Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Tue Nov 15, 2016 10:42 am Post subject: Worst quality spark plugs |
I just removed these craptastic "Autolite platinum " spark plugs from a customer's car.
#4 broke while trying to remove.
However, all four left their connectors in the ignition wires. I was not aware that this was a high stress connection (I have never seen this before, especially on all four spark plugs.). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Nov 15, 2016 3:56 pm Post subject: Re: Worst quality spark plugs |
I have never seen rusty spark plugs before, even ones that have been in motor for 100K miles. Does the owner rinse the motor with sea water?
At least they came out... |
Posted: Tue Nov 15, 2016 5:56 pm Post subject: Re: Worst quality spark plugs |
They were the only thing rusty in the engine bay, & the car only has 130,000 on it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Posted: Tue Nov 15, 2016 8:09 pm Post subject: Re: Worst quality spark plugs |
That is funny!
Note to self; NEVER Autolites! |
Posted: Wed Nov 16, 2016 8:02 am Post subject: Re: Worst quality spark plugs |
The rest of the engine bay is pretty decent otherwise.
I dare say that the original plugs would have been in better condition. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Nov 19, 2016 7:54 am Post subject: Re: Worst quality spark plugs |
Accept that it's missing a dipstick.
With rust at the tip of the plug, I suspect there was water present before the plug wire was connected. I personally would not use Autolite plugs on a clients or my car unless I had no choice in the matter. Obviously it worked until it was due for a service. |
Posted: Sat Nov 19, 2016 8:26 am Post subject: Re: Worst quality spark plugs |
Yes, I accept that the dipstick isn't where it should be, I remove them to take the engine over off, you can see it on top of the air box.
I don't use Autolites, Champions, or any of the other crap plugs either, I posted these to show just how bad they were. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Sun Dec 18, 2016 7:14 am Post subject: Re: Worst quality spark plugs |
My son's 08 GTi is almost ready for new plugs, could you suggest a brand ? Thanks _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Sun Dec 18, 2016 10:04 am Post subject: Re: Worst quality spark plugs |
Stick with dealer or NGK. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Dec 19, 2016 8:41 am Post subject: Re: Worst quality spark plugs |
VW does not make their spark plugs, so I would stay away from the dealership. There are way too many middle men that add to the final cost of the plug.
Stick with OEM [06H 905 601A]. NGK or Bosch is the preference for my customers. Cheap does not normally apply to spark plugs. Good ones will last 60-100k miles. Spend the money and save some time and aggravation. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Jan 21, 2017 7:47 pm Post subject: Re: Worst quality spark plugs |
always referred to autolites as "auto-seize"....those non-plated pos's would rust up and not come out of anything except an oil burning american bomb where the threads stayed covered in oil....they were particularly miserable in anything air cooled as the heat burnt off any lube....they always used to be the cheapest plug on the market...for good reason |
d4xycrq Samba Member
Joined: December 18, 2016 Posts: 20 Location: Boyertown, PA
Posted: Sun Jan 22, 2017 6:33 am Post subject: Re: Worst quality spark plugs |
NGK is the ones to buy, in my opinion.
I run two Ford tractors on Autolites! No problems.
Ray |
