beetleman217 Samba Member
Posted: Tue Nov 29, 2016 12:28 am Post subject: Timing with stroboscope |
I have my 2.0 FI engine timed to 7.5 BTDC using a test light. It runs good, however I think it would be a good idea to properly time it with a stroboscope. Should I time it at idle RPM to 7.5? Or like I was told once at 3000 RPM to 30 degrees? _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Nov 29, 2016 1:13 am Post subject: Re: Timing with stroboscope |
You need a timing light not a stroboscope.
https://www.amazon.com/Actron-CP7527-Inductive-Tim...1248861011
There are cheaper timing lights, but his is a tool you will use repeatedly and the money is well spent. You will also need a dwell meter if you have points.
http://www.ebay.com/itm/like/331963334829?vectorid...rmvSB=true
The engine will run well by setting the points at .016 with a feeler gauge or matchbook cover, but why not start by setting at .016 and then do it right?
Dwell affects timing. Timing does not affect dwell. It's easier to R&R points and condenser and set the gap while the distributor is on the bench, rather than bending over with half your body in the engine compartment.
Check your Bentley and TheSamba for correct timing for your engine.
Aloha
tp |
Posted: Tue Nov 29, 2016 1:30 am Post subject: Re: Timing with stroboscope |
The reason for setting your timing to 28° @ 3500+ rpms with the hoses off and plugged, is that this is the condition your engine see when pulling a hill at full throttle.
The idle timing spec was a best guess at what the timing might be at idle when every part was factory new, it hardly applies when the dizzy may be a hodge podge of parts from different units and even if the parts are original they are old, sticky, and worn. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Nov 29, 2016 7:07 am Post subject: Re: Timing with stroboscope |
beetleman217 wrote: |
I have my 2.0 FI engine timed to 7.5 BTDC using a test light. It runs good, however I think it would be a good idea to properly time it with a stroboscope. Should I time it at idle RPM to 7.5? Or like I was told once at 3000 RPM to 30 degrees? |
You should time it at idle to 7.5 BTDC using the timing light (and after disconnecting and plugging the vacuum hose to the distributor).
Then, since you have a type 4 engine with a handy timing scale, you can check the timing at max advance and make sure it's not advancing too far beyond 28-30 degrees. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Nov 29, 2016 7:39 am Post subject: Re: Timing with stroboscope |
Thanks everyone for the input. I gapped the points to spec when the dizzy was out. I forgot to mention that my dizzy is centrifugal advance only, no vacuum canister. _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
SGKent Samba Member
Posted: Tue Nov 29, 2016 8:06 am Post subject: Re: Timing with stroboscope |
mike's post to time it to 28 is what I would do.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Randy in Maine Samba Member
Posted: Tue Nov 29, 2016 9:42 am Post subject: Re: Timing with stroboscope |
You should be looking for a more appropriate distributor for this application.
Put a "Want to Buy" in the classifieds. |
curtp07 Samba Member
Posted: Tue Nov 29, 2016 12:49 pm Post subject: Re: Timing with stroboscope |
And be very careful of used distributors....could be complete junk! _________________ Subaru |
Posted: Tue Nov 29, 2016 12:52 pm Post subject: Re: Timing with stroboscope |
curtp07 wrote: |
And be very careful of used distributors....could be complete junk! |
So are many of the new ones out there |
Posted: Tue Nov 29, 2016 1:08 pm Post subject: Re: Timing with stroboscope |
Wildthings wrote: |
curtp07 wrote: |
Damn straight.. _________________ Subaru |
Posted: Tue Nov 29, 2016 1:43 pm Post subject: Re: Timing with stroboscope |
Glenn can tell you the distributor you need and will sell you a rebuilt. Possibly take yours as a core.
http://www.glenn-ring.com/bosch/
Aloha
tp |
Posted: Wed Nov 30, 2016 11:23 pm Post subject: Re: Timing with stroboscope |
Tom Powell wrote: |
From Wikipedia:
"A stroboscope used to set the ignition timing of internal combustion engines is called a timing light."
Well as I stated the bus is running like a Swiss watch, which is why I'm reluctant to even touch it, let alone replace the distributor. The only thing I'm concerned about are high head temps due to wrong timing. I have a head temp instrument installed but I don't really trust it. It shows around 200F when the engine reaches working temp. _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Posted: Thu Dec 01, 2016 1:02 am Post subject: Re: Timing with stroboscope |
Tom Powell wrote: |
From Wikipedia:
"A stroboscope used to set the ignition timing of internal combustion engines is called a timing light." ... |
Amazon sells a stroboscope for $157.33 + $10.04 shipping
https://www.amazon.com/Sper-Scientific-840009-Digital-Stroboscope/dp/B00V65N8X4
They sell a timing light for $16.99 and free shipping
https://www.amazon.com/Tooluxe-20724L-Automotive-F...ming+light
How do you get a stroboscope to flash when the ignition fires? They're usually used to determine rotational speed. Both can use a strobe light, but they have different purposes and use.
Perhaps Wikipedia should say, "A strobe used to set the ignition timing of internal combustion engines is called a timing light." They do say, "A stroboscope also known as a strobe, is an instrument used to make a cyclically moving object appear to be slow-moving, or stationary."
Aloha
tp |
Posted: Thu Dec 01, 2016 5:34 am Post subject: Re: Timing with stroboscope |
Tom Powell wrote: |
From Wikipedia:
Well as I stated the bus is running like a Swiss watch, which is why I'm reluctant to even touch it, let alone replace the distributor. The only thing I'm concerned about are high head temps due to wrong timing. I have a head temp instrument installed but I don't really trust it. It shows around 200F when the engine reaches working temp. |
What CHT gauge do you have and where did you install the sender? A 009 distributor is a poor choice for a FI Type 4 engine in a bus. |
Posted: Thu Dec 01, 2016 8:47 pm Post subject: Re: Timing with stroboscope |
The CHT that I have is the VDO 600F, with the 323 701 temperature sender. The sensor is screwed to the sensor port on the head. The reason I don't trust it is because I have 2 wires running the length of the bus connecting the sensor to the gauge, and I read somewhere that the length must be specific in order to get true readings.
This is the reading I got today after a half an hour drive. For a minute let's assume the reading is correct. What is the normal working head temp range of a Type 4 FI engine?
1977 Westfalia
1961 Beetle |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Dec 01, 2016 9:32 pm Post subject: Re: Timing with stroboscope |
If it works anything like an exhaust pyrometer like I have, then I don't think it is so much the distance of the wires, but the types of wire used and how it is connected.
So if you need to lengthen the wire, if you extended it with the correct wire it isn't really a big deal. But if you used any ole wire from the FLAPS then yes it is suspect.
You could get an idea, perhaps, of if and how far it is off with an infrared thermometer. Drive the bus to operating temps for a bit, then pull over quick and run back and take a reading. Won't be perfect probably, but it'll give you an idea if and how close your gauge is. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Dec 01, 2016 11:28 pm Post subject: Re: Timing with stroboscope |
Somewhere a thermocouple system must have a cold junction. If you use thermocouple wire all the way to the gauge the cold junction will be in the gauge and may or may not be temperature compensated depending on the design of the guage, while if you use a non thermocouple wire for an extension the cold junction will be where the thermocouple wire hooks to the non thermocouple wire.
Not sure what you mean when you say the sensor is screwed into the sensor port??? Are you talking the location of the TSII sensor? The early TSII sensor location will give a good indication of the actual temperature of the head, whereas the later TSII sensor location will read somewhat lower.
When you put the sensor under the spark plug, what you are really doing is sticking the hot junction down into the spark plug well between the metal of the head and the metal of the spark plug and your reading will be something close to the average temperature of the two pieces of metal. "Note, the ring itself is not the hot junction, only the crimp is. If you install the hot junction somewhere else, then it will not be affected by the heat of the spark plug and thus will read very different from a setup with the hot junction next to the plug.
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Dec 02, 2016 2:27 am Post subject: Re: Timing with stroboscope |
Quote, "What is the normal working head temp range of a Type 4 FI engine?"
Buuuuwaaaaahahahah....Buwaaahahahaa! _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Fri Dec 02, 2016 5:07 am Post subject: Re: Timing with stroboscope |
If you are going to use a CHT gauge (even a VDO), you have to at least install the sender correctly withthe sender around the #3 spark plug.
http://www.germansupply.com/home/customer/home.php?gspage=customer/main/tech/cht/cht_install.tpl |
