JQ Samba Member
Posted: Sun Nov 27, 2016 2:43 pm Post subject: Electical problems with random no start. |
1970 hardtop westfalia with 1600cc motor. I had her sitting for about a year and a half while I replaced my transmission and did other work on her. I got her back on the road again recently and I'm having some tricky electrical problems that weren't there when I parked her. First off, sometimes (very rarely) as I try to start the motor the key turns all the way with no reaction from the starter. Battery is fairly new and good condition with a full charge. While she was parked I took apart the starter and solenoid, cleaned it, regreased, and reassembled. The majority of the time it starts and sounds just fine but when it doesn't I either wait a little bit and keep trying and then eventually it will turn over. I have also used a portable jumper pack to give it a little boost and surprisingly that works as well. Also after I start it once the problem goes away for a couple weeks and then come back randomly, as is first thing/cold start, or after I drive and park and try to restart. Is this an ignition switch problem starting to develop or a starter/solenoid issue.
Next, my oil pressure gauge worked fine before but now the warning lamp stays on and the gauge doesn't move. I know for sure I have oil pressure and shes been driving great so I doubt it's that. I bought a new replacement VDO sender because I thought my old one was bad but same thing. I even tried using the stock single pole sender and the light still didn't go off. Ideas?
Also, my turn signals seems to work whenver they feel like it and the light on the dash will flash a couple times and then stop or not at all. Is the relay in question here?
I did no work electrical work while she was parked and all these things worked fine before making me believe it might be a corrosion issue at some of the terminals and I have tried cleaning them up but it would be nice on where to look before I wire brush every connector.
Thank you,
JQ _________________ 1967 Bug aka "Junior" (SOLD)
1970 Campmobile aka "Penelope the BEAST" |
timvw7476 Samba Member
Posted: Sun Nov 27, 2016 2:58 pm Post subject: Re: Electical problems with random no start. |
The first two issues, I'd check the ground strap, trans to body & the
ground surface for the negative battery cable, the turn signal issue,
check the fuse, actually clean all the fuses, they like to corrode at the
contact surfaces at the ends and stop current flow.
I doubt Vacaville gets too moist, but you list S.F. too, so...moisture
& change-of-seasons. Contact point cleaning time. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Nov 27, 2016 3:47 pm Post subject: Re: Electical problems with random no start. |
timvw7476 wrote: |
^ This ^
Every electrical event you have enjoyed in your VW came from electrons flowing from the negative post of the battery into the vehicle's metal. From their ground spades or mounting points, the electrons are "sucked through" the starter/lights/wipers/turn signals, etc and are vacuumed back into the battery through the positive post with such vehemence that you will see sparks.
Clean your grounds from whence the magic flows.
Colin _________________ www.itinerant-air-cooled.com |
SGKent Samba Member
Posted: Sun Nov 27, 2016 3:56 pm Post subject: Re: Electical problems with random no start. |
the most common starter no start failure is a sticky solenoid. That said, you want to be sure every connection is clean and solid like the last two posters suggested. A common quick test is to have someone turn the key for you and tap the solenoid with a wrench, hammer or screwdriver. Notice I said tap not hit. If that makes it kick over the grease inside it has hardened. I went thru this faithfully on a near new 1971 VW bus for 400,000 miles once every couple years while I owned it depending on miles driven and how long it sat.
As for oil pressure, I would insert a mechanical gauge and check again. The light and gauge are two separate circuits, and you have tried 3 senders. That would deeply concern me. Making matters worse, the light won't come on unless the engine block is grounded so if that had no ground the light would not work. You can pull the wire off the sender and see if the light goes out. If it does then don't drive it until you check for oil pressure with a mechanical gauge. Does it have oil in it? Are you sure? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
JQ Samba Member
Posted: Fri Dec 02, 2016 6:15 pm Post subject: Re: Electical problems with random no start. |
SGKent wrote: |
As for oil pressure, I would insert a mechanical gauge and check again. The light and gauge are two separate circuits, and you have tried 3 senders. That would deeply concern me. Making matters worse, the light won't come on unless the engine block is grounded so if that had no ground the light would not work. You can pull the wire off the sender and see if the light goes out. If it does then don't drive it until you check for oil pressure with a mechanical gauge. Does it have oil in it? Are you sure? |
I disassembled, cleaned, and regreased the starter and solenoid so unless I did something wrong everything is clean. Although I did try tapping the solenoid when it first happened to no avail.
I've been meaning to double check it with a mechanical gauge but haven't done so yet. This is the same motor that was in it before i parked her and the gauge worked then showing it had pressure. I'm most confident it has oil in it and I check it often. I;ve already driven about 800miles so far and the oil temps never get above 180F so I feel if something was wrong I would know.
I agree with the other posters and will double check all grounds and terminals for contact/corrosion.
Thank you,
SGKent Samba Member
Posted: Fri Dec 02, 2016 6:19 pm Post subject: Re: Electical problems with random no start. |
pull the wire off the sender and see if the light goes out. If it does you either have a rash of bad senders or low oil pressure.
Have you checked the screen to be sure it is clean? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
JQ Samba Member
Posted: Fri Dec 02, 2016 6:25 pm Post subject: Re: Electical problems with random no start. |
SGKent wrote: |
Have you checked the screen to be sure it is clean? |
Does it matter which one? Or try pulling both, one at a time?
The oil screen? Yes. And have replaced the oil twice in the time of a couple months. _________________ 1967 Bug aka "Junior" (SOLD)
airschooled Air-Schooled
Posted: Fri Dec 02, 2016 6:27 pm Post subject: Re: Electical problems with random no start. |
Check the oil level too. Once my engine consumed a quart in 250 miles. It never did it before, or after. Well, except that one time it blew the oil cooler seals… Then it dumped it all in 250 feet! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri Dec 02, 2016 6:30 pm Post subject: Re: Electical problems with random no start. |
JQ wrote: |
SGKent wrote: |
pull the wire off the sender and see if the light goes out. If it does you either have a rash of bad senders or low oil pressure. |
Does it matter which one? Or try pulling both, one at a time? |
The gauge and the warning light have two separate wires, and they go to particular terminals on the VDO sender. The engravings on the back of the sender are etched "G" for GAUGE and WK for WÅRNING KLÎGHT I guess… Make sure the stock green wire is going to the GAUGE terminal. If they were switched, you would get a flickering oil light and a peaked gauge needle though…
SGKent is saying pull the WK wire from the dual-pole sender and see if the light goes out. If it stays on, you have a wiring issue causing the green wire to ground prematurely, and if it goes out, you have sender issues.
busdaddy Samba Member
Posted: Fri Dec 02, 2016 6:38 pm Post subject: Re: Electical problems with random no start. |
asiab3 wrote: |
Robbie |
You mean like when it touches the manifold preheat tube and melts the insulation so it grounds out? (not that I've ever seen that happen before).
Robbie wrote: |
WÅRNING KLÎGHT |
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Dec 02, 2016 6:44 pm Post subject: Re: Electical problems with random no start. |
busdaddy wrote: |
asiab3 wrote: |
Robbie |
Robbie wrote: |
WÅRNING KLÎGHT |
Desertbusman caught that wire on my original engine five years ago at a car show!
(That's the only way I can remember what the other inscription is. Two teaching degrees and government jobs instill a dire need for acronyms everywhere.) _________________ Learn how your vintage VW works. And why it doesn't!
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Fri Dec 02, 2016 10:59 pm Post subject: Re: Electical problems with random no start. |
The only way to accurately diagnose a starter issue is with a voltmeter. You need that, and a pair of test probes which have clips on the ends.
- Connect the meter from the small starter wire from the ignition switch (still connected to the starter) to engine ground. Have someone try to start. Watch the meter. If it reads near battery voltage, then the solenoid is getting power but not doing anything with it. Repair / replace the solenoid.
- If the voltage is low, then move the meter ground to body ground, and try again. If the reading is normal, then it's the tranny ground strap.
- if it's still low, then move the meter ground to the battery '-' terminal and try again. If the reading is normal, it's the battery ground cable or its connections.
- If the reading is still low, move the meter to the ignition switch. Red probe to the red/white starter wire, black to body ground. If the reading is normal, then it's the wire to the starter or its connections.
- If still low, move the red meter wire to the red supply wire to the ignition switch. It should read 12 volts immediately. Try to start. If the reading stays steady, it's a bad switch. If it drops, keep tracing the red wire back to the fuse block, headlight switch, and eventually to the battery '+' terminal. Somewhere the voltage will stop dropping. The problem lies between that point and where the voltage drop is measurable. Inspect, find, and fix.
Note: it is typical to find and fix one problem only to find it then occurs somewhere else. Keep finding and fixing. The practice will do you good the next time the horn quits... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
SGKent Samba Member
Posted: Sat Dec 03, 2016 12:56 pm Post subject: Re: Electical problems with random no start. |
telford dorr wrote: |
Note: it is typical to find and fix one problem only to find it then occurs somewhere else. Keep finding and fixing. The practice will do you good the next time the horn quits... |
Amazing - and to think that back in 1977 on that cold pavement all I had was a hammer. A tap on the solenoid and the bus started. Three days later in Amarillo I started a bug that way for someone. Sometimes one has to improvise when no meter is around > But I do agree a volt meter and knowing how to use it is the easiest way. Problem is that 99% of mechanics don't really understand electrical circuits enough to use a meter. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Dec 04, 2016 10:44 am Post subject: Re: Electical problems with random no start. |
Hence the long-winded tutorial... _________________ '71 panel, now with FI
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Sun Dec 04, 2016 12:11 pm Post subject: Re: Electical problems with random no start. |
Just to add to the solenoid story - I had this intermittent non-starting problem on my bus . And at the same time I also had a defective ignition switch.
Some times the starter did not engage even with 12v direct on the tags on the back
Other times not even 12v on the starter.
So the resolution was a new ignition switch (although stripping down the old switch, collecting springs and ball bearings in the dark with a big flashlight from the driveway, cleaning and reassembly worked for a while)
And because I could not be bothered, a reconditioned starter motor. _________________ Ancient vehicles and vessels
Posted: Sun Dec 04, 2016 4:51 pm Post subject: Re: Electical problems with random no start. |
A multiple failure like that doesn't surprise me. If the solenoid fails to pull in, it will, due to how it works, draw a huge amount of current. This huge current will slowly destroy the ignition switch.
Cascade failure... _________________ '71 panel, now with FI
