Pgbarrow Samba Member
Joined: June 19, 2016 Posts: 19 Location: Phoenix, AZ
Posted: Wed Nov 30, 2016 9:13 pm Post subject: Breaking inner tie rod ends loose |
Hey guys,
I have a couple stuck inner tie rod ends. Is this a job for a pickle fork? (Just returned my rental yesterday) Do you guys have any other suggestions? I've hammered on it (as I can) and tried to use a press, but did not have enough space to line it up.
Thanks,
Paul
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Wed Nov 30, 2016 9:22 pm Post subject: Re: Breaking inner tie rod ends loose |
BFH (I use a 48 oz) & strike the pitman arm. You may want to thread a nut on the threads to keep from damaging them in case you miss. Pickle forks destroy the boot & sometimes damages the tie rod end. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Nov 30, 2016 10:38 pm Post subject: Re: Breaking inner tie rod ends loose |
Hum, not following you on that one. How does hitting the pitman arm drive out my tie rod ends? Also, is there another ball joint in the steering clam/box thing? I'm getting tires of ordering parts piecemeal.
Thanks,
Paul |
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Thu Dec 01, 2016 12:52 am Post subject: Re: Breaking inner tie rod ends loose |
Just had a tie rod that was stuck. Took a day and a half to break free. Keep soaking it with PBlaster |
Frodge Samba Member
Posted: Thu Dec 01, 2016 4:11 am Post subject: Re: Breaking inner tie rod ends loose |
Kroil works even better. |
Posted: Thu Dec 01, 2016 4:23 am Post subject: Re: Breaking inner tie rod ends loose |
Penetrating oils aren't going to do much for loosening the wedge mated connection that the tapered ends of the tierods have. 2-3 strikes of a heavy hammer will jar it loose.
In your picture, you can see that shiny glare on the pitman arm just above the threads of the tierod, that's pretty much where you want to knock the living sh*+ out of it with the BFH. It's counterintuitive but it does the least amount of damage to the components. Again, loosely thread a nut back onto the tierod end to keep from damaging the threads just in case you hit them. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
JKLNHYD Samba Member
Joined: July 21, 2007 Posts: 260 Location: Pasadena, CA
Posted: Thu Dec 01, 2016 5:16 am Post subject: Re: Breaking inner tie rod ends loose |
EverTough 67008
I rented it from Oreilleys for $35, you can access all of them.
_________________ Jon
1971 1776
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Dec 01, 2016 6:26 am Post subject: Re: Breaking inner tie rod ends loose |
just whack it with a BFH, you are not going to hurt it. Loosely put on the nuts first. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Thu Dec 01, 2016 6:53 am Post subject: Re: Breaking inner tie rod ends loose |
Don't whack it with a BFH. That's a good way of putting undue stress on the steering box. Got get the right tool at whatever tool place you have near you.
Look at this page and the tool you want is in the lower left. You can get a full front end kit like this, or just the individual tool. If you are replacing the tie rods, then you can use a pickle fork as well (which is how I did it). |
Posted: Thu Dec 01, 2016 7:13 am Post subject: Re: Breaking inner tie rod ends loose |
Chochobeef wrote: |
A large pothole exerts more stress on the steering components than you will be able to with a hammer, if something happens to the steering box when you hit the pitman arm with a hammer, you have just saved your own ass. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
beetlenut Samba Member
Posted: Thu Dec 01, 2016 7:22 am Post subject: Re: Breaking inner tie rod ends loose |
I used a small two arm puller to pop all my old tie rods off. As suggested, thread the castellated nut on to protect the threads. The trick is heat! I tightened the puller down, and then used a propane torch to heat the end of the rod until it just popped off. You need heat to expand the metal of the wedge mated connection of the tapered ends of the tie rod. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Thu Dec 01, 2016 7:30 am Post subject: Re: Breaking inner tie rod ends loose |
heat near the gas tank I don't think so.
My tool box is full of specialty tools for working on bugs and the best one for this job is a well placed whack with a BFH.
you can take off the kids gloves when working on these inanimate objects
This is why most shops don't let the customer in the work area, they would be offended that you are ruining their precious vehicle _________________ Rick
tasb wrote: |
sb001 wrote: |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Dec 01, 2016 7:32 am Post subject: Re: Breaking inner tie rod ends loose |
I beat on a lot of things with a hammer, but not a steering box. Use the pickle fork or other removal tool. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Dec 01, 2016 7:35 am Post subject: Re: Breaking inner tie rod ends loose |
if you aim it just right you don't have to worry about hitting the steering box. _________________ Rick
tasb wrote: |
sb001 wrote: |
Q-Dog Samba Member
Posted: Thu Dec 01, 2016 7:39 am Post subject: Re: Breaking inner tie rod ends loose |
60ragtop wrote: |
if you aim it just right you don't have to worry about hitting the steering box. |
True, but you and I and several others here kinda know what sort of force is appropriate and where to apply it. If the OP knew those things he wouldn't be asking us what to do.
Always try the least destructive thing first. In this case I think the BFH on the steering box would be a last resort sort of thing. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Posted: Thu Dec 01, 2016 7:45 am Post subject: Re: Breaking inner tie rod ends loose |
60ragtop wrote: |
This is why most shops don't let the customer in the work area, they would be offended that you are ruining their precious vehicle |
That's what pullers were made for, so you don't damage something else while trying to do a job! Any competent mechanic uses heat to loosen stuck bolts and tie rods. As with any tool though, it has to be used judicially. A BFH isn't always the right answer, especially when working on steering components! _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Thu Dec 01, 2016 7:47 am Post subject: Re: Breaking inner tie rod ends loose |
Q-Dog wrote: |
I beat on a lot of things with a hammer, but not a steering box. Use the pickle fork or other removal tool. |
& what do you do with the pickle fork? You hit it with a BFH.
The problem with the pickle fork is that it pinches the boot against tierod & destroys the boot. Add to that it also damages the tierod end, which is fine if you plan on replacing it anyway. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Dec 01, 2016 8:40 am Post subject: Re: Breaking inner tie rod ends loose |
I'm glad I learned how to work on cars before Al invented the internet.
really _________________ Rick
tasb wrote: |
sb001 wrote: |
Q-Dog Samba Member
Posted: Thu Dec 01, 2016 12:24 pm Post subject: Re: Breaking inner tie rod ends loose |
TDCTDI wrote: |
Q-Dog wrote: |
The problem with the pickle fork is that it pinches the boot against tierod & destroys the boot. Add to that it also damages the tierod end, which is fine if you plan on replacing it anyway. |
Well, I start with a LFH, and I don't use the pickle fork unless I won't be reusing the parts. _________________ Brian
'69 Dune Buggy
'70 Beetle |
