket? |
Headlight buckets are available at Stoddard Porsche, part # NLA-631-151-10. But cheaper to salvage some from swap meet fenders. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Tue Oct 25, 2016 1:58 pm Post subject: Re: Cut out headlight bucket? |
I removed one of my buckets a while back.
was a 50's fender which was held in with four small welds and was a tight fit.
I ground the welds down with a dremmel and knocked the bucket out, as yours have already been butchered, it should be pretty easy remove.
I'd replace with proper buckets as suggested above or new fenders. _________________ If you can't join them, beat them! |
Posted: Wed Nov 16, 2016 4:14 am Post subject: Re: Cut out headlight bucket? |
So I sourced a couple of buckets and welded them in. One of them moved a bit, so I just want to see if it's a problem. I'm not sure how critical the exact fit is because I don't have headlights yet. Will this small gap matter?
I'm pretty sure it's fine, but it'd be much easier to fix now if needed.
Posted: Thu Nov 17, 2016 5:11 pm Post subject: Re: Cut out headlight bucket? |
The small gap should preferably be the right height and even all around if you plan to fit a headlight-to-fender seal. The position of the tab at the top of the bucket will determine how much the headlight assembly will slightly compress the seal nearby. If omitting the seal, the fit may be slightly loose but acceptable. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Nov 17, 2016 8:32 pm Post subject: Re: Cut out headlight bucket? |
Huh? Omitting the seal is acceptable? No sir.
If you intend to paint that fender a color and not have the headlight shake and rub a halo all around that hole- all the while causing the headlight to lose aim and shake it's internals loose- then indeed that seal is necessary.
It's metal to metal contact between two independently shaking pieces. Every part of a VW's body has similar isolation from wear and vibration damage.
I partially agree in this regard- the unevenness of the rim to fender gap. The most important part is that the rim is a perfectly flat plane. You must be able to place a flat plate of something on the rim and see no gapping- no potato chip wave to it. Otherwise the chrome ring (and the rest of the assembly) will fight you when tightening to the fender. _________________
EverettB wrote: |
FU#5 |
Posted: Fri Nov 18, 2016 8:18 am Post subject: Re: Cut out headlight bucket? |
Thanks for the replies. I suppose the smart thing to do would be to take the time to make it as uniform as possible now to avoid troubles later.
What's a little more grinding and welding in the grand scheme of things right? |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri Nov 18, 2016 8:26 am Post subject: Re: Cut out headlight bucket? |
Unless someone has the gap spec, I would suggest trying to scrounge up a headlight bucket and seal to make sure you have the gap right. Too many times I have guessed at something, done a lot of finish work only to have to take it all back apart, finish the mistake and redo all the work. Patience isn't a virtue for me, so I can relate. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Fri Nov 18, 2016 9:28 am Post subject: Re: Cut out headlight bucket? |
Here's the thing though. I don't recall seeing any gap at all when i cut the remnants of the old buckets out. Not only that, i have a hard time believing that some guy was measuring gaps when these fenders were made. I feel that if a gap was necessary, the Germans would have devised a way to quickly stuff the buckets in while maintaining it, such as little nubs to keep them from bottoming out.
It's my opinion (and just an opinion) that the lips ARE the placement set point. They just pushed the buckets in till they bottomed out and tacked them. |
Posted: Fri Nov 18, 2016 9:43 am Post subject: Re: Cut out headlight bucket? |
I don't have any fenders laying around with empty buckets, but looking at all the classifieds the gap looks pretty uniform. You could be right about the bump out being the guide. Looks like it would be about right. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Fri Nov 18, 2016 4:58 pm Post subject: Re: Cut out headlight bucket? |
hitest wrote: |
It's metal to metal contact between two independently shaking pieces. Every part of a VW's body has similar isolation from wear and vibration damage. |
The choice is Jimdub's whether or not a seal will be used. I've run headlights without the seals and they were snug. No vibration, no problems. The tab at the top, the mounting screw at the bottom, and the raised rim all around can provide an acceptable fit......just as they did before VW introduced the seal in Jan 1950.
There may have been a jig which ensured that the seal-type buckets were installed to the right depth. Who knows, there may have been variations on the design, (especially on aftermarket fenders) but the seals that I've used have a flange which fits perfectly into that little gap. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
hitest Samba Member
Posted: Sat Nov 19, 2016 7:19 pm Post subject: Re: Cut out headlight bucket? |
Zwitterkafer wrote: |
hitest wrote: |
You hinted at the reason for the seal in your response: Progressive Refinements.
VW added the seal for a reason. Metal to metal contact thusly eliminated in Jan 1950.
I do agree- they can be snug without, but only with perfect fender openings and straight, good quality chrome rings. I'm not sure the OP has these. _________________
EverettB wrote: |
FU#5 |
