langan Samba Member
Joined: December 31, 2010 Posts: 423 Location: Eagle ID.
Posted: Fri Nov 25, 2016 9:14 am Post subject: Bolting Roll Bar to Fiberglass need help |
Ok so most owner's know Manx bolts to fiberglass and through fiberglass to Torsion housing. I am lookig for Do's and Donot's for bolting through fiberglass. I want to bolt on some side bars under arms and to the front and rear hoops. I have no room to go by seats. If i just sandwich two plates between fiberglass i think it will crush the fiberglass as car flexes. I could space through fiberglass and bolt solid then tab and bolt fiberglass to hoops.
My cage is already a light duty as it is unboltable from pan. Still have rear to do.
What have others done?
sandhopper Samba Member
Joined: December 13, 2004 Posts: 453 Location: Norwalk Ca
Posted: Fri Nov 25, 2016 10:10 am Post subject: Re: Bolting Roll Bar to Fiberglass need help |
I don't have any pics of how I did it and the buggy is in the trailer .
I have a nerf bar bolted to the pan with 1 inch tubing front and back that comes up just under the fiberglass lip . I used U bolts to go around the roll cage thur the fiberglass and connect to the nerf bar . This stopped all the flex I had |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Fri Nov 25, 2016 10:28 am Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Is that a 2nd cage in the background near the o/h door??? _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
slalombuggy Samba Member
Posted: Fri Nov 25, 2016 10:44 am Post subject: Re: Bolting Roll Bar to Fiberglass need help |
I laminated steel tubes into the body on both sides that are longer than the space between the front and rear hoop. If something happens it should be enough to stop intrusion into the car and the car being light will bounce away from the impact
brad |
bigfatloser Samba Member
Joined: July 27, 2014 Posts: 94 Location: High Desert Calif
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Sat Nov 26, 2016 8:04 am Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Look at the way the outside tubes on the Manxter's connect to the verticle inside tubes. They have a 2 bolt flange that makes the connection. I don't have a picture handy, but I am sure you can find one. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
langan Samba Member
Posted: Fri May 26, 2017 6:36 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Gaining on cage,got rear cage,front bumper and most of exhaust |
Posted: Fri May 26, 2017 6:48 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Looking GREAT Jiim! _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
langan Samba Member
Posted: Fri May 26, 2017 7:44 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Thanks Paul |
wythac Samba Member
Posted: Fri May 26, 2017 7:54 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
That looks great. Love to see it in person at the Vintage Meet in July! Or maybe its time that I negatively affect real estate values on the peninsula and come darken your doorstep! |
langan Samba Member
Posted: Fri May 26, 2017 8:18 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
You are welcome anytime and were is this Vintage meet in July? |
wythac Samba Member
Posted: Fri May 26, 2017 9:38 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Nice quiver there. Sent you a pm for the summer vintage meet info. |
langan Samba Member
Posted: Sat Jun 03, 2017 2:59 pm Post subject: Re: Bolting Roll Bar to Fiberglass need help |
Some things done this trip. Finished exhaust.
Changed shock towers |
