jaxdream Samba Member
Joined: August 12, 2014 Posts: 31 Location: North Central Tennessee
Posted: Thu Nov 03, 2016 8:39 am Post subject: Flex Plate Bolts for T4 / 003 Auto |
Dose anybody have any experience using the flex plate replacement bolts N902 268 01 for the OEM 021 105 305A when bolting up a flex plate to a Type 4 crankshaft ?? What is the fitment like and will the new bolts interfere with the torque converter ??? Any info would be helpful as the original flex plate bolts seem unobtainable from general suppliers .
Jack |
Posted: Fri Dec 16, 2016 12:37 pm Post subject: Re: Flex Plate Bolts for T4 / 003 Auto |
Ok , I got the flex plate and the GoWesty flywheel bolts together , placed all five bolts in the T4 flex plate , bolted the plate to torque converter and there was plenty of room between the bolt heads and the torque converter . Any body needing the flywheel bolts to bolt up a type 4 automatic flex plate and bolt up to a type 3 automatic torque converter should snag a set of these bolts from GoWesty , reasonably inexpensive and should work out ok if you can't source out the original 12 spline ( triple square ) VW auto T4 flex plate bolts.
Jack |
raygreenwood Samba Member
Posted: Fri Dec 16, 2016 2:17 pm Post subject: Re: Flex Plate Bolts for T4 / 003 Auto |
jaxdream wrote: |
Jack |
Great information! Thank you!
Ray |
