modok Samba Member
Posted: Sun Nov 27, 2016 5:48 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Glenn wrote: |
When the header doesn't allow stock tins....... Get a different header.
I have 1-5/8 headers and all stock tin with Type 126 shields. |
Your berg setup is very nice and does suit the engine, but some engines require shorter primary length.
Possibly the only daily driven bug with a tri-y header.....
heck no I'm not going to modify it so the stock tin fits. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Nov 27, 2016 5:50 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
AlteWagen wrote: |
Glenn wrote: |
or you could spend 15 minutes with some tin snips and a hammer on a $5 set of cool tins instead of spending $600-2K on a performance header that can run heater boxes. |
Berg GB-933S 1-5/8" $225
http://www.geneberg.com/cat.php?cPath=448_2937
_________________ Glenn
Member #1009
#BlueSquare |
GTV Samba Member
Posted: Sun Nov 27, 2016 8:10 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Glenn wrote: |
Or simply trim the sled tins to fit the header.
Deleting the sled tins and their counterparts next to 2 & 4 makes the rest of the tin fit loosely, aka: like shit. They really do tie the room together. _________________ EMPI Power Rules! |
Glenn Mr. 010
Posted: Sun Nov 27, 2016 8:12 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
GTV wrote: |
Glenn wrote: |
Or simply trim the sled tins to fit the header. |
So then no thermostat. _________________ Glenn
Member #1009
#BlueSquare |
GTV Samba Member
Posted: Sun Nov 27, 2016 11:54 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Glenn wrote: |
GTV wrote: |
Glenn wrote: |
So then no thermostat. |
Well, yeah. I agree that your solution is by far the best, but the people that run a thermostat in this hobby are the minority. Let's say this year we will get them to swap out their cylinder deflectors, next year we'll work on the thermostat. Don't want to rush them _________________ EMPI Power Rules! |
slalombuggy Samba Member
Posted: Mon Nov 28, 2016 9:15 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
How about instead of calling people dumasses and idiots we let people do what they want on their own vehicles that they buy parts with using their own money and we can all stop being a bunch of condescending pr!#$s. I personally know of engines that have run these tins on them in daily drivers for 20+ years so it can't have that much of an adverse affect can it?
If someone wants to step up and buy me an $800 1 7/8" header and pay the freight to a foreign country to run on my car so I can run sled tins that would be great. Until then I'll run tins that help get the air around as much of the cylinder as possible. It's a work around on an engine that can't fit factory tins, runs wide open most of the time and is out in the open so trying to get uniform cooling all around the cylinder is a challenge.
brad |
mr. lang Samba Member
Glenn Mr. 010
Posted: Tue Nov 29, 2016 5:58 am Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
slalombuggy wrote: |
brad |
Just as long as people are making informed decisions.
The problem is that vendors have been pushing Super Cool Tins for so many years, they the masses just accept it as gospel.
Hey, this is America and there are way more people doing stupid stuff everyday than it's possible to help. _________________ Glenn
Member #1009
#BlueSquare |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Nov 29, 2016 7:38 am Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Like many before and after me, I bought into the "cool tin" idea when I knew no better. Used the for a while but as mentioned, fitment was always an issue and unlike has NOT been mentioned, at least for me there were 2 issues that made me give up on them. One was the "collection" of dirt and grime inside them (didn't think of flattening them darn tabs). The second was more common sense, as in protection for the push rod tubes! Not only the sleds create the correct flow of air but they also protect the tubes from possible damage from road debris. I will try to remember to post a picture of a sled which I currently use that has a dent on it. Just saying. _________________ Some people are so busy being clever they don't have time enough to be wise. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Nov 29, 2016 1:14 pm Post subject: Re: Tropical Cylinder Air Deflector |
I know, off topic, but I thank you, I've asked about this before once or twice and nothing came of it, but I figured it might pop out of the shadows if I kept trying.
I find it interesting, in that it doesn't damn the paper gaskets nearly as much as I expected. Basically, it says from early model year 74 they are deleted but to use them on all previous engines. I sort of expected it to be from later on (actually, there may very well be one for all I know)
I just went and dug into all the various parts books that VW has archived online at their Classic Parts site - German language microfiche scans for the most part - and all the post-74 Type 1 books (four of them, 1200/1300 to Jan 78, 1302/1303 to Jan 80, Mexico 1978-85 and Mexico 1986-99) show the part number but with an "X" for quantity with no explanation, dates, chassis or engine numbers, kind of unusual for the factory parts book actually. I guess Sept 1973 would be the date then...
Of course, some of those books also show compression shim part numbers for both ends of the cylinder.
Thanks for putting it up again. I've not seen the M series Tech Bulletins, the K series used to be up online several years ago, and I don't recall seeing this, but since it was in German I might not have spotted it. I only saved to my computer the pages dealing with stock single carburetors, then they all disappeared from the cloud. _________________ Andy T.
tecnica Samba Member
Joined: March 25, 2014 Posts: 7 Location: São Paulo - Brazil
Posted: Wed Dec 07, 2016 12:10 pm Post subject: Re: Tropical Cylinder Air Deflector |
Joel wrote: |
I'm surprised no one posted this.
If Volkswagen themselves say its a bad idea you probably should listen.
Well, VW of Brazil apparently did not listen themself....because here all T1 and T2 engines were equipped with these "cool tins" since 1984.
In 1984, the VW of Brazil kept only the 1600 engine, with several improvements, called "tork engine" by the market. These modifications are:
- Reduction of the fins in the cilinder heads from 8 to 6. Now they have more material in the combustion chamber, the spark plugs threads are longer (before BP5HS now BP5ES)
- Added 2 fins in the cilinders
- Oil cooler moved to a doghouse, now the #3 runs cool
- Added a thermostat to control flaps in the fan housing
- Use of the "cool tins"
- Exhaust valves reduced from 32 to 30mm
- New camshaft
This configuration was produced until 2005, using a multipoint bosch fuel injection ecu
The new heads:
modok Samba Member
Posted: Wed Dec 07, 2016 6:05 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
I think a lot of things VW of Brazil did to the VW engines was just the opposite of what hotrodders or the Germans would want, but perhaps these changes were what THEY needed. I can't judge that. I am glad they kept the engine for so long, but it seems strange to me that they made very few changes to the design in so long! |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Wed Dec 07, 2016 6:29 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Aren't those heads meant to run high compression on some ethanol mix?
That would explain the fin reduction. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
Posted: Fri Dec 09, 2016 7:18 am Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
modok wrote: |
The automotive market here is very complicated. For a long time, the life cycle of the engines and cars models was too long. VW built a confortable reputation of reliability....rsrs, we call "ism" here: VWism, Hondism (of the market of motorcycles), Samsungism (electronics)...and so on. There was no reason for big improvments, no emission laws, neither safety laws to force the evolution.
Back to the T1 engine, theese modifications was well studied by the tuners and hotrodders here. "CHT'ing" the headers shows that the warmup time was speed up, the heads run a little hotter than the 8 fins models under low loads and iddle, but little cooler under high loads.
Boolean wrote: |
That would explain the fin reduction. |
I think that main reason is keep the head temperature under a narrow band, although hotter in general use. Curiously, those 6 fins heads arrives in machine shops with low ocurrence of cracking. I believe that most of you knows that the bus was produced where until 2013, and util 2005 with the air cooled engine.
Much of theese buses were adapted to use natural gas, in most cases with low quality kits and poor job, and runs in severe use for years. When arrive the time of rebuilting, normaly the crankcase is much more damaged than the cylinders and heads, and the engine in most cases almost does not smoke. Valve guides and exhaust valve are very worn, the valves springs very weak, but low crack between valve seats. Opposite side, the bearings is very damaged, requiring new big oversized bearing due a hard lineboring.
Recently I rebuilt one of these engines, it came from a bus bought by a junkyard in a auction. The heads was only cleaned, changed the valve guides, machined in the seats, and received new valves and springs. The cylinders should go to trash, but 2 of them was donated to another unlucky bus engine (that was smoking). The crankcase, however, was linebored to 0.5mm/0.5mm oversize, and already have a steel jacket in #1, that was kept .
Boolean, the "6 fins" compression ratios where the same of the 8´s: 7.5 for gasoline, and 10:1 for ethanol ones.
The ethanol in these engines is a very cool thing, transform them in a little devil. You should experiment it. |
mark tucker Samba Member
Posted: Fri Dec 09, 2016 2:14 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
brad |
bingo, dingo,ditto. not all people have the $ for some things and not all the people have the brains if they choose a part that requires a tiny amount of mods that would probably make the entire system work better....and some are just stupid, there I said it.it may not be thier fault.. and thats ok.. as far as imformed dissions....informed by whoo??? you? RC? morlock? me? or just the gods of the internet? Ive been informed that I cant spell.....but I dosent beleave it.and my grammer is bad..well she has been dead now for 10 years. as for the tropickil cooling tins...thats the only ones I will use Im my personal vw,s. and recommend them for any I build. but unlike ugly you cant fix stupid. witch also go's for everything else related to vw's.....and thier owners no not to mean there all either ugly or stupid, just one cant be fixed. you can try, but...it wont be a complete success. so in the end do all the research you can and see what parts you want, need, have, and make a "informed" dission witch way to go and if you have to do some triming or modifying do a little at a time ask questions, and think about what you are doing and what it will cause or affect. |
Glenn Mr. 010
Posted: Fri Dec 09, 2016 2:39 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
mark tucker wrote: |
Ive been informed that I cant spell.....but I dosent beleave it.and my grammer is bad..well she has been dead now for 10 years. as for the tropickil cooling tins...thats the only ones I will use Im my personal vw,s. and recommend them for any I build. but unlike ugly you cant fix stupid. |
Oh come on Mark, I won't give up on you. There's always hope. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Dec 10, 2016 2:11 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
I realy dont think i look all that bad glenn so dont worry. |
modok Samba Member
Posted: Sat Dec 10, 2016 2:19 pm Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
I used to think the 6 fins was for ethanol too, but I was wrong.
They have different pistons for gas and alky. Big dish in piston for the lower CR gas. I still have not seen one of these pistons. If you see one take a picture for us
Remember a lot of the VW engines in the 80's were going towards a "May fireball" chamber design, with more and more combustion space being in the piston dish and less in the head. Certainly could make the piston run a little hotter and the head a little cooler. |
maggiolo72 Samba Member
Joined: April 24, 2013 Posts: 332 Location: Basel (CH)
Posted: Sun Dec 11, 2016 3:11 am Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
Here they put the supercool on the aircraft engine..... |
Glenn Mr. 010
Posted: Sun Dec 11, 2016 5:01 am Post subject: Re: Tropical Cylinder Air Deflector aka Super Cool tins |
maggiolo72 wrote: |
Are they using Type 1 fan shrouds? Or is the cooling air coming from the front of the aircraft? _________________ Glenn
Member #1009
#BlueSquare |
