B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Fri Nov 25, 2016 1:18 pm Post subject: Check those IRS pivot bolts! |
Weekend over for this one...
_________________ Go outside and do something. |
DSTMULE Samba Member
Posted: Fri Nov 25, 2016 7:54 pm Post subject: Re: Check those IRS pivot bolts! |
Been there. Luckily we caught it before we lost the pivot bolt. Put one in the tool box on the buggy after that episode, might be able to help someone else down the line. |
oldschool5er Samba Member
Posted: Fri Nov 25, 2016 8:15 pm Post subject: Re: Check those IRS pivot bolts! |
If the pivot bolt backed out and was not broken, a pivot bolt lock would have prevented that. You can buy the kit from suppliers (they are cheap) or you can fab up one using a bolt and welding the tabs in. Some people use a cotter key but if the pivot bolt loosens up the cotter key will let it fret the threads the pivot bolt screws into, A royal PITA. The bolt head method doesn't allow for any loosening up of the pivot bolt at all, you just remove the bolt plate if you ever need to take it out. _________________ HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving. |
Dale M. Samba Member
Posted: Sat Nov 26, 2016 8:19 am Post subject: Re: Check those IRS pivot bolts! |
Was the broken CV joint result of losing pivot bolt?
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sat Nov 26, 2016 9:23 am Post subject: Re: Check those IRS pivot bolts! |
Dale M. wrote: |
Dale |
My question too.. Cause it looks like the pivot bolt is still in place |
race-desert Samba Member
Posted: Sat Nov 26, 2016 9:28 am Post subject: Re: Check those IRS pivot bolts! |
yea it kinda looks as if the bracket broke/ off?!?!? |
Posted: Sat Nov 26, 2016 11:17 am Post subject: Re: Check those IRS pivot bolts! |
Yeah if you look at it and see how far away from the torsion housing the pivot point is, looks like the pivot bolt broke or lossened up and fell out. That could have caused the CV joint bolts to shear or the cv joint to pull apart if he keep driving on it. I am just guessing based on what I am seeing in the pic though. _________________ HRE in Westerville,Ohio
Posted: Sat Nov 26, 2016 12:20 pm Post subject: Re: Check those IRS pivot bolts! |
Yeah.... Looking at again with new insight from previous posts pivot bolt either ejected it's self or broke or mount tore off torsion tube..
Posted: Sat Nov 26, 2016 12:38 pm Post subject: Re: Check those IRS pivot bolts! |
oh yea, I was thinking I seen the bolt still in arm! that's just the inner sleeve i'm seeing! pretty clear now-bolt just fell out deal.... |
Posted: Sat Nov 26, 2016 2:28 pm Post subject: Re: Check those IRS pivot bolts! |
Yeah the bolt fell out then the CV joint failed. I was up in the dunes and it was an ordeal to get it pulled out and back to camp. Thanks to a small crowd of other duners, it didn't take that long. _________________ Go outside and do something. |
