NJ John Samba Member
Joined: September 21, 2007 Posts: 2223 Location: HdG, MD & NJ
Posted: Sun Nov 13, 2016 8:36 am Post subject: dropped spindles drum vs disc - offset |
Is there a difference between the offset out on the two? Or, also, what brands stick the tire out the least? Thanks John _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Nov 13, 2016 9:08 am Post subject: Re: dropped spindles drum vs disc - offset |
What front end does your car have? Link pin or Ball joint? 4 Lug of wide five?
http://www.kustom1warehouse.net/Zero_offset_front_...t5x205.htm _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 13, 2016 9:23 am Post subject: Re: dropped spindles drum vs disc - offset |
Ball joint drum _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sun Nov 13, 2016 4:22 pm Post subject: Re: dropped spindles drum vs disc - offset |
When I installed CB dropped spindles on my stock ball joint DRUM brake set-up, there was only a slight increase in track...IIRC approximately 6-8 mm per side.
However, when I installed EMPI dropped DISC spindles, this moved the wheels out 18-19 mm, which caused the stock tires to rub when turning corners. Had to switch to smaller tires (or you could use a narrowed beam). _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun Nov 13, 2016 6:54 pm Post subject: Re: dropped spindles drum vs disc - offset |
I do not think there is any difference from VW drums to VW disks, if there is I never noticed.
Any kind of dropped spindles will end up making the track wider probably 1/2 to 3/4 inch per side. |
Posted: Mon Nov 14, 2016 5:19 pm Post subject: Re: dropped spindles drum vs disc - offset |
Ok, thanks. So expect some offset and probably more with Empi. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Fri Dec 09, 2016 4:20 pm Post subject: Re: dropped spindles drum vs disc - offset |
Thanks, I saw that thread. I had built a 3" narrow beam for another project. So, I decided to use it on this car. Haven't finished the swap, yet. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
