KKiley Samba Member
Joined: March 08, 2016 Posts: 662 Location: Aruba, Jamica, nope, Kokomo
Posted: Mon Dec 05, 2016 9:20 pm Post subject: Re: Failed smog today |
Well, it does close, got it hooked up. But it didn't take anywhere near 5 minutes. It was completely closed in less than 2- 3 minutes. Maybe it needs to stay open a little longer until the engine is fully warm? Does the adjustment do that?
Thanks
Kevin _________________ 1978 Super Beetle convertible
Click to view image |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Randy in Maine Samba Member
Posted: Tue Dec 06, 2016 2:10 pm Post subject: Re: Failed smog today |
I clean mine now with Gibbs Lubricant.
Your freezer and a hair dryer are tools to be used here. |
KKiley Samba Member
Posted: Tue Dec 06, 2016 8:48 pm Post subject: Re: Failed smog today |
Ok gentlemen, I have verified the AAR is functioning correctly and we are back running. Cold start is fine. Once it is running for about 2 minutes, it still drops the idle. It will come back once it is warm.
Bill, I tried your suggestion tonight and unhooked the fuel pressure vacuum line tonight when it wouldn't idle and it idled perfectly. And the miss I was feeling went away. So making it richer is the goal.
What direction should I be looking at now?
Thanks
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Dec 06, 2016 9:00 pm Post subject: Re: Failed smog today |
Have you tried the resistors yet? |
KKiley Samba Member
Posted: Tue Dec 06, 2016 9:18 pm Post subject: Re: Failed smog today |
Haven't tried the resistors yet. I think it's a great idea. One thing bad about Radio Shack not being around, lol. I don't have anyplace close to go purchase some. Fry's is about 15 miles away up the 405, which is not fun...
I will buy a variety, just want some idea of which ones so I can do it in one trip. _________________ 1978 Super Beetle convertible
ps2375 Samba Member
Posted: Tue Dec 06, 2016 9:27 pm Post subject: Re: Failed smog today |
Like posted earlier, start with 100 ohms and add one or two to that if needed. |
KKiley Samba Member
Posted: Tue Dec 06, 2016 9:41 pm Post subject: Re: Failed smog today |
Thanks ps2375, I will give that a try and pick up a variety pack. Understanding this system better, it makes perfect sense. _________________ 1978 Super Beetle convertible
JKLNHYD Samba Member
Joined: July 21, 2007 Posts: 260 Location: Pasadena, CA
Posted: Tue Dec 06, 2016 9:53 pm Post subject: Re: Failed smog today |
Does this sound like an oxygen sensor? _________________ Jon
1971 1776 |
KKiley Samba Member
Posted: Tue Dec 06, 2016 10:03 pm Post subject: Re: Failed smog today |
No oxygen sensor on a '78, they were only on '79 CA versions _________________ 1978 Super Beetle convertible
Posted: Tue Dec 06, 2016 10:05 pm Post subject: Re: Failed smog today |
Ah, ok.
I wrestled with smog on a '79 f250 for a year, so I am rootin for you. _________________ Jon
1971 1776 |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Tue Dec 06, 2016 10:25 pm Post subject: Re: Failed smog today |
For what it's worth....the state of Ca. makes it almost impossible to pass smog with pre '95 cars. I have a '79 bug that runs perfect and can't pass the current smog test unless I take it to my mechanic and let him dial it in with his old smog machine. Then he runs it down to the test station, it passes and then he has to dial it in to run right. Been doing this for 20 years! |
KKiley Samba Member
Posted: Tue Dec 06, 2016 10:32 pm Post subject: Re: Failed smog today |
Well, it passes on the high speed with room to spare, just failed on the idle HC's. It does have a low idle tremble, that went away when when I unhooked the fuel pressure regulator, so I think the resistor will add fuel where it needs it to pass. Just a micro adjustment will do wonders I think. _________________ 1978 Super Beetle convertible
EVfun Samba Member
Posted: Tue Dec 06, 2016 10:56 pm Post subject: Re: Failed smog today |
if the lean condition is just an idle problem you can keep closing the air bypass screw on the air flow meter. It changes the running mix very little, but has a pronounced effect on the idle richness. Adding some resistance to the temp sensor is another fine idea, but that should richen the mix at any rpm by making the "computer" think the engine has not fully warmed up.
You can make adjustments to the air flow meter too, there are 2 adjustments for the variable resistor, one changed the return spring tension while the other shifts the base point for the variable resistor. This is much more of a PITA though, best done only if you can tune the engine with a exhaust analyzer checking the mix prior to the catalytic converter. _________________
Wildthings wrote: |
Posted: Tue Dec 06, 2016 10:59 pm Post subject: Re: Failed smog today |
Is your bung plugged? _________________ Jon
1971 1776 |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Wed Dec 07, 2016 9:09 am Post subject: Re: Failed smog today |
Hi. That's good news Kevin. This is progression. As far as resistors go, in my general area there is an electronics store call All Electronics Corp, www.allelectronics.com, and you could shop their site at home and order. These resistors seem to be dirt cheap and looks like a minimum order is 10 pieces, at about .60 each. They are in Van Nuys, Ca.
I have a Frye's about a mile from me if you want I can go over there for you.
It would be nice to know if the removal of this vac line richened up enough to bring the HC down into compliance. Also the ability to sniff the exhaust prior to the cat and after would tell you how effective the cat is working.
Does the shop that did the initial smog offer free retest? Wonder if they would do a pre-test to see if the improvement brought the HC down, but, as important, did not raise the CO. If it did a minor adjustment to the AFM screw might bring the CO down.
Hope this helps, Bill. |
Posted: Wed Dec 07, 2016 9:22 am Post subject: Re: Failed smog today |
Al Capulco wrote: |
Hi. You're so right on this Al. There are groups of people here in Calif, as well as other states to include Washington DC, who wish all the old cars to go away probably by regulation like tighter emissions standards. Most good people don't have the drive to keep up with this but ever tightening gov't control.
The SAMBA is different. People here will do whatever it takes to maintain their precious rides. I know a very respectful shop owner who has told me he has had owners of '76 and later bus' who give up on Calif's emissions program and there are people from different countries lined up waiting to buy up their cars and remove them from Calif.
Bill |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Wed Dec 07, 2016 9:23 am Post subject: Re: Failed smog today |
KKiley wrote: |
No oxygen sensor on a '78, they were only on '79 CA versions |
Uh, no, Cal Bus had it in 79, but Bugs never did. That's all VW needed to do to certify the Beetle with the Feds for the 1980 model year, and they didn't do it, instead they extended the 1979 O2-less model year as far as they could (into January 1980), and then shut it down. _________________ Andy T.
Posted: Wed Dec 07, 2016 2:06 pm Post subject: Re: Failed smog today |
Fed emissions and Cal emissions are totally different though, even to this day. I am not debating you, just saying. I didnt know that you could have a cat without having an O2 sensor. _________________ Jon
1971 1776 |
Posted: Wed Dec 07, 2016 3:39 pm Post subject: Re: Failed smog today |
Put it this way, if VW was already making a O2 sensor California Beetle in 1979, they could have just made that as the 49 state model for model year 1980. They didn't. _________________ Andy T.
