1979vwcamper Samba Member
Posted: Wed Oct 26, 2016 10:50 am Post subject: Please help with engine ID |
Hello, I have tried to look at all the info on the engine ID, but I can not figure it out.
The case halves are 26-311 101 101 K and 40 211 101 102 D the number stamped on the case is U0298549 it is not located under the generator stand. I have been told that it is a Type 3 is that correct? It also looks like it has the mount bosses in the front for the Type II set up.
Thanks in advance!!! |
kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Wed Oct 26, 2016 11:01 am Post subject: Re: Please help with engine ID |
Pics? _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 26, 2016 2:00 pm Post subject: Re: Please help with engine ID |
Yes. I will post some tomorrow.
Thanks,
Fred |
customcityjim Samba Member
Joined: January 10, 2011 Posts: 114 Location: Arkansas
Posted: Wed Oct 26, 2016 4:28 pm Post subject: Re: Please help with engine ID |
That is a type 3 number. |
Posted: Thu Oct 27, 2016 10:39 am Post subject: Re: Please help with engine ID |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Thu Oct 27, 2016 11:42 am Post subject: Re: Please help with engine ID |
Yup..Type 3 case, I have the same UO case in my bus _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
Posted: Thu Oct 27, 2016 12:19 pm Post subject: Re: Please help with engine ID |
so, will it bolt right up? What is the difference?
Thanks!!! |
Posted: Thu Oct 27, 2016 12:26 pm Post subject: Re: Please help with engine ID |
"Bolt right up" to what?, what year bus are you thinking of using it in?
While it's apart drill and tap a hole for an oil pressure sender, that's the only really different feature from an upright cooled engine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Oct 27, 2016 12:29 pm Post subject: Re: Please help with engine ID |
Sorry!! That would help!! 1971 Westy |
fes Samba Member
Posted: Thu Oct 27, 2016 12:37 pm Post subject: Re: Please help with engine ID |
Can be used in a 1971 with no problems..another difference the type 3 case had is the oil filler neck was located on the bottom right of the case..but yours should have a delete plate over it..I can't quite tell from your pic..It just barley misses the bottom right of the sump from your shot..Do you have an open hole there? _________________ '68 Campmobile-Pedro
