ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Sun Dec 04, 2016 10:21 pm Post subject: Re: January 1963 squareback |
notchboy wrote: |
Sweet stamped mounts
Jacks house has always been the Type 3 Factory. |
Funny you say that because in the past 10 years I have had an amazing amount of really special cars reside in my yard. Only a couple were mine but I guess that's what happens when you get to rub elbows with the 1500club elite😎 _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22457 Location: Escondido CA
Posted: Mon Dec 05, 2016 10:24 am Post subject: Re: January 1963 squareback |
We need to steak a sign in the corner of your yard with the list of whats come through there, start signing that thing too _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
pedro sainz Samba Member
Posted: Mon Dec 05, 2016 9:29 pm Post subject: Re: January 1963 squareback |
ibjack wrote: |
notchboy wrote: |
Funny you say that because in the past 10 years I have had an amazing amount of really special cars reside in my yard. Only a couple were mine but I guess that's what happens when you get to rub elbows with the 1500club elite😎 |
One Out of Jacks Yard and reside for many months
Is on the cover on Hot VWS Mag
Great things Happends here
Jacks Type 3 - Type 34 Factory _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
ibjack Samba Member
Posted: Mon Dec 19, 2016 10:40 pm Post subject: Re: January 1963 squareback |
Received the kits needed to finish refreshing the front brake cylinders. All ready to go.
Gas tank had 8 gallons of vintage 1976 leaded gasoline in it. It's been drained and the desludging has begun. Not a lot of fun _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
ibjack Samba Member
Posted: Wed Dec 21, 2016 8:49 pm Post subject: Re: January 1963 squareback |
Just wanted to say thanks to Per, Christmas came a few days early.
the1500club.com
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
ibjack Samba Member
Posted: Sat Dec 24, 2016 5:47 pm Post subject: Re: January 1963 squareback |
i needed to replace a headlight so I thought it would be a good idea to take pictures of an early original set up. I'm sure that I'm the first person to open the headlight up since it left the factory almost 53 years ago.
Details of the SB12 outer ring
Part #
This one has two drain holes, which must be early since the ones off my 65 notch had no holes
One neat feature is the writing on the rear hatch. I think I was an indication of what script was to be installed
the1500club.com
t3kg Samba Member
ibjack Samba Member
Posted: Sat Dec 24, 2016 11:53 pm Post subject: Re: January 1963 squareback |
t3kg wrote: |
ibjack wrote: |
That's awesome. Are you going to try to preserve it? |
That's my plan. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4188 Location: Pasadena CA/DTLA soon China
Posted: Sun Dec 25, 2016 12:42 am Post subject: Re: January 1963 squareback |
Nice! Vut I thought Sb12 rings were a 1967 item. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Sun Dec 25, 2016 11:47 am Post subject: Re: January 1963 squareback |
ALLWAGONS wrote: |
Nice! Vut I thought Sb12 rings were a 1967 item. |
As far as I know all inner retaining rings were S12's. _________________
t3kg wrote: |
1964 1500 S
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
ibjack Samba Member
Posted: Thu Jan 05, 2017 5:16 pm Post subject: Re: January 1963 squareback |
The original gas tank had 8 gallons of early 70's leaded gasoline in that turned into varnish sludge so I opted to use one of my spares. I sent it out to be cleaned and lined, even though many don't think it's necessary or good to do but I've had good luck with it. I also got lucky to find a fuel sender from 2.63 since the wire on the original broke when trying to clean it. Before I installed the tank I decided to give the spare tire area and the trunk/front end a good clean up. Since this is a preservation and not a restoration I'm trying to clean up what I can and leave it alone. I'm inspired by Lee Hedges documentation on his super early T34 (vin 0001200) so I'd like to do the same with this car since there are very few early original squarebacks.
Here's a shot of the cleaned up spare tire well. Original seal was in good condition but I noticed that the used a liberal amount of glue and didn't seem to worried about getting it on perfect.
It really is an advantage to remove the gas tank to replace or service the top part of the front end. I installed the master cylinder and cleaned and refreshed brake lines coming from the reservoir. Also topped off the steering box with fresh oil.
All put back together
Looks more work going on and updates will be happening. Any other early Squateback owners feel free to post pictures of what you have. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Jan 05, 2017 8:27 pm Post subject: Re: January 1963 squareback |
Please tell me you kept the original fuel sender...Jim Adney can repair them and he does excellent work!
If you need the steering box rebuilt, Tim's rebuilds are to factory spec and they turn out really nice. He can rebuild the one from that car and return it to you unless it's out of spec for wear. I can help you out if that happens. |
ibjack Samba Member
Posted: Thu Jan 05, 2017 10:56 pm Post subject: Re: January 1963 squareback |
ataraxia wrote: |
I checked with Jim first and was going to have it rebuilt but the other one was real nice and just a month off. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
65Nsqback Samba Member
Joined: September 17, 2004 Posts: 1256 Location: Grantsville UT
Posted: Fri Jan 06, 2017 10:45 pm Post subject: Re: January 1963 squareback |
Looking good Jack keep it up...this one will be back on the road in time _________________ Wow look at that THAT'S A "SHOW CAR"!!
you can't be something your not...be your self by your self stay away from me
__________________________________
I'm Trying to help you.......but you don't hear me... |
Stevo Wide 5 Samba Member
Joined: August 30, 2000 Posts: 1110 Location: Antwerp, Belgium
Posted: Sun Jan 15, 2017 4:49 am Post subject: Re: January 1963 squareback |
Very nice car bud! Love early type 3's!
here are some pics of my may 63 Square!!
_________________ 62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com |
